Old Nov 15, 2012, 11:39 AM
AJWoods is online now
Find More Posts by AJWoods
Aircraft Designer Guy
AJWoods's Avatar
United States, CA, Santa Clara
Joined Jul 2005
Originally Posted by Petefoss View Post
How are you masking for painting Adam? Frisket paper?
I'm just using manilla folder, I lightly dust the areas around the edges with 3m77 (very very light dusting) then I spray straight down over the part.
-A
AJWoods is online now Find More Posts by AJWoods
Old Nov 15, 2012, 03:43 PM
Petefoss is offline
Find More Posts by Petefoss
Petefoss's Avatar
Oxford, Michigan, United States
Joined Aug 1999
Deleted.
Petefoss is offline Find More Posts by Petefoss
Old Nov 15, 2012, 07:47 PM
AJWoods's Avatar
Joined Jul 2005
Got it all finished up tonight. Motors are from an old Airhogs and I'm using the mCX brick with the yaw gyro popped off. Came in at 18.5g with a 150mAh lipo, could prob go a bit smaller. Getting just about 1:1 thrust:weight.
Flies great, differential thrust is very effective, and I'm thinking the speed will be nice and relaxing once I've got it properly trimmed.
Cartoon Skeleton F-35 Maiden (0 min 58 sec)
This guy's a keeper, time to expand to the rest of the egg plane fleet.
-Adam
Old Nov 15, 2012, 07:51 PM
minimicrorc is online now
Find More Posts by minimicrorc
Joined Apr 2012
vtol coming I hope?
minimicrorc is online now Find More Posts by minimicrorc
Old Nov 15, 2012, 08:02 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Very nice adam
I have an mcx and msr brick laying around waiting for such projects
Well done sir!
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 15, 2012, 08:59 PM
AJWoods's Avatar
Joined Jul 2005
Originally Posted by Razors edge 29 View Post
Very nice adam
Well done sir!
Thanks! Yeah, the mCX brick is a nice little unit that is often overlooked for twin micros (mostly because the gyro orientation would provide roll feedback through the diff thrust if left stock.) They gyro is the silver rectangular component on the servo side of the board. You can literally just pop it off with a razor blade, and the unit will function fine with differential thrust, and no weird feedback.
-A
Old Nov 15, 2012, 09:09 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Yah I have done some research on the mcx brick
Modfly has a good thread on it
I was going to try the MSR brick as well but it won't work the same
However it may be useful in other unique projects
I have a twin project in mind using mcx or mossie brick as well
A allied WW2 airplane that never made it to mass production but would've been fantastic.
Just got a box of depron so it's time to build' build, build lol
Question
Have you used the model plane foam yet? If so how did you like it?
-A
Old Nov 16, 2012, 08:25 PM
AJWoods's Avatar
Joined Jul 2005
Got a few more flights on it this evening, trimmed nicely now. Flies great, loops and will do a dirty roll. I added a set of removable gear from the um-T-28. Should have move video and plans up by the end of the weekend.
-A
Old Nov 16, 2012, 09:31 PM
Joe Malinchak is offline
Find More Posts by Joe Malinchak
Carbondale PA
Joined Aug 2005
Hi Adam,
Your Cartoon Scale Skeleton F-35 model looks really cool. You did a great job with its design!
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
Old Nov 17, 2012, 12:52 PM
AJWoods's Avatar
Joined Jul 2005
Here are the plans, incorporating a few changes from the prototype. The sheets are full size, but I included a 1inch scale on both. Foam parts are on a 24X12.5in sheet (wing is 12" span, so I added a 0.5" margin) Stencils are on 22x17in. There are also optional intake pieces, I drew/made but did not install.
Cartoon Skeleton F-35 (2 min 22 sec)
-A
Old Nov 17, 2012, 04:32 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
What Travel extents did you set the rudders? Is it just straight up?
Sometimes with my MCX Differential thrust conversions I have to play with the rudder travel to avoid death spirals.
UNGN is offline Find More Posts by UNGN
Old Nov 17, 2012, 04:43 PM
AJWoods's Avatar
Joined Jul 2005
I left them at 100% with about 30% expo. Full aileron and rudder will do a nice barrel roll. Roll is very sluggish using just taileron, so I'd suggest people who are more right stick centric setting up a 50% aileron-to-rudder mix.
-A
Old Nov 17, 2012, 05:12 PM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Thanks Adam!
Old Nov 17, 2012, 07:01 PM
AJWoods's Avatar
Joined Jul 2005
No problem Pete! You get started on that cub yet? I finally got around to making a plug for the windscreen.
-A
Old Nov 18, 2012, 06:11 AM
Petefoss is offline
Petefoss's Avatar
Joined Aug 1999
Nope it got pushed behind another plane. When Carolynn says she wants a plane, it jumps to the top of the pile! She really likes Mark's new Camp e-Racer in Halloween trim.
What do you think about your Cub on 2S?
Discussion Skeleton Cartoon Pitts (now with video) Gordon Johnson Scratchbuilt Indoor and Micro Models 113 Sep 23, 2012 01:03 PM
Sold LPU San Antonio TX: JPower 50mm MiG-15, F-86, F-22 and F-35. FoamJunkE Aircraft - Electric - Jets (FS/W) 3 May 09, 2012 12:00 PM
Mini-Review Cartoon F-14 Plans SteveLeach Foamies (Scratchbuilt) 3 May 02, 2012 10:19 PM
Discussion Micro Skeleton(sorta) F-22 Jet rcalldaylong Scratchbuilt Indoor and Micro Models 13 Sep 04, 2011 05:38 PM
Build Log Skeleton Cartoon Albatros D.V. LRF... FINALLY FINISHED! starscream4002 Scratchbuilt Indoor and Micro Models 19 Jun 21, 2011 08:16 AM
