Nov 12, 2012, 02:17 PM
USA, WA, Benton City
Joined Oct 2007
One of our members built one just like yours for test use. Just a few things need to be changed on his. Make sure the wheels are low enough OR big enough so it rolls without digging into the dirt/grass. Add a tray underneath to hold your flight box/starter/fuel etc. Replace the uprights with a removeable wood dowel on both sides. Allows you to use pipe foam. The most important mod needed was to add a round stick/dowel to act as a handle on the rear end. Our's is a bugger to move around because you're too close to the stand when rolling it around. Just drill a hole thru the wood and put the dowel on a chain. They're sure better then working on your hands & knees. Keep up the good work.
Dan
Latest blog entry: I've had enough!
