Old Nov 11, 2012, 08:50 PM
grosbeak is offline
Find More Posts by grosbeak
Illegitimi non carborundum
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Hobbistar 60 - Tail dragger conversion
Now that the wing repair is complete, I'm turning my attention to the next project for this plane - converting it from conventional tricycle gear into a tail dragger.
The first step was to remove all of the stock landing gear.
grosbeak is offline Find More Posts by grosbeak
Old Nov 11, 2012, 09:01 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Next step: Filling in the main gear channel with some scrap.
I went with a Sullivan tail wheel. The original idea was to have it castering, but a closer look at the tail presented a different solution - taking a notch out of the elevator.
The notch was centred, but the stripes weren't.
Re-covered...
Old Nov 11, 2012, 09:08 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
After the notch was cut and covered, I ground off the heads of the plastic tail bolts, possible because the horizontal and vertical stabilizers are epoxied in place. Once that was done, I re-covered the tail.
The tail wheel bracket was mounted with four servo screws...
... and the steering arm was connected to the rudder.
Old Nov 12, 2012, 02:48 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Innovative spring shock absorbing linkage
Clean job
(confirm CG)
Very nice
Regards
Rick
rick.benjamin is offline Find More Posts by rick.benjamin
Old Nov 12, 2012, 08:52 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
I would think that will work just fine. It doesn't take much to steer a tail wheel. Nice clean set up.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old Nov 12, 2012, 09:11 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Thanks, fellas! I will definitely recheck the CG.
Old Nov 13, 2012, 05:21 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
On to the main gear. The first step was to decide on the orientation. I chose to have it sweep back.
There are calculations you can do to determine where the gear should go. After a lot of thought, research and advice I decided that placing the axles directly beneath the leading edge (in a level attitude) was the solution for me. To that end, I followed these steps.
  1. Eyeball the placement of the gear on the fuse
  2. Mark the leading edge of the gear on one side of the bottom, 5mm from the edge
  3. Insert a t-pin at the mark
  4. Roughly across the bottom from the t-pin, make a short line parallel to the edge and 5mm from it
  5. Pick a forward point on the fuse. Measure halfway across the bottom and insert the t-pin there
  6. Measure the distance between the two t-pins
  7. Mark the same distance from the forward -pin to where it intersects the 5mm line drawn in step 4.
  8. Insert a third t-pin at the mark
  9. The line between the two rearmost t-pins forms an accurate leading edge location for the gear
Old Nov 13, 2012, 05:28 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
With the leading and trailing edges of the gear marked, the covering came off the bottom.
There was a small gap at one point where a razor blade could be worked in...
... but first the bottom had to be cut across. A fine-toothed back saw worked well.
Old Nov 13, 2012, 05:34 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
With the crosscuts done, a razor blade fit nicely into the gap.
A small scraper soon followed.
With some gentle encouragement, the bottom plate came off the fuse with little damage.
Turns out I had a hardwood block that was the perfect depth and width - it just had to be cut to length.
Old Nov 13, 2012, 05:45 AM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
I used 30 minute epoxy to secure the block.
While it was curing, I turned my attention to the gear itself. Drilled out the axle holes...
... test fit the axles...
... and marked the centre line.
Old Nov 13, 2012, 08:54 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Looking good so far. Your tailwheel has good springing between rudder and wheel - essential to avoid feeding shocks back up to your rudder servo thanks to those odd less than straight roll-outs we all do - very occasionally, of course Main gear location is good too, you can't go far wrong with your placement.
Keeping the main UC and model in tight formation can be a problem. I learned that the hard way back when I first flew higher powered electrics, with 40 ounce batteries...
My favourite reinforcement involves two lengths of 1" alloy 'L' section from a local hardware store. These are epoxied between the UC plywood mount plate and the fuselage sides -which in my models are inevitably doubled up with thin ply. Hope the attached photo makes it all clearer
D
Dereck is offline Find More Posts by Dereck
Old Nov 14, 2012, 02:50 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Thanks!
D
Nice approach. In my case, the mains for the tricycle gear were made of music wire and were held in by a little friction and a couple of small straps with tiny wood screws, which did not loosen at all over the life of the plane.
My plan for the new undercarriage is five #8 screws into the hardwood block. I'll keep an eye on them, but I don't think they're going to work loose.
Old Nov 14, 2012, 03:44 PM
EJWash1 is online now
Find More Posts by EJWash1
AMA 910957
EJWash1's Avatar
United States, WA, Hoodsport
Joined Mar 2008
Nice project, and cleanly executed.
EJWash
EJWash1 is online now Find More Posts by EJWash1
Old Nov 14, 2012, 08:27 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
Thanks EJ!
I put the tail wheel on before work this morning - couldn't wait to see how it looked.
I made a drilling template for the main gear based on the location of the hardwood block.
Got the holes marked and ready for drilling.
Old Nov 14, 2012, 08:43 PM
grosbeak is offline
grosbeak's Avatar
Canada, ON, Ottawa
Joined Mar 2011
With the holes marked it was time to lug my trusty drill press to the bench.
A little protection...
Started with the pilot holes.
Then to an 11/64" bit for the #8 wood screws.
Discussion Repairing an RTF wing - my Hobbistar 60 trainer grosbeak Crash Discussion 70 Jan 25, 2013 11:10 AM
For Sale Hobbistar 60 select rtf ROBERT.S Aircraft - Fuel - Airplanes (FS/W) 1 Dec 18, 2012 11:22 AM
Discussion Tail dragger CP airframe? kenh3497 Classic Pattern Flying 5 Apr 18, 2012 11:09 AM
For Sale 2 new tail sets for hobbico hobbistar 60 johnsheri Aircraft - Fuel - Airplanes (FS/W) 0 Jan 04, 2010 09:15 AM
Wanted Hobbistar 60 wing/tail feathers Harlan Aircraft - Fuel - Airplanes (FS/W) 2 Jul 29, 2007 11:55 AM
