This thread is privately moderated by earlwb, who may elect to delete unwanted replies.
Old Nov 11, 2012, 07:59 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
My Low Wing plane
Many years ago, circa 1990, my best friend at attempted a business venture, where he would have some planes made as ARF's that used foam core wings with 1/64 inch plywood sheeting, balsa, ply fuselage and tail. But the best part was they were all hand painted very nicely. Well the batch of prototype planes all worked out great. I built up six of them for my friend and had used Saito engines for three of them and Fox engines for the other three. He had three models, designed for .45 two stroke glow engines, a high wing trainer like plane, a high wing sport plane and a low wing sport plane built more like a pattern plane.
But unfortunately things didn't work out so well for the container load that came in. The planes were produced during the monsoon season and loaded into a container, which was shipped to Arizona. The dry heat in Arizona dried the wood out too much and the paint all cracked and peeled around the edges of the planes. Some planes turned out much worse than others though. But he couldn't sell them as new, high quality ARF's though.
Anyway, I have been building and flying some of the planes for years now. A while back I accidentally crashed a low wing plane. But I dug another one out of the storage shed and put it together. I almost lost it when some high winds caused it to pancake into the ground when it lost lift at the flying field. But it wasn't damaged much, so I fixed it back up to fly again.
So here is the latest incarnation of the .45 size low wing plane with a NGH 9cc gasoline engine mounted on the front of it. The engine actually pulls the plane around really well too. It does get a bit of a power boost from the Tower muffler that is mated to the engine. The low wing plane is fairly large and has a 59 inch wingspan, so it would work Ok with a .60 engine on it too. So I can see where the NGH 9cc engine would pull around a Hangar 9 Phoenix Pattern plane Ok too. Maybe not as good as a modern 2 stroke glow engine could, but it would be acceptable.
But the last time I had it out, the Spektrum radio was acting all funky when I fired up the engine. The radio would work fine until the engine started and then it would reset itself, which isn't good. So I switched it over to the Futaba one instead. So I'll see how that works instead. It it flakes out too, then there is a problem with the wiring or connectors someplace. The other two planes with NGH engines on them both use Futaba gear and they haven't exhibited any of those funky things the Spektrum gear exhibited. At first I thought it was the FiFe battery pack, so I changed it out and the plane still had problems with the Spektrum receiver.
Here it is beside my Escapade .40 plane. It is quite a bit larger in size versus the little Escapade.
earlwb is offline Find More Posts by earlwb
Old Nov 22, 2012, 09:33 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I made a video clip of me flying the low wing plane with the little NGH 9cc gasoline engine on it. I used a 11x7 Master Airscrew prop and a Tower Hobbies muffler on the engine. I did some low high speed passes so I could guage its flight speed using a Doppler Shift speed checking program and I got readings stating the plane was going just a hair under 58 mph in the air.
Flying my Low Wing Sport Pattern Plane with a NGH 9cc engine on it (10 min 7 sec)
Old Nov 25, 2012, 10:51 AM
psychoticflyer is online now
Find More Posts by psychoticflyer
psychoticflyer's Avatar
United States, NJ, Barnegat Township
Joined Nov 2012
walbro carb
were did you get the part used to bolt carb to on the walbro convertion,,,thanks
psychoticflyer is online now Find More Posts by psychoticflyer
Old Nov 28, 2012, 08:19 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
One of our forum members Gary Cee made it for me.
Old Jul 16, 2013, 01:08 PM
JohnAV8R is online now
Find More Posts by JohnAV8R
Canada, ON, Hamilton
Joined Oct 2005
Nice model Earl. I like it.
The engine sounds almost like a glow .60.
John
JohnAV8R is online now Find More Posts by JohnAV8R
Old Aug 01, 2013, 09:59 AM
comy is offline
Find More Posts by comy
comy's Avatar
ShangHai China
Joined Jun 2008
its Designer is my friend,in the same city
comy is offline Find More Posts by comy
Old Aug 12, 2013, 10:19 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Nice to meet you. I think the engines turned out OK, but there were issues with the pump/regulator unit. Other than that it seems to work fine.
One issue is that the pump cover may not fit flush with the pump body. I think the center post protrudes just a tiny bit too much and it doesn't get enough pressure to seal up well along the edge. That might be the main problem. I have been thinking about it for a while now and what might be done about it.
Old Sep 24, 2013, 04:02 AM
comy is offline
comy's Avatar
ShangHai China
Joined Jun 2008
Thank you !I will let my friend know this。
Old Dec 11, 2013, 11:22 PM
GallopingGhostlr is offline
Find More Posts by GallopingGhostlr
Vintage Aircraft Lover
GallopingGhostlr's Avatar
United States, NM, Clovis
Joined Jan 2013
earlwb, listening to the video, that is a really sweet sound coming from your plane. I've considered getting one of those .52 gas burners, too. Plane almost looks like a Lanier of the late 1970's, is it? For an ARF, it looks like a fine performing plane.
GallopingGhostlr is offline Find More Posts by GallopingGhostlr
Old Dec 22, 2013, 05:38 PM
G WILLIE is offline
Find More Posts by G WILLIE
Bill Mohrbacher, MECA Fox Guy
G WILLIE's Avatar
Beaver Falls, PA
Joined Dec 2006
This summer one of my buddies had a gas powered 108" Citabria newly built. He had maybe 20 or 30 flights on it, no radio problems at all. He put in a different spark plug as the idle wasn't quite right. The airplane started glitching now and then. After several flights we realized throttling back would allow control to be regained. He realized the problems began when he changed the sparkplug. It turned out the new plug was a bit shorter than the old one that came with the engine. The actual contact inside the high tension boot was making intermittent contact with the new plug! So much for 2.4's interference rejection!
G WILLIE is offline Find More Posts by G WILLIE
Old Dec 22, 2013, 07:16 PM
Joined Jan 2013
My guess is the electromagnetic interference (EMI) was strong enough from the spark at the high tension boot cap of the engine due to its close proximity to the receiver, that it it induced interference past the RF (radio frequency) section of the receiver injected into amplification portion that affected the digital portion that drove the servos. The radio has no shielding, like an aluminum case with antennas protruding to prevent this type of interference. Even then it could possibly find its way in.
Spark interference is so strong, that car ignition systems use resistor cables or resistor links to minimize EMI for broadcast radio reception. Those radios are usually well sheilded in a metal case. If it affects car radios, then so much the same for RC.
Although 2.4 GHz technology is good, there are some additional caveats that cannot be ignored to ensure reliable operation, IMO.
Glad to see your buddy found out the problem and is aware of how to solve.
Old Jul 26, 2014, 11:49 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Just to let you guys know, but the NGH 9cc engine is still working for me. It get abused fairly hard in flying, as I am flying WOT the whole time. With this low wing plane it is a bit underpowered for the takeoffs, but once it is up to speed it does OK.
Anyway the engine is getting a bit grungy too. But it is still hanging in there. Even with the 100 degree heat we have down here in the summer, the engine is performing well still.
Anyway, it has been well over a year now and many flights later and something like three to four gallons of gasoline through this engine and the other two I have as well, but the engine is still working OK for me.
Old Jul 26, 2014, 02:51 PM
Joined Jan 2013
That's neat earlwb that the NGH 9cc gasser is able to power that plane. It sort of reminds me of the planes of the 1960's. Then AFAIK, people used less power, engines produced less power, required a bit more skill to fly. Greatest incentive is the reduction in fuel costs.
Old Jul 26, 2014, 11:33 PM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Thanks, in thinking about it, this plane was flying since fall 2012, with this particular engine on it. The Ugly Stick plane was flown late winter or early spring 2012 and the Escapade was first flown summer 2012. So the engines have had their share of problems, but they have been working Ok and hanging in there though.
Discussion Motor for my X5 wing, low KV is better? Gio_fly Power Systems 28 Oct 24, 2012 09:56 PM
Wanted Low wing plane 60 size dpenoncello Aircraft - Fuel - Airplanes (FS/W) 2 Jul 31, 2012 02:38 PM
Rant Low wing electric plane Betomxl Glow to Electric Conversions 53 Jul 28, 2012 01:39 AM
Discussion Any tips for my first flight with a low wing plane? Warthog_Fan Fuel Plane Talk 4 Sep 06, 2009 08:53 AM
Discussion My 1st low wing plane and I crashed 1st flight captainkarl Beginner Training Area (Fuel) 23 Feb 03, 2008 08:53 PM
