This thread is privately moderated by epoxyearl, who may elect to delete unwanted replies.
Old Nov 11, 2012, 06:16 PM
epoxyearl is online now
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
odds and ends
I'm trying to enlarge a 32" Sparky rubber powered model to 114"....I have some of the framework completed but I want to turn a LARGE prop.
If every thing scaled properly,I'd need a 43" one. to be properly sized.
I got a .60 size helicopter drive system which is geared 8.5 to 1...
With the engine turning around 8,500 r's and the prop at 1,000,it seems possible..
I need to build up the prop like miniature wings,with strong spars and maybe foam cores,sheeted and glassed.
I don't know if it'll work,but I ain't skeered to try.
epoxyearl is online now Find More Posts by epoxyearl
Latest blog entry: My "Take" on the AMA
Old Nov 11, 2012, 11:01 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
A 43" prop... awesome. . Order some thin NACA foam cores from FlyingFoam and give them a good spar and a sturdy glassing and you should be OK for 1,000 RPM. Emphasis on should. That's the only way I can see it working though.
Or order some ~1000mm Heli blades and add them to a 10" yoke.
acetech09 is offline Find More Posts by acetech09
Old Nov 12, 2012, 05:41 AM
epoxyearl's Avatar
Joined Oct 2011
My most recent experience is with a 62 cc gas engine with a belt reduction.It normally turns a 22 x 10 prop around 7,000 rpms.With the belt reduction, it turns a 32 x 12 prop at 4,000,with noticeably more 'pulling' power-over 35lbs.!
Since the Sparky is a slow flyer anyhow,with loads of lift,I don't think a prop with lots of pitch will be overtaxed to move it.
I'll never forget the sound of the original balsa prop huffing around on a still evening...Prolly won't hear this one over the engine,but........
Sold Odds And Ends. Curt S Non R/C Items (FS/W) 2 Oct 23, 2012 10:10 PM
Sold Closed 500Driver Aircraft - Electric - Multirotor (FS/W) 0 Oct 22, 2012 03:38 PM
For Sale Servos,Motor, ESC, odds and ends! prodigy Non R/C Items (FS/W) 14 May 13, 2012 10:55 AM
Sold Odds N Ends irun4fundotca Non R/C Items (FS/W) 0 Mar 19, 2012 11:42 PM
Sold Odds & Ends, Custom Parts, Spring Cleaning 500Driver Aircraft - Electric - Multirotor (FS/W) 3 Mar 09, 2012 08:44 AM
