Old Nov 11, 2012, 04:42 PM
Honza C is offline
Find More Posts by Honza C
Crashing? Hunting the mole!
Honza C's Avatar
Česká republika, Jihomoravský, Brno
Joined Jan 2011
Download
Symmetrical 4-digit NACA airfoil generator in Matlab
I was stuck with a Katana plan with the ribs but not the cuts of the whole wing that would help me to produce templates for sanding the leading edge. A fellow modeller produced some airfoils in 'profili' for me, but simply none was properly fitting.
So I sat down, found the equation for NACA profiles at http://en.wikipedia.org/wiki/NACA_airfoil and wrote a little Matlab function. There is no fancy maths, so it should work also with the free clones of Matlab (Octave, Scilab, ...). The result can be exported to DXF using writedxfline.m from Mathworks pages: http://www.mathworks.com/matlabcentr...writedxfline.m
I overlapped the results with the original ribs in Draftsight, looks pretty good. It can be easily modified for assymetrical NACA profiles or anything where you have the parametric representation.
RCG do not support *.m files, so remove the .txt from the filename after downloading it.
Honza C is offline Find More Posts by Honza C
Question Airfoil, Clark-Y vs. NACA 2412? abroadhurst94 RC Airliners (Commercial, Cargo, Troop Carrier) 51 Aug 03, 2012 08:44 AM
Build Log Tritle Pitts 14 Build Log with NACA 23012 airfoil 4stroker Scale Kit/Scratch Built 11 May 14, 2012 02:32 PM
Discussion Tritle Pitts 14 : anyone tried the semi symmetrical NACA 23012 ? 4stroker Scale Kit/Scratch Built 0 May 03, 2012 05:30 PM
Discussion Will it fly? Symmetrical airfoil no vertical surfaces Joe_Wildcat Flying Wings 12 Apr 21, 2012 10:43 AM
How does a fully symmetrical airfoil generate lift? AndrewsJr Power Systems 11 Dec 05, 2001 11:07 AM
