Old Dec 26, 2012, 01:01 PM
jeffpn is offline
Find More Posts by jeffpn
Joined Mar 2011
Originally Posted by TTRotary View Post
Hmm, don't agree with this.
Yes you do, you just don't know it . If you are an experienced RC pilot, I'm sure you've helped a newbie learn how to fly on a plane you owned. I bet it flew differently than yours, too.
Or let's say that you get a plane kit, and I get a plane kit. We each build them. Even if we tried to build them identically, they probably wouldn't perform identically. Lets say I slide my battery pack all the way back, because I like an aft CG. You slide your forward because you like it a little tamer. You like more rudder authority than I do. Some manufacturers even specify an acceptable range of CG. they specify ranges of motors or engines to use. The same kits can be built quite differently, and won't perform the same as each other at all.
Like Skaluf said, all of these variables (and many, many more) can be adjusted in RF to give you the exact performance you are looking for.
jeffpn is offline Find More Posts by jeffpn
Old Dec 26, 2012, 04:26 PM
TTRotary is offline
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
That is why I indicated an ARF built to spec. Exact build, power system, and CG instructions were followed. Still flew totally differently from the sim version. Bottom line: the sim versions of the warbirds fly like trainers, not real warbirds (or at least this is true of RF and FSOne). If a newbie became "proficient" landing the sim P-51, then tried to land the real plane, they would most likely have a pile of scrap wood. I agree each real model is slightly different from the other, but most ARFs fly very similarly to each other if trimmed out and completed properly. P-51s always have p-factor on takeoff, and they always tipstall (snap) to the left if the nose is up too high and the speed is too low on final approach. The full scale does the same. My point is that the sim versions are deficient in that they totally fail to model these common characteristics of the type.
So my original question still stands: have those of you who design models for download for RF come up with a warbird that's tough to fly. Just curious at this point.
Thanks on the suggestions for 6.5. I will take a look in the LHS at the advanced sections in the sim and see if I can modify to my liking.
TTRotary is offline Find More Posts by TTRotary
Old Dec 26, 2012, 06:48 PM
jeffpn is offline
Joined Mar 2011
Heh. I'm good at making RF aircraft next to impossible to fly, but I suppose that's not what you're looking for!
Personally, I don't even like to do physics when I design a model for RF. I'm not really into the real hobby anymore, and I've never flown a scale warbird. Anything I would do would only be a guess. I can't speak for other modelers. You might try asking your question at the RF forums.
Old Dec 26, 2012, 07:03 PM
dedStik is online now
Find More Posts by dedStik
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
I've done both the real warbirds and the sim warbirds and like jeffpn says they fly like someones interpretation. I've searched and searched for a PZ Bf 109 in a sim that actually flies like mine. There isn't one, all I've found are too easy to fly as TT has stated, and I realize the only way I could have one is to mod an existing till it flew like mine, even then there will be someone whose flies completely differently from mine.
dedStik is online now Find More Posts by dedStik
Old Dec 26, 2012, 09:42 PM View Post
jowiejooijdofig
A moderator felt this post violated the following rule: Excessive Advertising (Spam). Show it to me anyway.
Old Dec 28, 2012, 12:31 AM
jriley1974 is offline
Find More Posts by jriley1974
Angry Flyer!
jriley1974's Avatar
washington state
Joined Oct 2008
A couple things might contribute to the 'easyness' of warbird flight in the Sim. Having no wind, in my opinion makes everything easier. Certainly when it's calm outside I find it hard to tip stall most of my warbirds unless I get really slow. Also, perhaps it's hard to tell how fast a Sim model is actually flying. Maybe the model is flying (vectoring) faster than it appears on screen in certain view modes.
I would think increasing/decreasing AUW can create a desired stall charateristic too.
jriley1974 is offline Find More Posts by jriley1974
Old Dec 28, 2012, 08:24 AM
Skaluf is offline
Find More Posts by Skaluf
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
Correct, most of us do not fly in perfectly calm conditions. Crank up the wind, add some turbulence and you can accurately replicate a real-world environment. Minor tweaks to the aircraft will get it flying like you think it should in a realistic environment.
Steve
Skaluf is offline Find More Posts by Skaluf
Site Sponsor
Old Dec 28, 2012, 01:29 PM
TTRotary is offline
Joined Mar 2010
Agree. We need wind. I saw somewhere that 6.5 can do various wind models including cross wind up to 90deg. Does anyone know whether it can model gusts? That is mostly what I deal with out here in SoCal.
Old Dec 28, 2012, 01:50 PM
jeffpn is offline
Joined Mar 2011
RF simulates gusts, turbulence, thermals, variabilty in speed and direction, faster wind at higher elevation. Really just about every possible wind scenario.
Old Dec 28, 2012, 03:55 PM
TTRotary is offline
Joined Mar 2010
Cool, thanks Jeff. My only experience with RF is Basic. May be time to upgrade, though $175 is pretty steep.
Old Dec 28, 2012, 04:11 PM
jeffpn is offline
Joined Mar 2011
I've paid that 3 times for 3 different versions of Realflight; G2, G3, and G4 . Fortunately for me there was an upgrade price for G5 and RF6. You may only have to pay $175 once.
Old Dec 29, 2012, 02:27 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Its worth the price tag for what you get imo you will be stoked if you pull the trigger on this sim.
Kris... is offline Find More Posts by Kris...
Old Dec 29, 2012, 01:03 PM
TTRotary is offline
Joined Mar 2010
with these features, it should be. I'll get over tl the LHS and check it out.
Old Dec 29, 2012, 05:43 PM
GassPasser is offline
Find More Posts by GassPasser
Pro Bro # 2398
GassPasser's Avatar
BoonVegas, Indiana
Joined Dec 2005
i cant get my new headphones with mic boom to work in multiplayer. any suggestions ?
GassPasser is offline Find More Posts by GassPasser
Old Dec 30, 2012, 10:00 AM
Vrated is offline
Find More Posts by Vrated
Vrated's Avatar
United States, UT, Marysvale
Joined Aug 2004
Wow! I just was going through the Knifeedge forum. They are beating up on some poor guy pretty bad. Kinda funny.
http://www.knifeedge.com/forums/show...d=1#post243968
I couldn't find a whole lot of new planes, etc, on the new G6.5 can you load the older Real Flight aircraft from say the G3.5 into G6.5 in Windows 8?
Vrated is offline Find More Posts by Vrated
Question Realflight 6/6.5: Prometheus model sound effects. Puzom Simulators 9 Nov 15, 2012 02:38 PM
Found Realflight 6.5!!!!!!!!!!!!!! joker24458 Aircraft - General - Miscellaneous (FS/W) 5 Oct 09, 2012 07:33 PM
Question Is it worth the $50 to upgrade Realflight from 4.5 to 6? Kevinfred Simulators 2 Aug 19, 2012 03:30 AM
Discussion G5.5 user created in RealFlight 6? viciouspeanut Simulators 1 May 15, 2012 09:48 PM
Wanted Realflight 5.5 or 6 spektrumforever Non R/C Items (FS/W) 3 Apr 10, 2012 10:28 PM
