Old Nov 17, 2012, 03:19 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
The green foam is stryodur the lightest version: 28kg/m3
http://www.basf.de/en/produkte/plast...dur_2500_c.htm
It's the 2500 serie that I've got in 5cm thickness
The plan is to cut it with Hotwire and I've already did some tests but this stuff don't leave one heavy nasty smell so I can work with it without getting stoned
I hope she's running fine nitro! I'm waiting for test results!
I doesn't going to use the case because I think it will going to be to heavy so I will attach the motor in the place where the inlets come together isn't that a better plan for you nitro?
The first plane will run at the normal brushed motor while I'm testing the single phase setup
It's good flying weather out here so I'm at the field to fly! Good bye, Robert
robertboxhoorn is offline Find More Posts by robertboxhoorn
New Product Yeah Racing (#F104-014SS) Spring Steel Main Drive Shaft Black for Tamiya F104 Pro edwardchan80 Product Announcements 0 Jul 19, 2012 09:31 PM
Discussion Green air design 50mm EDF F104 Starfighter - where can I get one? redtail Foamy EDFs 5 May 16, 2012 02:16 AM
Discussion Green Air Design Starfigther F104 EDF redtail Foamy EDFs 10 Apr 10, 2012 02:43 AM
Discussion 1/68 Scale BAe Hawk (15mm EDF) Chris T Scratchbuilt Indoor and Micro Models 178 Feb 19, 2009 08:11 AM
