Old Nov 11, 2012, 10:27 AM
robertboxhoorn is offline
Find More Posts by robertboxhoorn
Flying Dutchman!
robertboxhoorn's Avatar
Nederland, FL, Emmeloord
Joined Sep 2011
15mm edf f104 1/72?
Hey guys,
I was thinking about one new micro edf
The plane I loved the most is the f104 so that's the one I'm wanna build bu I know that it will be difficuilt.
I've just got a new type of foam that is very light and very strong and I've calculated that the full fuse without wings and stabiliser wil be about 0.6gr
I'm thinking about the wings what type of material I'm gonna use 0.8mm balsa or or the same foam.
Foam is lighter but its about my thought to weak in 0.8mm thickness but I will cut some test wings.
I am thinking about this as setup
Shapeways 15mm rotor from nitro
http://www.hobbyking.com/hobbyking/s...em_combo_.html
This but without the prop and gear
http://www.hobbyking.com/hobbyking/s..._Receiver.html
Fully stripped so without connectors and shrink tube all soldered at the print
Will this work at 1s lipo?
http://www.hobbyking.com/hobbyking/s...ar_Servo_.html
Servo's stripped as much possible to and one servo for both ailerons.
One lipo 1s lipo that can deliver 1.3amp constant.
I hope this will be possible I've made the blueprint and the only thing left is make some wood moulds to cut the foam with Hotwire :-)
Anyone got test results with the 15mm rotor from nitro and one 6mm motor? The one one the thunderbolt is the one from BIM so that's different.
When the build has started i'll post pics :-)
Greets out of holland, Robert
robertboxhoorn is offline Find More Posts by robertboxhoorn
Old Nov 11, 2012, 03:06 PM
hanzie is offline
Find More Posts by hanzie
Fear me, I'm a space-duck.
hanzie's Avatar
Joined Nov 2011
Waaaaaaait, you want to go brushed? Are you sure that will provide enough thrust?
As for the wings, I'd go for the foam with maybe a small carbon rod to strengthen things a bit. But seeing the size of this, I'm not even sure if you'll really need any carbon. Good luck with this one!
hanzie is offline Find More Posts by hanzie
Old Nov 11, 2012, 04:00 PM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
can't u go 18 mm?
minimicrorc is offline Find More Posts by minimicrorc
Old Nov 11, 2012, 04:03 PM
Joined Apr 2012
also use a deltang receiver, and acutators or super expesive sub gram servos
Old Nov 11, 2012, 04:05 PM
Flying Dutchman!
Joined Sep 2011
I can go4shure to 18mm 120mm if I want to :-p
No without jokes I've got at school permission to fly in one gym hall 4times the size of one normal gym so I've got space enough to fly and the f 104 is my all the way favourite
There is one 15mm can on my way but what's the difference in performance with 15 and 18? 18 would not fit in my plane so I have to scale it up slightly but. I doesn't start building only cad plans for now that's why I've started this thread :-)
Old Nov 11, 2012, 04:09 PM
Flying Dutchman!
Joined Sep 2011
http://www.lipoly.de/index.php?main_...ucts_id=216895
Something like this I think, only the way to make actuators left :-)
http://www.supermagnete.nl/eng/S-01-01-N
Three of this magnets and 0.3mm coated chopper wire wrap it around one 1.5mm pin and connect and it will work?
Old Nov 12, 2012, 12:39 AM
Joined Apr 2012
use this actuator MicroAct 0.41gm Proportional Actuator, the deltang rx 53, 20mm bahoma lipo, the ares 6mm motor that is used in the nano stick, BIM's shapeways 18mm edf fan, and 18mm fan case for a 6mm motor and 1mm depron, or if u can get it, durobatics
Old Nov 12, 2012, 12:42 AM
Joined Apr 2012
4 flans, u can use this site, it's got a card model that you can adapt for whatever size u ant by printing it out on different sizes http://www.freewebs.com/paragon19/coldwar.htm
Old Nov 12, 2012, 03:07 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Why does he have to go to 18mm? Rob wants a 15mm jet, doesn't he?
My next micro will also be 15mm EDF.
NitroCharged is offline Find More Posts by NitroCharged
Old Nov 12, 2012, 03:33 AM
Chris T is offline
Find More Posts by Chris T
Micro Jet Pilot
Chris T's Avatar
Joined Jul 2005
Nitros fan comes with a stator that should allow to custom wind a single phase bl motor. That one will run with my bl controller. That should give you the thrust you need. I think Nitro is starting a prototype soon
Chris
Chris T is offline Find More Posts by Chris T
Old Nov 12, 2012, 04:08 AM
Flying Dutchman!
Joined Sep 2011
I've ordered the 15mm rotor only I will run in the thrust tube and the motor will be attached at the point that the two thrust tubes come together.
The receifer from deltang that can control 3 actuators and one brushed motor looks fine for this setup and I've got one 6mm motor at home so I think this will be the lightest way to build it
Durabatics foam is not what I wanna use i,ve got one green foam of 0.00000125gr/mm3 and it will let my full airframe weight under the one gr
Chris; do you get one good build example to make actuators?
Thanks for helping, Robert
Old Nov 14, 2012, 06:09 AM
Flying Dutchman!
Joined Sep 2011
Hey guys,
I've got a plan for one single phase motor controller.
This are the components I should use:
H bridge=bd6211-f
Hall sensor=ah3761-wg-7
The only thing left is the pic-12f683 but wich type is what I need?
http://nl.farnell.com/jsp/search/bro...questid=354660
And I've got one drive file to but how do I get it in the chip? It one .lzh file
I've found the magnet that I need in one hxt 500 servo motor the size is 4x5mm and 0.8mm inside if I guess.
So magnets are going to be cheaper and more easy to find for your single phase motor :-)
Best regards
Robert Boxhoorn
Old Nov 16, 2012, 06:30 AM
Flying Dutchman!
Joined Sep 2011
Got my rotor at home today :-)
Man! It's small!!!
http://www.facebook.com/photo.php?fb...size=960%2C717
Don't know or you can see this but this is a picture of it.
Now it's time to start at the jet!
@nitro, any progress yet?
Old Nov 16, 2012, 04:42 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Hi Rob,
yes, I have wound the stator and constructed the fan. She is ready for it's first power up today and yes! she's small alright.
I may need more copper but a slow spool up just to check things out is the plan.
Old Nov 16, 2012, 09:41 PM
Joe Malinchak is offline
Find More Posts by Joe Malinchak
Carbondale PA
Joined Aug 2005
Your 1/72 scale F104 sounds like a great project! The key is to keep it as light as possible.
Nitro,I am really interested in the amount of thrust that you can get with the15mm fan, a single phase brushless motor, and Chris T's new controller!
What is green foam? Did you cut or sand it down, or is it available in thin sheets?
Joe.
Joe Malinchak is offline Find More Posts by Joe Malinchak
New Product Yeah Racing (#F104-014SS) Spring Steel Main Drive Shaft Black for Tamiya F104 Pro edwardchan80 Product Announcements 0 Jul 19, 2012 09:31 PM
Discussion Green air design 50mm EDF F104 Starfighter - where can I get one? redtail Foamy EDFs 5 May 16, 2012 02:16 AM
Discussion Green Air Design Starfigther F104 EDF redtail Foamy EDFs 10 Apr 10, 2012 02:43 AM
Discussion 1/68 Scale BAe Hawk (15mm EDF) Chris T Scratchbuilt Indoor and Micro Models 178 Feb 19, 2009 08:11 AM
