Old Nov 11, 2012, 07:07 AM
sunnybreeze is offline
Find More Posts by sunnybreeze
Joined Oct 2010
New 3.5m Thermal glider composite build
Just wanted to share our clubs new 3.5 meter glider build. It's been a great team effort and we are getting close. The airfoil is Mark Drela's Supra but we changed up the fuse to a saddle mount.
The nose is slip-in to the fuse so we machined CNC molds to create either a electric version or a winch launch version. Bladder system to create all fuse parts. Vert stab is vacuum bagged as well as all wing skins. The wing is full on hollow core using 1.5mm depron for core material.
Full flying horz stab again in molds. Everything pre-painted in the molds.
sunnybreeze is offline Find More Posts by sunnybreeze
Old Nov 11, 2012, 07:10 AM
Joined Oct 2010
Just a few more pictures.
The lower center panel of the wing was laided up last night for the first tiime. You an see the 3k CF tow used for spar caps and drags in the last picture. Kelvar servo reinforcement for the flap. Will demold tomorrow and post results.
The first fuse and vert and horz stabs done!
Old Nov 11, 2012, 02:30 PM
timbuck is online now
Find More Posts by timbuck
Nothing is easy
timbuck's Avatar
gold coast australia
Joined Aug 2008
Nice project SB....
Tim
timbuck is online now Find More Posts by timbuck
Old Nov 14, 2012, 03:19 PM
eolos30 is offline
Find More Posts by eolos30
Joined Jun 2007
After waxing, what kind of color is more easy, to use?
Andreas
eolos30 is offline Find More Posts by eolos30
Old Nov 15, 2012, 07:18 AM
Joined Oct 2010
Pre waxed and then sprayed on PVA. Let dry and spray on any Enamal paint you want.
Discussion Dodger EP 3 Channel Thermal Glider 1980mm (ARF) BP1011 Thermal 14 Apr 01, 2014 06:05 PM
Build Log Build log PIK-12 Gabriel, 1:3,2 (5m) tuootal Scale Sailplanes 18 Jun 11, 2012 03:47 PM
Wanted Any Polyhedral Thermal Wing 3.1-3.5m jrbackus Aircraft - Sailplanes (FS/W) 3 May 17, 2010 10:28 AM
Question Good scale thermal glider in 2.5m range? Any? Nikolash Thermal 3 Sep 10, 2008 05:45 AM
