Old Nov 10, 2012, 07:56 PM
wingloada is offline
Find More Posts by wingloada
wingloada's Avatar
United States, MD, Lutherville-Timonium
Joined Apr 2012
2.4 Rx for 3M RES
I'm using a JR 8103 radio with a Spektrum 2.4 Tx module installed. I'm building a 3M RES woodie glider and I am wondering what the group wisdom is for full-range 2.4 gHz receivers for such a plane. Make? Model? Cost? Single Rx? Satellite Rx?
W
wingloada is offline Find More Posts by wingloada
Old Nov 12, 2012, 09:24 AM
Lou_p is offline
Find More Posts by Lou_p
United States, MD, Baltimore
Joined Oct 2011
I have a AR600 full range, same as the stock radian which works fine. You could also go Orange with Sat. receiver for less money. I have used both with no problems.
Lou
Lou_p is offline Find More Posts by Lou_p
Old Nov 12, 2012, 12:35 PM
wingloada's Avatar
Joined Apr 2012
Thanks, Lou_p. I have been using the Orange receivers on smaller planes and have satellite receivers for them. I just didn't know if since they are so inexpensive that they are reliable for these larger, more costly planes. If so, that would be great. If not, I'll look into the Spektrum line.
W
Discussion 3m res/ref choices Andrew Smith Sailplane Talk 14 May 29, 2012 09:04 PM
Discussion Looking for info on 3M RES sailplane called Salsa hog2soar Sailplane Talk 3 May 06, 2012 03:05 PM
Question High Performance 3m REF or RES E-Sailplane Kits? Piper J3 Electric Sailplanes 4 Mar 31, 2012 10:44 AM
Discussion help with RES electric choice 3m or bigger raggedraider Electric Sailplanes 21 Mar 25, 2012 10:02 PM
Found Looking for a good 2.5 - 3M RES plane mdiley Aircraft - Sailplanes (FS/W) 0 Dec 13, 2005 10:56 PM
