Old Nov 10, 2012, 07:24 PM
CPATRICK is offline
Find More Posts by CPATRICK
CPATRICK's Avatar
PAGOSA SPRINGS,CO
Joined Apr 2004
85in Taylorcraft to electric?
Hey guys, want to convert origingal 85in Taylorcraft to electric using either tacon 160 or 110. Want to use either 6s or 8s to convert from Saito 180. I fly at 7600ft so will be using a fairly large prop for bite. The plane weighs 14lbs now, so don't see saving much weigh with electric setup, but gotta go electric...Any suggestions would be welcome if you have actual knowlege of using these two motors...Be nice! Pat
CPATRICK is offline Find More Posts by CPATRICK
Old Nov 11, 2012, 10:11 PM
blvdbuzzard is offline
Find More Posts by blvdbuzzard
The high desert of Southern California
Joined Jul 2002
Using the Tacon 110, 8s 6000mah battery, 20X6 APC "E" prop. Gives you about 244 ounces, 15 pounds of thrust. If you bump the prop up to 20X7 you get just over 17 pounds of thrust but you are over the rating of the motor by 5 amps.
This is the free online calc program I used.
http://www.s4a.ch/eflight/motorcalc_e.htm
Buzz.
blvdbuzzard is offline Find More Posts by blvdbuzzard
Last edited by blvdbuzzard; Nov 11, 2012 at 10:19 PM. Reason: If I could only spell
Old Nov 12, 2012, 10:03 PM
CPATRICK is offline
CPATRICK's Avatar
PAGOSA SPRINGS,CO
Joined Apr 2004
Wow!,I'm impressed, I couldn't even find the motor in the program. Could the 160 motor be used on 8s? I'm going to use ice 100 cause I've got two. Got a couple Turnigy 400kv motors turning 18/6/10 wood props on 6s very well but on a much lighter plane. Looking for scale IMAC performance on 8s max. Pat
Old Nov 13, 2012, 09:16 PM
Joined Jul 2002
An easy way to test it, use the eflite motors from the drop down list.
Well it says the 160, swinging an APC 22X10, 8s well give around 334 ounces of thrust, 16 pounds at 2077 watts. It is just a touch over limit. Specs say 78 amps is the limit and this is 78.14 amps.
Buzz.
Old Nov 13, 2012, 10:03 PM
CPATRICK is offline
CPATRICK's Avatar
PAGOSA SPRINGS,CO
Joined Apr 2004
Buzz.
Hey buzz, thanks for the help! That should give me about 140 watts/lb. Pat
Old Nov 15, 2012, 02:18 AM
Ldm is offline
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
no disrespect but the ecal your using is wrong , its does not work nor calculate correctly.
I have tested it in the past with proven motors , props etc and hit my field numbers into the system and there totally wrong .
If you can seek out a rcu member names Kahlog , no one is better at conversions then him .
He is in the glow to electric forum and in many of the post on the "Platt Dora Purchased to Bash" , he will give you exact suggestions that are dead on
Ldm is offline Find More Posts by Ldm
Yippee! Hangar 9 Taylorcraft electric conversion motor12 Giant Electric Planes 5 Jun 22, 2012 12:23 PM
Discussion E-Flite Taylorcraft 450 ARF Kit and High Power E-Flite electrical components $300 Philscho Hot Online Deals 1 Mar 02, 2012 08:11 PM
Video 3D HobbyShop 85in Katana flyinghamiltons Electric Plane Talk 6 Feb 20, 2008 10:49 AM
Taylorcraft for electric datsun74 Parkflyers 17 Feb 01, 2005 04:42 PM
KMP 69" Taylorcraft Electric conversion tim61 Sport Planes 1 Oct 27, 2004 09:25 AM
