Espritmodel.com Heli Air
This thread is privately moderated by Razors edge 29, who may elect to delete unwanted replies.
Old Nov 10, 2012, 06:49 PM
R.C. Aviation Fanatic
Razors edge 29's Avatar
Canada
Joined Aug 2009
Estes Rubber Band Condor gets powered flght
Today at the LHS, I bought a rubber band powered glider called the Estes Condor. I believe this is part of a new line up as it is foam, and not balsa. The wing, hstad and vstab seem to be made out of Depron, while the main fuse is conpressed EPP I think.
See link below
http://www.estesrockets.com/004014-r...nd-foam-glider
I bough this with the intention of making it a tractor set up, but then realized I dot have any small enough props to use with motors I had on hand.
So, I made it a top mount pusher.
It uses a Champ brick, mounted upside down under wing through fuselage, and a MCPX tail motor and rotor blade. I used a scrap piece of Depron to make top pusher mount. I ended up running the elevator linkage through the fuse. The brick is mounted off center to allow rudder/aileron servo to be outside fuse. I cut down the stock main landing gear and made it a lot closer to ground. I also fashioned up a tail wheel which is steerable via the rudder.
I went nuts with some sharpies and stock stickers. This conversion ended up with a weight w/o a lipo of just under 21 grams with landing gear.The main landing gear is removable and weights 1.3 gram.
I had it out earlier this evening and it did fly, but was quite pitch sensitive and thus I have since adjusted the motor angle to give down thrust.
She has lots of dihedrel, and under camber which provides great lift. I think it may even be able to rog in a gym for take off. The MCPX tail powers it nicely.
I will try and add videos if I can.
thanks for reading.
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Nov 15, 2012, 02:41 PM
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
thanks for reading.
very nice! I might just do this. vid would be cool.
My first plane was from wal-mart and it was the estes twin blue angels, so I sorta have a special thing for them. I wished they would of rethought things and stopped trying to compete with folks like air hogs...they would of done well with selling just airframes....IMO, they had some really nice airframes.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Nov 15, 2012, 08:04 PM
Canada
Joined Aug 2009
Yeah.
I've been eyeing up a new Estes planes
Old Nov 21, 2012, 01:09 AM
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
Glad I saw your blog link, I've got an ar6400 sitting on the shelf looking for a home, this could be the inspiration I need to do something with it. Subscribed.
eltreato is offline Find More Posts by eltreato
Old Nov 21, 2012, 08:07 AM
Canada
Joined Aug 2009
Hey
There are lots of good homes, for an AR6400
Make a mini 3D plank
Old Nov 21, 2012, 03:28 PM
eltreato's Avatar
Joined Oct 2011
That was actually my first choice, though it means I'll have to drop some $$ on a couple spma2000Ls, plus my brick isn't a long throw. I also saw a vid on youtube of a guy's flying wing ar6400 that could be fun too.
Old Nov 21, 2012, 06:14 PM
Canada
Joined Aug 2009
Yeah, flying wings are fun for sure
Check out micro stingray thread in the indoor and micro thread
It's fun but quick lol
Old Nov 21, 2012, 06:16 PM
Canada
Joined Aug 2009
This, thread here
http://www.rcgroups.com/forums/showt...1761053&page=5
Old Nov 21, 2012, 06:22 PM
eltreato's Avatar
Joined Oct 2011
that is awesome, thanks!
Old Nov 21, 2012, 11:11 PM
Canada
Joined Aug 2009
no worries
Sold 4x Vintage Micro Comet balsa kits $60 shipped - Rubber Band power BedEvil Aircraft - Electric - Micro & Indoor Airplanes 2 Jun 24, 2012 09:42 AM
Help! Covering a balsa wood rubber band powered model chrisrussell Free Flight 18 Jun 20, 2012 11:46 PM
Discussion Estes Rubber Band Power Flying Model Plane's aeronaught Free Flight 14 Aug 22, 2009 10:33 PM
Where can I get crystal rubber bands? flyingflipper Hitec/Multiplex USA 2 Oct 31, 2005 12:01 PM
Question dangit!!! Where to get catapult rubber bands? youngster Free Flight 4 Apr 15, 2005 02:22 PM
