Old Nov 10, 2012, 06:26 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
"crab" style quad
I am on my 7th frame design and each time I have been adding and taking away bits. This time I have been inspired by a number of posts to create a simple and versatile frame that works as well for acrobatics as it could for FPV without any unnecessary bits. A few things in particular inspired this design, one is that props can overlap, as long as it's not too much and CW and CCW balanced it should not affect flight and someone building a FPV quad by taking a + hex and removing the front and rear arms.
To that end I created an adjustable birch 1/8 inch ply FC mounting plate and use 2x alu c-channel arms that end up at different heights. The whole thing is held together by 5 bolts and a lot of zip ties.
Just tried "crab mode" this evening and it flew very well, probably could use some tuning, but it's ready to accept the video equipment.
Passing along the pictures as an inspiration to others.
brontide is offline Find More Posts by brontide
Old Nov 12, 2012, 07:04 PM
brontide is offline
Joined Sep 2012
Update: video pod created, tested, and reworked. Still got some vibes, but can't rule out my mangy props until a fresh shipment comes in. Still need to give the video plate a coat of paint. Switching between angles is about a 20 minute ordeal, will probably get it down to 15 with some practice.
Old Nov 12, 2012, 07:37 PM
Matt Chester is offline
Find More Posts by Matt Chester
Matt Chester's Avatar
Newnan, GA
Joined Oct 2002
Can you get some video of it from LOS and Onboard to share? I'd like to see that for sure. I like your ideas here and the simplicity of construction.
Matt Chester is offline Find More Posts by Matt Chester
Old Nov 12, 2012, 07:43 PM
overmyhead is offline
Find More Posts by overmyhead
United States, FL, Bradenton
Joined Jan 2012
When you use the wire ties to mount the props to the motor bells is that to allow the ties to breakaway on ground impact and save the props from damage?
If so does it work?
Wonder if maybe they are causing your vibrations?
overmyhead is offline Find More Posts by overmyhead
Old Nov 12, 2012, 08:03 PM
brontide is offline
Joined Sep 2012
Once it's tuned up some on board video should not be a problem, from the ground will be a little more difficult since ill have to find a willing helper sucker.
The zip ties do work well presume they are put on correctly ( tied on the trailing edge ) and they will sometimes break on crash rather than the props. I have not noticed any issue with balance because of the ties. I also have to be careful that they are good quality, had a few crashes before I recognized that one batch of ties from HD was crap and stopped using them for structural items,
Here is the maiden, untuned, uncut video from the pod.
Practice (2 min 33 sec)
Tomorrow looks like a washout, but maybe later in the week I can get some real flights in.
Old Nov 13, 2012, 08:24 AM
brontide is offline
Joined Sep 2012
Picture showing blade separation from the side. When its in traditional X configuration there is no overlap in the blades. I will confirm when the weather breaks that I can do full yaw sticks without blade strike.
Old Nov 13, 2012, 11:03 AM
brontide is offline
Joined Sep 2012
Sorry for the short video, but I had been through 4, or so, iterations before hitting on this alteration. Even with my crappy props I get vibe free video downloads! Basically going soft was the wrong way, i tightened up everything on the pod and then loosened the pod from the FC plate in order to isolate the video and battery. Photos to follow.
Mount tweaking (1 min 5 sec)
Old Nov 13, 2012, 11:33 AM
brontide is offline
Joined Sep 2012
Updated shots of the mount. Can only post 1 pic per post on the iPad.
Old Nov 13, 2012, 11:34 AM
brontide is offline
Joined Sep 2012
Even with props that look like this!!
Old Nov 13, 2012, 02:22 PM
brontide is offline
Joined Sep 2012
Longer video, still need to play with my motor mixing. Turning down the pitch made it less twitchy, but the wind nearly took me into some lines. Need some more height dampening as well.
Tooling around (11 min 15 sec)
Old Nov 15, 2012, 02:35 PM
brontide is offline
Joined Sep 2012
Had so much fun with it in traditional X mode I switched back for a few days. Here is a short video LOS in my very small front yard.
Crab Los (1 min 32 sec)
For Sale HT-450 Quad Frame Kit (CAMO) with Extra Center plates FPV style jetbootz Aircraft - Electric - Multirotor (FS/W) 1 Nov 22, 2012 08:20 PM
For Sale HT-450 Quad Frame Kit (CAMO) with Extra Center plates FPV style jetbootz FPV Equipment (FS/W) 0 Oct 08, 2012 08:25 AM
Sold Bambucopter Crab 25 Mini Quad RX Ready bobepine Aircraft - Electric - Multirotor (FS/W) 4 Sep 25, 2012 10:37 PM
For Sale G10 FPV/AP Boom Style Quad Frames. tosjduenfs Aircraft - Electric - Multirotor (FS/W) 9 Jun 12, 2012 05:14 PM
Build Log MSQ Build (Mini Spider Quad) dacat style actionplus Multirotor Talk 0 Apr 30, 2012 05:20 PM
