Old Nov 10, 2012, 05:59 PM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Question
Pylon construction.
3mm ply/3mm liteply+glass?
Another bit of advice concerning the pylons mentioned in the concave/convex planking thread.
I cut some trial formers out of liteply just to see if my "head cad"design would work,see the pics.Looks as though it will be ok.
I'm wondering now what would be the best material to make these from.
I'm thinking at the moment,3mm ply above the hinge line.6 of these in each of 2 pylons would carry the weight of a 2.2m flying wing.(foam)
Would glassed liteply be as strong as standard ply?
What about a strip of carbon run up the leg from the axle bearer ?
The outer surface-1/16 balsa or thin ply,maybe a layer of glass to give a bit more strength.
Any ideas/suggestions would be welcome.
Stuart
Stuart A is offline Find More Posts by Stuart A
Old Nov 11, 2012, 05:04 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
If your formers shown in the pictures are made from liteply I'd say that it's likely that they are strong enough for general flight and landing loads. But it's hard to suggest one way or the other without knowing what you're building.
BMatthews is offline Find More Posts by BMatthews
Old Nov 11, 2012, 05:48 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
This is the beast.It's a long term side project,I'm not aiming for scale-'cos there is none
The airframe is adapted from the Ho VII,the rest is make up as I go along.
Stuart
Old Nov 11, 2012, 05:58 PM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Link wouldn't work.This is a pic one of the guys found,appears to be a works drawing
Stuart
Old Nov 12, 2012, 12:41 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Oh yeah, that thing...
I'd suggest that you're barking up the wrong tree by trying to use wood to support the axles. Instead solder up a cage of music wire or even fabricate a long U channel arrangement of aluminium sheet with lightening cutouts so it's stiff but fairly light. These two plates for each of the landing gear arrangements can act as both the support for the landing gear as well as attachment points for lightly fabricated side panels. And at the lower end the plates would give you attachment points for the hinged lower doors. All in all such a setup would be decently light. And more importantly it would be THIN so the overall fairing isn't much wider than what the scale size would have been.
Question Speed 400 pylon racer wing composite construction- Complete! invertmast Composites Fabrication 6 Sep 24, 2012 12:48 PM
Help! Aircraft Body, Wing Construction help! goldcoastperson Beginner Training Area (Aircraft-Electric) 5 Feb 26, 2012 10:08 PM
AZ-Shrike Bluecor Fan Fold Pylon Racer - Plans & Construction AZ_Astro Foamies (Kits) 504 Feb 16, 2004 11:26 PM
