Old Nov 10, 2012, 03:43 PM
HotAir2 is offline
Find More Posts by HotAir2
Neal
Christchurch, NZ
Joined Nov 2004
Futaba S.Bus in 6m glider
Hi there
I want to use the S.Bus servos and wiring, but I don't see any extension cables longer than 1m. To get from the elevator to the Rx alone is 2.2m.
What are my options? Can I simply chain them together? Can I make my own cables? Is there a thrid party cable option?
Thanks, Neal
HotAir2 is offline Find More Posts by HotAir2
Old Nov 10, 2012, 03:51 PM
wakumann is offline
Find More Posts by wakumann
wakumann's Avatar
Canada
Joined Jul 2003
Originally Posted by HotAir2 View Post
Hi there
Thanks, Neal
Neal
is your question real
People who fly big scalies mostly know how to solder their own servo wiring.
Cheers
Thomas
wakumann is offline Find More Posts by wakumann
Old Nov 10, 2012, 03:58 PM
HotAir2 is offline
Neal
Christchurch, NZ
Joined Nov 2004
Heehee, fair enough. I currently fly a scratch built 5m and custom made all my wiring loom, soldered every little connection.
HowNotToLand5mScale (1 min 43 sec)
Is the S.Bus wiring the same? Are they just standard plugs and cables?
Is there a wire length limit? I can't find much info/specifications.
If I interpret your answer correctly, then all I need to do is make my own standard servo cables, and buy some of their 4 way hubs.
Thanks, Neal
Old Nov 12, 2012, 02:29 PM
Skaluf is offline
Find More Posts by Skaluf
Skaluf's Avatar
Sadorus, IL
Joined Mar 2004
There is no magic to the S.Bus wiring. The fewer the connections the better so I would recommend making up your own leads if that's something you are comfortable in doing. For a 2+ meter run you will want to consider a heavier than standard wire gauge and a battery system large enough to handle the loads.
One advantage to S.Bus is that a battery can be inserted anywhere along the wiring. This means you could add at battery closer to the servos in the tail of your sailplane, if you have access to that area and the weight would not be prohibitive.
Steve
Skaluf is offline Find More Posts by Skaluf
Site Sponsor
Old Nov 12, 2012, 03:28 PM
Mac37 is offline
Find More Posts by Mac37
Modesto CA
Joined Nov 2009
HotAir2:
You can daisy chain the extensions together. If you decide to make your own remember that the power wires for SBus are 18 Gauge.
Third party cables are available from Robbi and Emcotec. The longest is 1M. You can order from John at HKM USA.
Mac
Mac37 is offline Find More Posts by Mac37
Old Nov 12, 2012, 03:31 PM
Mac37 is offline
Modesto CA
Joined Nov 2009
Here is a link.
http://shop.rc-electronic.com/e-vend...&c=2406&p=2406
Old Nov 12, 2012, 03:32 PM
AirBornOne is offline
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
Hi there
Thanks, Neal
Been wondering the same myself Neal.
An additional consideration for me was the viability to use both S.Bus and non-S.Bus servos.
It appears that you either pay for the difference in servo costs or the adapters required to operate standard servos.
Steve,do you have any documentation to go with your information?
The wire gage issue is simple enough but data systems can have specific requirements for EOL (end of line) resistors,wire grade (strands & shields),and even connectors to avoid 'harmonic reflections',drops in signal level and plain old voltage and or capacitance issues. Any or all of which could be disastrous to an airborne model.
Thanks for any info.
Skies
Jay
AirBornOne is offline Find More Posts by AirBornOne
Old Nov 12, 2012, 05:28 PM
tewatson is offline
Find More Posts by tewatson
Team JR Air
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Ouch on the landing...
Tom
tewatson is offline Find More Posts by tewatson
Discussion Any successful ZYX-S installation with Futaba S-Bus? lordsirob Mini Helis 4 Mar 18, 2013 12:45 PM
Discussion Futaba S.Bus - Can I use a simple Y extension to expand the bus? jackheli Radios 5 Jun 12, 2012 11:12 AM
Found Futaba s-Bus 3 channel receiver. livinma1 Aircraft - General - Radio Equipment (FS/W) 2 Jun 08, 2012 01:17 PM
Question S.bus and servo question futaba R6208SB Chow Radios 0 May 23, 2012 01:50 PM
Sold R6203SBE - Futaba FASST S.Bus receiver xatled99 Aircraft - General - Radio Equipment (FS/W) 1 Mar 09, 2012 01:46 PM
