Old Nov 10, 2012, 04:29 PM
Jmat is offline
Find More Posts by Jmat
Joined Nov 2012
Help!
tail rotor not spinning
the model is BR6098 X-MAX the problem is when i went to fly it I notice the tail rotor wasent spinning. I check the motor in the tail section and the motor is good but now I got no clue where to start looking as to where the problem could be. please give me a direction to go. thanks P.S its brand new out of the box. cant return it have to fix it.
Jmat is offline Find More Posts by Jmat
Old Nov 10, 2012, 06:17 PM
RFDelie is offline
Find More Posts by RFDelie
Get to the choppa!
RFDelie's Avatar
United States, PA, Pittsburgh
Joined Sep 2012
How do you know the motor is good? What method are you using to test it?
RFDelie is offline Find More Posts by RFDelie
Old Nov 10, 2012, 06:41 PM
xtian3188 is offline
Find More Posts by xtian3188
Tuguegarao City Philippines
xtian3188's Avatar
Joined Sep 2012
disconnect the tail motor and apply voltage to it. if it did not spin, there's your problem. if it spins, check if you have voltage on the tail motor port on the pcb. if there's no voltage, there's your problem. if there's voltage, check the wire from the pcb to the motor if there is continuity along its length. if there's no continuity, rewire it.
dont forget to power up your heli and disconnect your main motors.
xtian3188 is offline Find More Posts by xtian3188
Old Nov 10, 2012, 06:47 PM
jetmaven is online now
Find More Posts by jetmaven
I had the same issue with a double horse 9116 , it was a new circuit board that fixed the problem.
jetmaven is online now Find More Posts by jetmaven
Old Nov 10, 2012, 11:23 PM
ASTREA1 is offline
Find More Posts by ASTREA1
A&P in training
ASTREA1's Avatar
United States, CA, Vacaville
Joined Dec 2008
Buy a helicopter with a belt driven tail?
ASTREA1 is offline Find More Posts by ASTREA1
Old Nov 11, 2012, 05:41 AM
Jmat is offline
Joined Nov 2012
in used a C battery to test and the motor is good. I check the wires from the circit board and it is good. i beleve its the circite board.
Old Nov 11, 2012, 05:52 AM
Jmat is offline
Joined Nov 2012
I need a new circite board but where do i get one.I looked on the internet but cant find the model i need. and how do i know it will match my transmitter. dont it has to match. i know on my futaba radio it has to match to work
this is my first heli does the tail rotor spin the moment the main rotor starts spinning? i know stupit ?
Old Nov 11, 2012, 06:57 AM
karlik is offline
Find More Posts by karlik
Closed Account
Joined Apr 2010
In the beginning of this video there are at least 3 times the tail stops spinning so it looks like it may not spin if the elevator is in neutral???
This appears to be a 3.5 channel? Finding parts may be near impossible. I know you don't want to hear this, but it's really a toy grade heli. I honestly wouldn't spend any money on repairs, but that's just me. My advice, for whatever it's worth, is to get one of the small blade helis, you'll get a lot more for your money.
mijn speelgoed op late leefttijd ( X-MAX 6098 3,5 channels ) (1 min 43 sec)
karlik is offline Find More Posts by karlik
Old Nov 11, 2012, 08:37 AM
Jmat is offline
Joined Nov 2012
http://www.youtube.com/watch?v=QNGAPvWpnTI
ok thanks for the advice
Old Nov 12, 2012, 04:04 AM
Jmat is offline
Joined Nov 2012
thanks again for the advice. you were right it aint worth much it just goes basicly up and down. i would like to get one that i can put my 6 channel futaba radio in do you have any suggestions as to a type of heli to look in to or brand thanks.
Old Nov 12, 2012, 05:48 AM
karlik is offline
Closed Account
Joined Apr 2010
I like futaba myself - my first radio was a attack 4 way back before they had gold stickers on the back, and my current fixed wing radio is a conquest 6.
If your 6 channel has all the swash mixing heli stuff avail you'll be able to use it on a CP (collective pitch) heli like a 450, but it doesn't sound like you're ready for that yet. It sounds like your new to heli so you'll probably want some experience on a trainer first?
The most popular small trainer helis are made by Blade, and they use spectrum radios. I'm going to need a new heli radio soon and I'm trying to decide if I want to stick with futaba or be like everyone else and use a spectrum like a dx6 or dx7.
You won't get many answers in this thread cause it's a little old and the title is about tail motors so start a new thread and ask the same questions - like any trainers that will use a futaba radio or what are the other best options. A new thread will get you answers and good advice from balr and jasmine and a some of the other helpful people.
I will suggest what I know they'll suggest in the new thread - get a good simulator like phoenix or realflight. It'll speed the learning process a lot and save you a ton of money on crashes and repairs.
Old Nov 12, 2012, 06:19 PM
Jmat is offline
Joined Nov 2012
thanks a bunch. i will start a new thread and yes this is my first heli i knew it was a toy when i got it. but now in ready to move up a couple nitches
Help! Tail rotor not spinning vengeance111 Electric Heli Talk 13 May 08, 2012 01:38 PM
Discussion Syma s107 tail rotor not spinning mediamaker Coaxial Helicopters 3 Nov 05, 2010 12:44 PM
Help! Tail rotor not spinning on start up. cb100 lanketer Micro Helis 10 Jun 22, 2010 04:22 PM
Discussion New honey bee fp tail rotor not spinning bjfederi Micro Helis 6 Dec 25, 2009 11:43 PM
Help! Tail rotor not spinning well Great Fun Micro Ready-to-Fly 0 Sep 28, 2007 12:51 PM
