Old Nov 10, 2012, 10:05 AM
Zahnarzt is offline
Find More Posts by Zahnarzt
Earth's Mightiest Hero, KC9TBO
Zahnarzt's Avatar
United States, IL, Lemont
Joined Apr 2010
Question
ESC, Inductance, and FPV Gear
I understand that inductance is an issue with extended battery-to-ESC connections and that a series of capacitors installed in line to the ESC offers a solution up to a point. I have a typical EasyStar FPV setup and am wondering if I may have an unrealized inductance issue. The flight battery connects to a small extension (approximately 6 inches) that connects to an Eagletree Systems eLogger V4. The ESC then connects to the eLogger. Does it matter if I have the eLogger between the battery extension and the ESC as far as inductance issues?
Thanks for your help!
Zahnarzt is offline Find More Posts by Zahnarzt
Old Nov 10, 2012, 10:59 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Anything that you put in-between the battery and ESC will increase the voltage ripple at the ESC. You would have to know the internal resistance of the eLogger and connectors and the maximum current to do the calculations.
What ESC’s do you have. If you have ICE ESC’s they will record the ripple voltage in flight.
RC Man is online now Find More Posts by RC Man
Old Nov 10, 2012, 11:15 AM
Zahnarzt is offline
Zahnarzt's Avatar
Joined Apr 2010
Thanks for your quick response. I do have a Phoenix ICE Lite 75A ESC. Just ordered a Castle Link so I can check out the ripple voltage. Should be interesting. Thanks again!
Old Nov 10, 2012, 07:01 PM
United States
Joined Feb 2001
Ripple voltage up to 10% of battery voltage (data logger numbers) is ok and wonít harm the ESC. Itís excellent if you can get it down to 5%.
Question ESC, Inductance, and FPV Gear Zahnarzt Power Systems 0 Nov 03, 2012 08:27 PM
Discussion Do I need worry about inducted voltages when adding LED's to ESC battery? Deadstick 8409 Power Systems 3 Sep 08, 2012 10:15 PM
Discussion Tips and trick for 450-sized helicopter, fpv landing and fpv gear emerge FPV Talk 0 May 29, 2012 10:52 AM
Question My motor is an induction oven! billcat Electric Motor Design and Construction 13 Apr 12, 2012 09:42 AM
Found Looking for fpv gear, will trade a t-rex500 and a t-rex550 for fpv gear FRANCISCO36 FPV Equipment (FS/W) 3 Sep 24, 2011 10:03 AM
