Espritmodel.com Heli Air
Old Dec 02, 2012, 09:51 AM
Air Assassin
RogueAce's Avatar
United States, FL, Pompano Beach
Joined Oct 2012
Great flight !!
RogueAce is offline Find More Posts by RogueAce
Old Jan 07, 2013, 05:13 PM
United States, CA, Aptos
Joined Sep 2012
I have just completed my Schumate F22 conversion to EDF. I'm using twin 65 mm fans for power.
The fans came out of a friends Dynam A-10 model. All up weight on the plane is 24 oz and it balances perfectly at the 3' mark per the original design.
Two photos. Completed plane and second with Fans mounted in tunnels
Poporbit is offline Find More Posts by Poporbit
Old Jan 15, 2013, 10:49 PM
Joined Sep 2012
F22 maiden flight was quite successful. The battery overheated causing power loss and a quick return to landing. Slight damage to the nose section resulted. Easy repair to follow.
The fans generate less thrust in the F22 than the A10 they came from. Reason, the inlet area is insufficient. I'll need to build a larger model to scale the inlets properly. I suspect a 115% model will accomplish the task but I well run calc's first to make sure. This will reduce the strain on the battery also.
I enjoyed the flight but expected a higher speed from this configuration. The A10 was faster.
Build Log whalleyB0Y's First Build (HK F22 Raptor Twin 70mm EDF) WhalleyB0Y Electric Ducted Fan Jet Talk 311 Jun 16, 2013 06:40 PM
Discussion schumate f15 118% 70mm stingeragents Scratchbuilt EDFs 46 Dec 02, 2012 10:28 AM
Sold 64mm edf w/motor 2-70mm edf's, 70mm edf motor Dave Barrow Aircraft - Electric - Jets (FS/W) 0 Aug 10, 2012 07:58 PM
Help! Exceed 70mm EDF F22 Raptor.......... Binome Foamy EDFs 0 Mar 27, 2009 06:28 PM
Discussion Exceed 70mm EDF F22 Raptor.......... A Question Binome Foamy EDFs 2 Mar 14, 2009 06:21 PM
