Old Nov 10, 2012, 12:49 AM
winndaddy is offline
Find More Posts by winndaddy
My poor poor planes.
winndaddy's Avatar
United States, LA, Lake Charles
Joined May 2012
Align T-Rex 500esp Battery
I just purchased my first T-Rex 500. Whats the Optimum battery size for this heli? I've seen 6s 2600mah 45c for it all the way up to 3300mah. I don't want to buy something and then I finally get it and it dosen't fit, you know.
winndaddy is offline Find More Posts by winndaddy
Old Nov 10, 2012, 10:22 AM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
2650s were the perfect balance on mine.
Xrayted is offline Find More Posts by Xrayted
Old Nov 10, 2012, 10:50 AM
Dejavu*Xion is offline
Find More Posts by Dejavu*Xion
Need More PURPLE !!
Dejavu*Xion's Avatar
United States, NV, Las Vegas
Joined Aug 2012
For my 500 I run both 2800 And 3000mah. Depending on what 500 you have, If you opt for 3300 you may have to do a mod. I would stick with 3000mah or under. A great battery that i have found that never gets talked about are the "tiger" 2800mah 35c batteries you can find on e-bay..These batteries are awsome !!
Dejavu*Xion is offline Find More Posts by Dejavu*Xion
Old Nov 10, 2012, 01:56 PM
winndaddy's Avatar
Joined May 2012
Oops, it took so long for me to get a answer I went ahead and ordered a couple of 3300mah 30c packs. The size is 137mm x 45mm x 35mm, and they weight 478g ( atleast that the specs advertised). From the looks of it they might fit. They were out of 40c. I would of rathered a higher c rating, but oh well. Its the GForce Elite series. They're cheap, and I've had good luck with them in the past.
What do y'all think?
Old Nov 10, 2012, 07:34 PM
Need More PURPLE !!
Joined Aug 2012
What 500 do you have ? Some 500's will take 3300mah wher as others wont without a frame mod. 30c will be fine.
Old Nov 10, 2012, 07:43 PM
winndaddy's Avatar
Joined May 2012
[QUOTE=Dejavu*Xion;23236729]What 500 do you have ? Some 500's will take 3300mah wher as others wont without a frame mod. 30c will be
The T-Rex 500 esp. Do you or anyone have a link to the battery tray mod just in case?
Old Nov 10, 2012, 08:45 PM
Need More PURPLE !!
Joined Aug 2012
I'm pretty sure the align esp would need a mod done in order to take a 3300mah battery. However before you do. Track down user Mhills in the large heli forum. He will know for a fact.
Here is a link showing how the mod is done. Its very simple, the only tool you need is a dremil with a cutting disk. http://www.mycoolheli.com/500mods/TrayMod/index.html
I had an hk500, And just running a 3000mah battery the mod was necessary. Nice thing about running a 3300mah battery is you get an extra min. of flight time.
Old Nov 10, 2012, 08:54 PM
Need More PURPLE !!
Joined Aug 2012
Here is also a very good thread to read thru on the subject. http://www.helifreak.com/showthread.php?t=134045
Take note of post #4 for a good visual upon completion.
Old Nov 11, 2012, 10:51 PM
winndaddy's Avatar
Joined May 2012
Well guys, thanks for all the info. Its was much appreciated as always. I decided to cancel my order, take the safe route, and go with a few 2600 packs. Its a new heli and I just don't feel good about cutting into her just yet.
Thanks, Winn
Old Nov 12, 2012, 12:12 PM
Need More PURPLE !!
Joined Aug 2012
Can't say I blame ya....cutting into one does seem harsh.
Old Nov 25, 2012, 11:00 PM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
winndadday— FWIW I use dual hyperion 2200 3s wired to make 6s and it flies well though slightly tail heavy. I also use Zippy 3000 mah 6s and it balances about right with no frame mod. In either configuration mild aerobatics are no problem.
Incidentally, my 500 has the stock Align smooth can 1600 kv motor; when I fly 6 minutes all batteries come down with power left to spare. I am pretty sure I'll get 7 minutes, as I gradually set the Tx for longer flights.
P.S.: 6.5 minutes is no problem for the 2200's or the 3000's!
zen@lanset.com is offline Find More Posts by zen@lanset.com
Old Oct 09, 2015, 08:21 PM
silasclaphan is offline
Find More Posts by silasclaphan
United States, MO, Maryville
Joined Sep 2013
Wow! I use 3300and did no drilling...no cutting. Just unscrewed top2 trey screws...and pushed top of trey down into battery strap slots..screwed back in...done.
silasclaphan is offline Find More Posts by silasclaphan
Old Oct 12, 2015, 08:25 PM
mrfirkin is offline
Find More Posts by mrfirkin
Oh, Ho, Ho, It's Magic!
mrfirkin's Avatar
Australia, VIC, Southbank
Joined Apr 2004
I use a couple of 6S 3700mah 40C in my stock Trex 500 E
Tad heavy but they fit with no mods (just) and give me around 8 minutes of scale type flying and hovering.
mrfirkin is offline Find More Posts by mrfirkin
Old Oct 13, 2015, 02:50 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I normally use 2600mAh packs, but a while back I moved my canopy mounts about 1/2" further forward so I could fit a 3300mAh pack made up of two 3S packs I had for another model. The mod also spreads the canopy sides slightly, which solves the problem on some 500s where the canopy fouls the main gear if not installed exactly straight.
abenn is offline Find More Posts by abenn
For Sale Complete Align FBL T-Rex 500ESP Airframe w/Upgrades & KDE/Neu 1708/1Y Motor helinut4ever Aircraft - Electric - Helis (FS/W) 0 Oct 07, 2012 12:31 PM
For Sale Bind-N-Fly FBL T-Rex 500ESP helinut4ever Aircraft - Electric - Helis (FS/W) 2 Apr 12, 2012 10:11 AM
For Sale Bind-N-Fly FBL T-Rex 500ESP helinut4ever Aircraft - Electric - Helis (FS/W) 0 Apr 07, 2012 07:31 AM
For Sale Assembled But Never Flown Align FBL T-Rex 500ESP helinut4ever Aircraft - Electric - Helis (FS/W) 0 Jan 14, 2012 08:55 PM
Sold Align T-Rex 500ESP - 95%NIB Buzz_Man Aircraft - Electric - Helis (FS/W) 2 Jul 29, 2010 03:15 PM
