Old Dec 08, 2003, 03:29 PM
Antonsoarer is offline
Find More Posts by Antonsoarer
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
Site potential for DS
I am new to DS and am about to revisit some of my old sites to check them out for DS potential. The picture below shows two shots of a old haunt I am considering for DS. Which side do you think will work best or will both work to some degree? Its about a 40 mile drive so any advice would be great.
The coastal site is great for frontside but there is this rock with the lighthouse on that I have never considered, it might work for DS, I will post a bigger picture of the coastal site next.
Antonsoarer is offline Find More Posts by Antonsoarer
Old Dec 08, 2003, 03:32 PM
Long to be flyin'
Wirral, (UK)
Joined Dec 2003
Potential coastal DS site?
This one is about 50 miles away. Photo is from the main cliff which works great in anything above about 8mph.
Old Dec 08, 2003, 03:48 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
They all look like they'd work, given the right wind direction. For the two bowls, you should be able to DS a pretty flat pattern behind the lip on the shallow side of the slope. The problem I've found trying to work a hill like that, the other way around, is that when the DS groove is bad, it's REALLY bad, and consists of nothing but down air, and then you risk getting trapped above a steep slope with nothing but rotor. Going the other way, the separation layer can be higher and further forward, and the DS loop nearly horizontal. At one spot I DS, the frontside is a cliff, and the backside about a 30 degree slope, and the separation boundary is nearly vertical. If I step 10 feet back from the edge, it's dead quiet.
As for the lighthouse. I'd think you'd have a problem with the wind direction, and landing. And is that a set of powerlines I see running down the the middle? That would complicate things a lot.
ian
Daemon is offline Find More Posts by Daemon
Old Dec 08, 2003, 04:10 PM
Long to be flyin'
Wirral, (UK)
Joined Dec 2003
Daemon, thanks, yes they are power lines, not an ideal site so I wont bother trying any DS there, just stick with the usual frontside which is great.
As for the 'bowl-n- slope site I will probably give the shallow side a go with a foamy. I did try a bowl once at another site and my foamy just went down like a brick, long walk!
Discussion Potential new DS site San Clemente THend Dynamic Soaring 10 Dec 09, 2006 06:22 AM
Discussion Looking for DS Site near Rochester New York HoverDown3K Dynamic Soaring 0 Jun 06, 2006 11:46 AM
Remote Ballast/CG Shifting for DS aircraft e-sailpilot86 Slope 25 Jul 06, 2005 11:01 PM
Attention Northern VA Fliers! Potential for new field! mralston Electric Plane Talk 19 Jul 19, 2002 05:01 PM
Max AMP draw potential for MAXXELL aaa 700 nimh batteries? try2fly Power Systems 4 Feb 26, 2002 12:49 PM
