man, you gotta go in steps. your just chasing your tail right now.
first things first. are the transmitter batteries good? if they are old, put new ones in. second is the trucks battery charged? when it gets low they will twitch some times. third look the entire truck over for loose connections. if the truck has tamiya battery and esc plugs on it, they are well known to give bad connections. this look over is also to make sure all connectors are plugged into the receiver good, that wires are not knicked or damaged, that the battery and esc connectors are all good. after this if you still have problems with the truck twitching forward/backward, then recenter all your trims on the transmitter, center dual rate steering (if you have it), and rebind the transmitter to the truck. if the problem still exists, then unplug your rear steer servo, still doing it, then unplug the front steering servo. what you are doing is eliminating the servos from causing the problem. if a servo is going bad sometimes they will bind and draw quite a bit of power. this excess draw can cause the esc's internal bec to shut off. when this happens the receiver will shut off also, when the receiver comes back on it can cause glitches. |
United States, MA, North Andover
Joined Feb 2012
Joined Feb 2012
I have tried almost everything people have sugested here with no luck. The rock crawler is fairly new, driven maybe a dozen times, not beat on and never exposed to mud and water. I find it strange how the problem went from just steering twitches to throttle twitches also without it even been driven. I am thinking it is either a transmitter/receiver problem or a problem with the speed control but am not sure how to determine which it is. The radio system and speed control are original equipment.
well if you are having twitching forward/backward problems, and you have checked all your batteries, and unplugged everything from the receiver except the esc and your still having these issues, the only other thing you can do is try a different transmitter or a different esc.
from my experience your problem will usually lie in the esc. but it would be very easy to use a different transmitter just to be sure. if you (or a friend) doesn't have one laying around, you might hit your local hobby shop. they usually have a few laying around they would probably let you try out, or they would know of somebody that does. |
Joined Feb 2012
hoghead,
sounds good, I will have to check my recources, Thanks for your help and advice.This R/C groups is awesome, a lot of people friendly and willing to take their time and help others in the hobby.I have been out of the hobby for about 10 years and the advances in electronics have changed things considerably. |
Joined Feb 2012
I tried looking for a replacement speed control under spare parts for the madtorque at the place I bought the truck at nitrorcx.com but they did not have a stock replacement. Any sugestions on an inexpensive replacement? My truck has the battery and motors that came with the truck.
not the best, but it's decent and pretty cheap to boot.
http://store.rc4wd.com/Outcry-Crawle...BEC_p_664.html |
| Thread Tools | |
| Sold Exceed RC Mad Torque 1/8 Crawler with FPV camera | cactus | Cars - Trucks and Parts (FS/W) | 1 | Nov 05, 2012 09:39 AM |
| New Product exceed mad torq 1/10 moa crawler | rcphreak | Rock Crawlers | 50 | Oct 24, 2012 05:38 AM |
| Wanted used 1/10 or 1/8 rock crawler roller or rtr | mervfan17 | Cars - Trucks and Parts (FS/W) | 0 | Jul 02, 2012 10:08 PM |
| Discussion New 1/8Th Mad Torque Rock Crawler | hobbypartz | Product Announcements | 1 | May 09, 2011 07:17 PM |
| Discussion ok will a exceed r/c 1/8 crawler be good for a starter crawler | mini t king | Rock Crawlers | 4 | Jul 06, 2010 01:25 PM |
