There must be a user group on the web for Sea Snarks. They have been around for a long time.
Anyway, I would think epoxy resin, not polyester resin, should be used. And don't use wood filler. Wood filler is made for, well, wood. Why not use the same epoxy resin you will use with the glass, but mix in a bunch of low density filler like micro balloons? Big name resins, like West System, work very well but are pricey. Check at your local marine chandlery like West Marine, or online. I have had good luck with the epoxy resin from US Composites in Florida. http://www.westsystem.com/ss/ http://www.uscomposites.net/default.asp Dave |
Joined Mar 2007
I'd take your query to www.boatdesign.net
Lots of experts on full size boats hang out there. Cheers, Earl |
| Thread Tools | |
| Discussion Difference between UHU Por Polyfoam and UHU Por Styrofoam? | sparkyz | Electric Plane Talk | 2 | Aug 23, 2012 03:22 PM |
| Question Reparing Styrofoam Heat Damage | notime_3001 | The Builders Workshop | 10 | Aug 19, 2012 01:41 PM |
| Discussion Blue styrofoam | vengeance111 | Foamies (Scratchbuilt) | 10 | May 13, 2012 11:18 PM |
| Help! Boat Hull Repair!!! | lago | Dock Talk | 9 | Jan 23, 2006 01:09 PM |
