Old Nov 09, 2012, 02:44 PM
squid10 is offline
Find More Posts by squid10
Israel
Joined Nov 2012
quadcopter flips over
I also posted this question at hobbyking, but didn't receive answer...
I just finished to build a KK2 quadcopter.
When i'm trying to fly it, it flips over.
current motors configuration:
M1 CW, prop - 8045R
M2 CCW, prop - 8045
M3 CW, prop - 8045R
M4 CCW, prop - 8045
I calibrate the sensors and the ESC.
setup:
ESC: turnigy plush 25amp
Motors: NTM 28, 1200Kv/250W
Frame: X525.
Dose the motors and the props configuration is ok?
Dose prop 8045R is for CW motor, or should I use 8045 without R?
squid10 is offline Find More Posts by squid10
Old Nov 09, 2012, 03:11 PM
ecks is offline
Find More Posts by ecks
Knowledge prevents flyaways
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
Show us a picture of the quad
ecks is offline Find More Posts by ecks
Old Nov 09, 2012, 04:20 PM
panos2408 is offline
Find More Posts by panos2408
DXL Team Pilot FuriusP
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
I have the kk2 board. It flies very well on my mini hexa.... you should normally have
1 2
4 3
where 1 and 3 = R
Since you are getting correct thrust direction on all motors you should be fine with this part... Try calibrating ESC's again. Also make sure you have the board set to the correct mode + or x depending how you fly. Note that the board sits on the main plate as a square and with 45 degrees angle.
panos2408 is offline Find More Posts by panos2408
Old Nov 09, 2012, 04:59 PM
CH33ZEBURG3R is offline
Find More Posts by CH33ZEBURG3R
Australia, VIC, Frankston
Joined Jul 2012
M1 CW, prop - 8045R
M2 CCW, prop - 8045
M3 CW, prop - 8045R
M4 CCW, prop - 8045
setup:
Frame: X525.
A Video would be more help than text and photos.
CH33ZEBURG3R is offline Find More Posts by CH33ZEBURG3R
Old Nov 10, 2012, 03:26 AM
squid10 is offline
Israel
Joined Nov 2012
here is a picture of my quad
Old Nov 10, 2012, 05:38 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
I can't see connection of ESCs to the board very clear but if top left motor is number 1 then i don't see anything wrong with that wiring. I can't tell the receiver and FC if have any problems either but it should be 1 aileron 2 elevator 3 throttle 4 rudder. Your gain setttigns should fly the model as they come from factory It's better if you take a small video... Also post some Gain values. Photo seems fine...
Old Nov 10, 2012, 05:53 AM
ecks is offline
ecks's Avatar
Sweden, Gothenburg
Joined Oct 2012
Are all motors spinning the right way?
Also do a receiver check on the kk2 board. It shows you what's happening corresponding to the transmitter. I needed to reverse 2 settings on the transmitter
Old Nov 11, 2012, 03:38 AM
squid10 is offline
Israel
Joined Nov 2012
I calibrated the ESC again and I also decreased most of the PI gains, now it much more better and it doesn't flips but is still not stable.
I think the problem is with my cheap hobbyking 4ch TxRx. I also crashed a bixler with this TxRx (after I spent month on a simulator... so I know how to fly...) in addition to the bixler I tried another plane - atom gliter and still, cant fly...
on the ground the TxRx seems to work good, but still it doesn't react good in real flight. can it be the TxRx?
Old Nov 11, 2012, 05:54 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Maybe you have some kind of interference.... I don't know... Are you trying to fly the thing in stabilized mode? I can't fly mine in that mode because it's not that responsive. Maybe try another Receiver if you think this is the problem. But i guess a video will enlighten us more for your case since it's not a typical mistake on the connections. Have you balanced your props? If there is to much vibrations it could be affecting the way flight control works....
Old Nov 11, 2012, 05:56 AM
squid10 is offline
Israel
Joined Nov 2012
ok, i'll try to upload a video in the next days,
Old Nov 11, 2012, 04:50 PM
Eddie James is offline
Find More Posts by Eddie James
FPV Racer - N4FPV
Eddie James's Avatar
United States, GA, Kennesaw
Joined Sep 2009
You have your motors mis-aligned, or one or more are spinning the wrong way, or you have the wrong props on.
Some controllers use this motor numbering system (like open pilot):
Front
12
43
Back
and some controllers use this motor configuration (like DJI Naza):
Front
21
34
Back
Here's what you do first:
1) Pull a motor wire from the controller and plug into your throttle input on your receiver. Then slowly throttle up. Identify which motor starts running and then tape that number written on a small piece of paper on the servo wire. Do this for all 4 motor wires.
2) Then determine what motor diagram you are using for your controller (see above) and make sure that the proper motor wire is plugged into the controller at the right input for each motor.
3) Then look at your controller's diagram again and make sure each motor is spinning in the right direction on your quad. If not, switch two wires on the esc for the motor that is not spinning the right way.
4) Than make sure you have the proper props. One is normal and one is left. Only your diagram for your controller will tell you these things. You just have to do it one step at a time and make sure all of these variables are all right.
5) and don't forget if your controller has a calibration function, do it before your test flight.
Eddie
Eddie James is offline Find More Posts by Eddie James
Old Nov 13, 2012, 09:30 AM
squid10 is offline
Israel
Joined Nov 2012
Hi Eddie,
My FC is KK2, it's using your first diagram.
I assembled the props right and the motors direction is also right.
I calibrate again the ESCs and now the quad is flying much more better and when i'm changing the PI it's reacting good, now i know for sure that the motors and the props are all right
the quad is still drifting a sides all the times and i'm pretty sure its the Tx or the Rx (i'm using the HK cheapest 4ch TxRx), right now i'm a little afraid to get it up more then 0.5 meter.
I ordered a turnigy 9x which im hoping will solve this saga.
hop to update you guys ASAP, also i started to write a PDF with all the instructions for my quad so new beginners will have a lot easy life
Thanks for the help!
Raz
Old Nov 14, 2012, 06:03 AM
panos2408's Avatar
Cyprus, Limassol
Joined Feb 2008
Ah you have to lift it higher am afraid. What you describing here is the ground effect... The air that your quad pushes on the ground bounces back and hits your quad and affects it's stability. Try at about 1 meter+ You might want to return your Pid in the default state now you have the props aligned correctly
Old Nov 14, 2012, 08:28 AM
squid10 is offline
Israel
Joined Nov 2012
you probably right.. i forgot there is a ground effect, I'll try to lift it higher and i'll see what will happen ...
Old Nov 15, 2012, 03:44 AM
squid10 is offline
Israel
Joined Nov 2012
ok, I update the firmware to v1.4 and set self level to on - it flies like a charm!!
if you were ask me 1 week ago if i'm actually believe that i can build a quad that actually fly i would have definitely say no, but this one fly like a baby! i got it 5 meters from the ground.
it still drifting very little and i'm sure i can fix that by playing with the PI.
thank you guys for sharing your knowledge
Help! Why does my modified Jetiger flip over? djacob7 Foamies (Scratchbuilt) 0 Jul 08, 2012 01:33 PM
Help! violent flip over during quad startup Scooter619 Multirotor Talk 12 May 22, 2012 09:06 PM
Help! New X525 Build, flips over. PsyQuad Multirotor Talk 15 Apr 05, 2012 05:53 PM
Discussion Flipping over Again rkenosha Hoverfly Technologies 19 Feb 28, 2012 04:12 PM
