Old Nov 09, 2012, 01:03 PM
San Francisco Bay Area
Joined May 2001
Charging lipos with Paul Daniels regulator
I have purchased a used Stobel V3 that has an installed 2-cell lipo and a Paul Daniels regulator.
I am not sure which lead to use to charge it.
As shown in the attached picture there are two leads (A & B) that connect the battery and the regulator. Should I use one of those?
Or should I use C? (the red lead from the regulator that plugs in to the receiver).
If I should use C I am assuming that A & B should not be connected while charging.
Any input would be greatly appreciated.
John
John Webb is offline Find More Posts by John Webb
Old Nov 09, 2012, 02:36 PM
Thermal, where art thou?
BavarianCharles's Avatar
85045
Joined Oct 2005
John
Always charge the battery directly, and never through the regulator. If you're using a switch-jack, then it should seperate the receiver + regulator from the battery.
BavarianCharles is offline Find More Posts by BavarianCharles
Old Nov 09, 2012, 02:37 PM
Mike M.
like.2.fly's Avatar
United States, UT, Eden
Joined Jan 2010
Looks to me like there is no switch jack in the circuit, so you will have to charge directly through the battery lead (connector "B", I think). Once C is plugged into your receiver then plugging/unplugging A & B is how you will turn the plane on/off. You cannot charge the battery backwards through the regulator (through "C" when "A" and "B" are connected). You will need a special connector or pigtail from your charger to connect it directly to B.
like.2.fly is offline Find More Posts by like.2.fly
Old Nov 09, 2012, 04:42 PM
no place like cloud base
DLGjunkyard's Avatar
Canada, ON, Cambridge
Joined Apr 2010
If done properly [which it appears to be] the battery wire [b] in this case has the red power lead as a female on the plug . Plug your charger straight into the battery. After charge and to power up the glider think this. The power is regulated before entering the system
DLGjunkyard is offline Find More Posts by DLGjunkyard
Sold Paul Daniels Regulators - Brand New smokeytbear Aircraft - Sailplanes (FS/W) 4 Oct 02, 2012 07:45 PM
Sold Paul Daniels regulator danfitz Aircraft - Sailplanes (FS/W) 4 Sep 06, 2012 02:09 PM
Sold Paul Daniels Regulators danfitz Aircraft - Sailplanes (FS/W) 1 Aug 11, 2012 10:44 AM
Sold Paul Daniels regulators danfitz Aircraft - Sailplanes (FS/W) 1 Jul 17, 2012 03:12 AM
Sold 2 Paul Daniels lipo regulators for HL grouch Aircraft - Sailplanes (FS/W) 3 Apr 29, 2012 03:32 PM
