Old Nov 09, 2012, 10:19 AM
KOMET 44 is offline
Find More Posts by KOMET 44
D.G.B.
KOMET 44's Avatar
Southington, Connecticut, United States
Joined Jun 2000
Saving balsa/plywood scraps??
I'm asking this question because I 'd like to know what amount or if any does evryone save? Just going through to old box's rite now.Do you save scraps from kit's?? Plywood scraps?
stefanP
KOMET 44 is offline Find More Posts by KOMET 44
Old Nov 09, 2012, 10:29 AM
Dean Church is offline
Find More Posts by Dean Church
United States, CA, Rio Vista
Joined Feb 2012
It's a non-cureable disease, worse than drugs and alcohol.
Maybe we could join a 10 step program.
Dean Church is offline Find More Posts by Dean Church
Old Nov 09, 2012, 10:54 AM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
There is no such thing as "scraps." They are simply bits which have not yet found a home in an airframe.
I save everything that could be even slightly usable. As a result I often build my micros with little or no virgin wood pieces.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 09, 2012, 11:06 AM
edwin1 is online now
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
Never throw away anything. I have a work bench with a jig saw, 1" vertical sander, and 4" horizontal sander, and that table is FULL of wood scraps. Its my first go to spot when I need a piece of wood.
Hmm, I'm a sick man!!!
Edwin
edwin1 is online now Find More Posts by edwin1
Old Nov 09, 2012, 11:12 AM
KOMET 44 is offline
D.G.B.
KOMET 44's Avatar
Joined Jun 2000
Andy ,thank you for the clarifing my wording.Sorry for the wrong terminoligy.
stefanP
Old Nov 09, 2012, 11:32 AM
epoxyearl is online now
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
No scrap-just unused
What we need to do,is teach ourselves to go to the box first-short pieces,gussets,braces and ply doublers are all right there.
But they're for "someday" and this ain't it! SAVE THE SCRAPS !!!
epoxyearl is online now Find More Posts by epoxyearl
Old Nov 09, 2012, 12:16 PM
kenh3497 is online now
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
http://www.rcgroups.com/forums/showthread.php?t=1753137
Ken
kenh3497 is online now Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old Nov 09, 2012, 03:23 PM
Fly Wheel is offline
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
My first build was a Tom Hunt Miss Stik and I saved all the left over balsa stock, which came in handy a few weks later when a "one point landing" scrunched the nose back to the cabin section. Turns out the saved "scrap was all I needed to rebuild the nose. I even had enough covering to ge her into "like new: shape.
Fly Wheel is offline Find More Posts by Fly Wheel
Old Nov 09, 2012, 09:37 PM
invertmast is online now
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
I probably have enough balsa "scraps" to build a 1/4 scale cub!
invertmast is online now Find More Posts by invertmast
Old Nov 10, 2012, 02:31 AM
scrub monkey is offline
Find More Posts by scrub monkey
use the 4s luke, use the 4s...
scrub monkey's Avatar
Australia, QLD, Booyal
Joined Sep 2012
Too bad the spares can't be joined to create new sheets
scrub monkey is offline Find More Posts by scrub monkey
Old Nov 10, 2012, 02:32 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
We need pics! Here's mine.
Stuart A is offline Find More Posts by Stuart A
Old Nov 10, 2012, 08:02 AM
Joined Sep 2003
My pile.
Edwin
Old Nov 10, 2012, 12:22 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
stefanP
Yep -every little scrap is saved, in separate boxes for balsa, liteply, birch ply (and even depron).
leccyflyer is offline Find More Posts by leccyflyer
Old Nov 10, 2012, 02:15 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Yes, I'm hooked as well. Balsa, ply, things, and ...............
(Sad isn't it ).
eflightray is offline Find More Posts by eflightray
Old Nov 10, 2012, 02:41 PM
Fly Wheel's Avatar
Joined Sep 2007
Actually they can. When I recovered the new nose on my Miss I simply overlapped the old covering with the new at the bulkhead where the old covering ended. Since it is backed by a solid object even the transparent covering shows no hint of being seperate pieces.
Discussion Scrap Balsa..... kenh3497 Balsa Builders 26 Oct 28, 2012 10:34 AM
Discussion Foam vs Balsa / Plywood Trainer worleyeoe Foamies (Kits) 3 Aug 21, 2012 03:51 PM
Discussion Balsa plywood and veneer energyos Hot Online Deals 0 Jun 24, 2012 06:38 AM
Discussion Balsa and Plywood jesse78 Trader Talk 0 May 26, 2012 06:41 PM
Found Your scrap balsa and ply dmarusa Aircraft - General - Miscellaneous (FS/W) 3 May 25, 2012 10:29 AM
