A droop nose is also a camber changing device. Properly shaped slots anywhere on the wing are stall delaying devices. That's why the various slotted flaps can be deflected to larger angles and produce larger lift increments. Sorry I don't have time to explain all the columns in that table. However you know most of the notation so can figure a lot of it out on your own. Just remember that delta is the algebraic symbol for rate of change Quote:
--Norm |
That's also why many full size planes use spoilers for roll control at slow speeds and high AOA. It leaves a greater portion of the leading and trailing edges free for lift increasing devices, and prevents unintended asymmetrical stalls, by effectively using "intended" asymmetrical stalls for roll. Ailerons work better at high speed and low AOA, so most liners have both ailerons, flaperons and spoilers.
in all other cases, the flaps or slats(?) change the airfoil shape into one that is concave while maintaining a unique trailing edge. But the split flap creates an airfoil with two trailing edges. are split-flaps more like a spoiler, which decrease lift and increase drag, than flaps which increase the lift curve and max CL? greg |
Joined Jan 2007
Spli flaps work much like plain flaps. They increase the camber of the wing, therefore increasing the maximum Cl.
Perhaps surprisingly, they produce slightly less drag than a plain flap for the same Cl increase. This can be a good or bad thing, depending on your application. There are lots of reports on split flap wind tunnel testing on the NASA server, and good information in "Theory of Wing Sections" A&D. http://ntrs.nasa.gov/archive/nasa/ca...1993091743.pdf Kevin |
Thanks Kevin
We can still use SOME aileron even when flying slowly and near the stall. But it's best done in small amounts and along with a bit of coordinated rudder. |
Actually, inboard flaps help in that situation, because they add aerodynamical washout to the wing. The central portion is at an higher AOA, so a stall is more likely to start inboard first. And generous aileron differential helps too. But for truly "walking pace" stol designs probably spoilers would be best.
| Thread Tools | |
| Question OLY II flaps or no flaps? | ozmo01 | Altitude Limited Electric Soaring (ALES) | 7 | Sep 18, 2012 11:17 PM |
| Discussion Conservatives Understand Liberals, but Liberals Don't Understand Conservatives | Highflight | Life, The Universe, and Politics | 78 | Mar 27, 2012 06:33 AM |
| Discussion Desperately in need of help with understanding flaps settings on a DX-7 for my Texan | Valid8r | Electric Warbirds | 14 | Feb 14, 2010 11:02 PM |
| help me understand the flap function on my 6XAS | shams42 | Radios | 1 | Feb 25, 2004 10:09 AM |
