Old Nov 09, 2012, 08:24 AM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Question
Understanding flaps
Hi All,
I'm going to ask this question in two forums, so please don't have a hissy fit.
It's my understanding that lift on an airfoil (wing) is a direct result of the top contour of the airfoil. When using standard flaps or flaperons on a plane I can see that the top profile of the airfoil changes. It gets longer which is what gives it more lift. When the air has to travel a longer distance to get past the wing it creates more lift on the top.
I have acquired my first SPLIT flaps plane. A Spitfire. On this plane the flaps are deployed under the trailing edge of the wing. The top of the wing profile is not changed?
So apparently my understanding of lift is wrong?
Can someone enlighten me
Tom
tacx is offline Find More Posts by tacx
Old Nov 09, 2012, 08:45 AM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Lift is caused by deflection of air under the wing
Aka: AOA
Discuss!
1320fastback is offline Find More Posts by 1320fastback
Old Nov 09, 2012, 09:28 AM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
This NACA smoke tunnel test should answer your questions.
I suggest watching the whole video:
http://www.youtube.com/watch?v=3_WgkVQWtno
The split flaps begin here:
http://www.youtube.com/watch?v=3_Wgk...ailpage#t=433s
You can judge drag by how much separation you see. Separated flow is indicated by the cloudy looking regions (as the smoke is being mixed).
You can judge lift by how many streamlines are diverted to go over the top. This is indicative of circulation. Notice that when an airfoil reaches the stall angle of attack, if the angle of attack increases the streamlines actually shift so as to have less circulation (less streamlines going over the top).
DPATE is offline Find More Posts by DPATE
Old Nov 09, 2012, 10:34 AM
nmasters is online now
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Yep
Nope
Fluid dynamics is the hardest problem in classical physics. The length of surfaces story that you've heard was BS made up by Theodore von Karman to get rid of a newspaper reporter.
nmasters is online now Find More Posts by nmasters
Old Nov 09, 2012, 12:19 PM
richard hanson is offline
Find More Posts by richard hanson
richard hanson's Avatar
United States, UT, Salt Lake City
Joined Oct 2007
So much ado about so simple a problem
Lift happens anytime there is a pressure differential- no matter how you do it
and you can produce it using a flat plate or a ball or a cylinder . or a piece of cloth.
HOW it occurs on each is different but the same net effect - there is always a difference in pressure.
Please ---- no text book quotes -most are simply long winded obfuscations
richard hanson is offline Find More Posts by richard hanson
Old Nov 09, 2012, 12:24 PM
tacx is offline
tacx's Avatar
Joined Apr 2009
All very interesting.
Old Nov 09, 2012, 03:04 PM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
http://www.rcgroups.com/forums/showt...un#post9045024
Old Nov 09, 2012, 03:13 PM
Brandano is online now
Find More Posts by Brandano
Also, flaps is a generic name for many different types of lift augmentation devices. The simplest ones increase the wing camber, and in a small measure the angle of the wing relative to the fuselage. Other incerase the wing area by extending rearwards, and then proceed to deflect downwards to increase the camber. Split flaps like those used in the Spitfire are a tradeoff between different needs. They lower the stall speed slightly by increasing the wing camber, increase wing drag making it simpler to control the speed using the engine only, and the fixed upper portion of the wing mitigates the wing's pitching moment, maintaining the tail's effectiveness at slow speed.
Brandano is online now Find More Posts by Brandano
Old Nov 09, 2012, 03:15 PM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
i'm sure someone can explain the purpose of flaps.
hopefully that explanation can also include the different types of flaps
ciurpita is offline Find More Posts by ciurpita
Old Nov 09, 2012, 04:17 PM
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
The attached table is from "Personal Aircraft Drag Reduction" by Bruce Carmichael
Old Nov 09, 2012, 10:00 PM
ciurpita is offline
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
i've never flown a plane with flaps which is why i hoped someone else would provide an explanation. My experience is with spoilers on a glider, which only affect drag and the glide slope to control the landing point.
any airfoil has a particular angle of attack that maximizes the lift to drag ratio. Ideally the plane will be flown at this AOA which along with the area of the wing and the aircraft weight determine the best airspeed. A smaller wing would allow a high airspeed with best L/D. Flying both above or below this best airspeed results in a lower L/D which can be used to control the glide path. But there are limits to how slow you can fly before stalling and the L/D (drag) may not change as must as desired.
Trailing edge flaps significantly change the airfoil shape and its characteristics, as well as effectively increasing the AOA without changing the pitch of the aircraft . With increased AOA, the airspeed will slow. But by making the airfoil more concave (reflexed) the lift curve can be significantly increased, increasing the maximum lift coefficient, reducing the stall speed and allowing the aircraft to be flown much slower. Extending the AOA also allows the aircraft to flown further from its optimal L/D, further increasing drag and lowering the L/D. See the wikipedia description of flaps.
Without changing pitch, extending flaps can significantly reduce airspeed and lower the L/D to increase the glide slope (visibility can be an important factor as well as landing planes with high L/D).
its not clear to me how much of the above explanation of flaps applies to split flaps where the trailing edges do not converge. While they may increase the lift curve and reduce the stall speed, perhaps they also have characteristics similar to spoilers which simply reduce L/D providing control of the L/D.
greg
Old Nov 10, 2012, 07:51 AM
Joined Oct 2007
greg
Flaps work the same way on a powered model- as on your glider AND the model will still fly even when stalled out- but under better control.
why?
most of the wing stalls ( the flapped portion) before the outpanel.
Notice that the model is still flying at a cruise attitude- even tho the flaps are deployed
Ideally, the plane is always pointed in exactly the same direction it is heading
Depending on the flap type and size and angle of deployment - the amount of lift and drag will be such that controllability on all axis is still good.
If you really want to see how this works (beats trying to calculate it), buy one of the new tiny indoor super light models -( the VAPOR is perfect) and in a large room (small meeting room is fine) and practice flying at different attitudes
You will quickly find that power must increase as you add AOA- just like using flaps- otherwise the angle of descent will increase. And no fears of damage thru a crash -they weigh 17 grams and are incredibly stable due to low aspect ratio and minimal wing loading.
This beats any other method of seeing-up close and personal- how it all works, that I have found in 60 years of flying.
Old Nov 10, 2012, 10:22 AM
ShoeDLG is offline
Find More Posts by ShoeDLG
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
The basic effect of flap deflection is to increase a wing's lift coefficient at a given angle of attack. One benefit of flap deflection is that (within limits) increasing deflection also increases a wing's maximum lift coefficient. This means that for a given weight, an airplane can takeoff or land at a lower speed.
In almost all cases, the increase in lift coefficient comes with an increase in drag coefficient (for a given AOA). For landing, planes often use significant flap deflection because drag is not of particular concern. For takeoff, where the goal is typically not just to get airborne, but to climb and accelerate, less deflection is normally used to achieve a compromise between runway required and the rate of energy addition during climb out.
Most of my practical experience with flaps is full-scale.
To illustrate the compromise associated with takeoff flap settings: In the F-18A-D, you set the flaps to "half" for the catapult shot. Setting the flaps to half (rather than "full") gives you better energy addition (particularly in the case where you lose an engine during the cat shot), but increases the amount you will settle in front of the carrier. In the F-18E/F you set the flaps to full (there are certain configurations where the sink is too high with the flaps at half). Even for two airplanes as similar as the Hornet and Super Hornet, the compromise between takeoff performance and energy addition leads to different catapult flap settings (both airplanes use half flaps for field takeoffs).
When landing on a carrier, flaps are generally your friend. Less landing speed means you won't break the wire you catch (definitely good). The additional drag means that the engines will be at a higher RPM which gives faster throttle response (also a good thing). The additional drag can be a problem if you've lost an engine, so you use half flaps for a single-engine approach in both the Hornet and Super Hornet (when single-engine, the ship will speed up to reduce your relative speed).
Reducing AOA for landing on a carrier is not necessarily a good thing. If you see a picture of an F-8 in the landing configuration you might notice that the entire wing is rotated (think of it as a full-chord flap). This made it very difficult to land on the boat (I've heard... It was well before my time). It turns out that engine thrust is far more effective at changing your flight path when it's not quite aligned with your flight path (as is the case when you have a few degrees of AOA).
There is no flaps "up" position in the Hornet/Super Hornet, only "auto". In this position you turn over control of the (single-slotted) trailing edge flaps and leading edge flaps to the flight control computers. Most of the time this means that the flaps are pretty close to up. The computers will adjust them slightly in cruise for minimum drag. As you increase AOA, the leading edge flaps will be the first to deflect. Once you get to high angles of attack (beyond about 30 deg), the trailing edge flaps will start deflecting significantly.
My RC experience with flaps is mostly with DLG flaperons. These have two primary uses. First, they allow you to reduce the drag in (more or less) level flight across a range of airspeeds. Second, they give you the ability to manage energy (by adjusting drag) once you've decided to land.
Hope this provides perspective on some of the ways flaps are used.
ShoeDLG is offline Find More Posts by ShoeDLG
Old Nov 10, 2012, 10:37 AM
OldeMan is offline
Find More Posts by OldeMan
Faster is Better
OldeMan's Avatar
United States, AZ, Gilbert
Joined Jul 2012
Class dismissed!
Nice overview.
OldeMan is offline Find More Posts by OldeMan
Old Nov 10, 2012, 05:24 PM
ciurpita is offline
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
why does a flap, or any trailing edge device creating a concave airfoil shape, cause an increase in the max CL?
when near stall, would moving a aileron down induce a stall, or like a flap, increase lift as well as increase the max lift coefficient, avoiding a stall?
greg
Question OLY II flaps or no flaps? ozmo01 Electric Competition Soaring-F5J/ALES/e-Soaring 7 Sep 18, 2012 11:17 PM
Discussion Conservatives Understand Liberals, but Liberals Don't Understand Conservatives Highflight Life, The Universe, and Politics 78 Mar 27, 2012 06:33 AM
Discussion Desperately in need of help with understanding flaps settings on a DX-7 for my Texan Valid8r Electric Warbirds 14 Feb 14, 2010 11:02 PM
help me understand the flap function on my 6XAS shams42 Radios 1 Feb 25, 2004 10:09 AM
