Old Nov 09, 2012, 07:49 AM
mew09 is offline
Find More Posts by mew09
Dr. Wylam
Rochester, MN
Joined Jan 2005
DIY Laser Cutter
http://www.kickstarter.com/projects/...n-laser-cutter
I am going to build this 40W laser cutter. Though it comes with a breakout board to run Mach3/CAM, I will upgrade to a DSP controller for PWM for the laser.
Thoughts.
mew09 is offline Find More Posts by mew09
Old Nov 09, 2012, 03:00 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
There are laser resistant plastics, I don't think they would stop a direct hit, but could help from a reflected laser beam.
http://www.professionalplastics.com/LASERFILTER
Roto Rob is online now Find More Posts by Roto Rob
Old Nov 09, 2012, 06:31 PM
Timthetoolman is offline
Find More Posts by Timthetoolman
CPA 30, SPA 523
Timthetoolman's Avatar
United States, TX, Fort Worth
Joined Nov 2009
It seems like a good deal. I'll be hinting to my wife. We were looking at Universal lasers since there was a dealer that's in the Dallas/Fort Worth area but the price was $15k and you can get one of these for $1.5k or $2k assembled.
The nice thing with a comercial version is the support but if you're familiar with CAD programs and such it would be a lot cheaper.
Have you used Mach3 yet? I'm not sure what the other controller was you mentioned that will take it's place. I'm also curious what CAM program you'll use or does the other product you mention take place of this?
I was going to buy Mach3 today but settled on GMFC for a CNC hotwire.
Tim
Timthetoolman is offline Find More Posts by Timthetoolman
Old Nov 10, 2012, 07:30 AM
mew09 is offline
Dr. Wylam
Rochester, MN
Joined Jan 2005
From lightobject.com .....the 2012 Commercial DSP CO2 Laser Engraving/ Cutter Controller = $450.00.
(http://www.lightobject.com/2012-Comm...oCad-P321.aspx).
This includes LaserCAD as the software. This type of controller has a microprocessor built-in for high frequency pulse width modulation (PWM) of the laser for graduated power control. It is not as necessary for vector cutting, but is certainly needed for raster-controlled engraving.
Also includes a LCD control panel.
Alternatively one could use CamBam + and Mach 3 bundled cost = $315.00 (http://sites.fastspring.com/hexray/product/cambam_mach3), i.e. the CamBam store.
Mach3 is standard CNC software, but not truly software for laser control. Best used for 2D or 3D milling. CamBam is a necessary software to turn design code, such as a DXF file into G-codes. Mach3 is essentially a G-code reader to run stepper motor controllers or TTL devices. I.E. it will turn laser on/off.
Old Nov 10, 2012, 09:09 AM
TheFernMan is offline
Find More Posts by TheFernMan
Too Many Thread Subscriptions
TheFernMan's Avatar
United States, FL, Miami
Joined Jul 2012
I've played with a laser cutter and it was installed as a plotter on a XP machine so you could just "print" to the "printer" using AutoCAD.
TheFernMan is offline Find More Posts by TheFernMan
Old Nov 17, 2012, 05:37 PM
Brian76239 is offline
Find More Posts by Brian76239
Brian76239's Avatar
Nashua, NH
Joined Nov 2008
This is a Seriously Cool Project
I'm teaching myself how to Use Turbocad for making Laser cut files.
Having My Own Laser Cutter would be totally Awesome.
Many thanks for posting the link to the Kickstarter Project.
Brian76239 is offline Find More Posts by Brian76239
Old Nov 28, 2012, 06:51 PM
mew09 is offline
Dr. Wylam
Rochester, MN
Joined Jan 2005
I ordered mine. The kickstarter project did not get funded, BUT buildyourcnc.com will be selling the Laser Kit. $1500 to kickstarter supporters, and I think $1800 to the rest. Stay tuned, I plan on doing a build log.
Old Dec 08, 2012, 12:38 PM
RCWorks is offline
Find More Posts by RCWorks
RCWorks's Avatar
Joined Aug 2003
The laser aiming would not be such a task with a simple design change.
The X axis moves the part, the Y axis moves the only mirror and the lens.
The laser never moves.
Just a thought to make it easier to build.
RCWorks is offline Find More Posts by RCWorks
Old Dec 08, 2012, 06:46 PM
Denver, CO
Joined Dec 2005
Like just mentioned that is an odd design for a laser engraver/cuttter. I think they move the Laser tube to make the footprint smaller. Laser tubes are rather fragile, I would not want mine moving around.
Most machines place the laser tube in the back, stationary. That makes the gantry lighter, and able to move fast for engraving, or light cutting work.
Old Dec 12, 2012, 09:02 PM
mew09 is offline
Dr. Wylam
Rochester, MN
Joined Jan 2005
You are referring to the fact that this is a gantry based system, i.e. the laser tube is mounted on the x-axis. The top of the line KERN Lasers are built on this design. Moreover, the proof is in the pudding. The design holds up, is simple to align, and maintains alignment over a larger area better. BTW. I suspect most on regroups.com are less worried about engraving performance.
Old Dec 13, 2012, 02:31 AM
Denver, CO
Joined Dec 2005
I looked up the Kern, looks like it works fine.
Old Apr 08, 2013, 06:16 PM
mew09 is offline
Dr. Wylam
Rochester, MN
Joined Jan 2005
Update on Blacktooth Laser
Finally received the kit and completed the build. The quality is outstanding and the performance exceeds expectation.
Discussion Laser Cutters bigdad1975 The Builders Workshop 13 May 08, 2014 09:06 AM
Laser cutter worldraft Aircraft - General - Miscellaneous (FS/W) 9 Oct 05, 2012 07:59 PM
Discussion Laser cutter?? c131frdave Scratchbuilt EDFs 9 Oct 04, 2012 08:18 PM
