Old Nov 19, 2012, 01:42 AM
F86_sabre is offline
Find More Posts by F86_sabre
Joined Jul 2004
Congrats Ace....plane is coming on nicely! As I have never done any resin casting myself is the quality of the resin similar to structural epoxy that is used for making molds?
F86_sabre is offline Find More Posts by F86_sabre
Old Nov 19, 2012, 06:23 AM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
I do use the same laminating resin for casting for some types of parts. Mostly I use urethane plastics which are more robust.
acesimmer is offline Find More Posts by acesimmer
Old Nov 19, 2012, 09:54 AM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Ace,
You have some serious moldmaking skills. Take a bow.
Are you planning on selling kits? Or is this just for your own personal enjoyment?
Bill
Prof100 is offline Find More Posts by Prof100
Old Nov 19, 2012, 05:16 PM
acesimmer's Avatar
Joined Oct 2011
Originally Posted by Prof100 View Post
Ace,
Bill
Thanks Bill
I'll probably sell a few short kits to help with the materials cost. Problem is the physical size for shipping so may have to be local guys or when I go to meets. I want to do the wing in one piece but was looking at filling the center section with hi density urethane foam so that it could be split. I just don't want the hassle of wing hold downs, tubes etc. My need is to have two old fashioned dowels on the leading edge into a bulkhead and a couple of nylon screws on the rear. Once I get the wing skins molded I'll revisit the split wing option.
Old Nov 19, 2012, 05:28 PM
acesimmer's Avatar
Joined Oct 2011
Today I cleaned up the molds and test fitted them all together. So far so good. I cut out the inner access areas to look at my options for joining. tomorrow I will layup a set for test and evaluation. I'll make this pull thicker for rigidity to test fit the tail and wings, firewall etc. I think that the first pull will be done in four sections with the rear section having a lip formed to join it to the front. I want to make sure that I get a perfect fitment so this way will give me full access to the seams.
So tomorrow another two coats of wax then PVA and start laying cloth.
Old Nov 19, 2012, 07:59 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Originally Posted by acesimmer View Post
Thanks Bill
Yes, shipping would be problematic unless you knew a cargo pilot to stow it away and fly to my city. Where is local?
Bill
Old Nov 20, 2012, 06:11 AM
eggsplurt is offline
Find More Posts by eggsplurt
USA, NJ, Red Bank
Joined Sep 2010
Not sure where to start in regards to commenting on this thread......Ace.....Sabre.....Morgan.....and the rest of you.......You're lucky I'm not your neighbor, or I'd be showing up with coffee and bearclaws just to hang around......messing around with engineblocks and rearends is getting to tough........this stuff however.....very cool.....Steve in N.J....
eggsplurt is offline Find More Posts by eggsplurt
Old Nov 20, 2012, 01:38 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I like bearclaws & coffee!
Ace,
It looks to have turned out fabulous! Congrats on some really nice work. Can't wait to see the rest of it. Keep it coming.
J
J Morgan is offline Find More Posts by J Morgan
Old Nov 20, 2012, 01:58 PM
acesimmer's Avatar
Joined Oct 2011
Thanks John... Coming from a master builder like you is a real compliment. Laying up the tail sections today to test fit etc. Doing it separately for now so molded a lip in so that I can join the tail to the main fuse if I want to. This is all just testing weights, adhesion etc.
Old Nov 21, 2012, 10:36 AM
bushpilotx1 is offline
Find More Posts by bushpilotx1
WITCH HUNTER EXTRAORDINAIRE
USA, FL, Boca Raton
Joined Feb 2001
Thank you for sharing, great work, cant wait until you do the Sbach
bushpilotx1 is offline Find More Posts by bushpilotx1
Old Nov 21, 2012, 02:13 PM
acesimmer's Avatar
Joined Oct 2011
I'm currently laying up parts in the molds. Due to the winter weather my parts are taking longer to cure than I would like. It is becoming very expensive to keep the shop heated to cure a cowl! So with that said I'm going to build a large variable heat curing oven.
See pic for basic design. I had built one of these on a small scale to cure my smaller epoxy castings and using a light bulb worked very well. In fact, it got the cycle cure time down from 14-24 hrs to 2 hrs.
So this one will be eight feet long with removable compartment dividers. This will allow me to cure a small part up to a full size Eurofighter fuselage that I'm also building. Each compartment gets a couple of light sockets connected to a separate light switch for each. A thermometer at each end and one movable will allow me to monitor the heat. This way I can also cure different parts in each section at different temps if required.
This bugger just fits nicely under one of my work benches with the top being used for a shelf. Now I will be able to layup the part and cook it without the rest of the shop heat bankrupting me. Cost is about $80 to build and pay back will be about one month.
Old Nov 21, 2012, 04:50 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Cool, I need to build one of those too. I use my storage area or trailer to cure parts in the summertime but a hot box is a hell of a lot better. Being able to control the heat would be nice.
Trek on Ace!
J
Old Nov 21, 2012, 04:54 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
You'll love the hotbox...
If your moulds have enough weight in them, you can pre-warm them too, which makes the layup even easier - the epoxy thins when it hits the warm surface, and flows much nicer.
I'm amazed at how quickly you've done this! I might consider maybe one day thinking about doing this for the Flanker...
Odysis is offline Find More Posts by Odysis
Old Nov 21, 2012, 10:05 PM
acesimmer's Avatar
Joined Oct 2011
Trek on Ace!
J
John... You can control the heat using the light bulbs. I'm putting all of them on separate switches so I can enable or disable depending on the temps I want. On my smaller one I have a small vent funnel that can also be adjust. It also act as a safety valve... kind of? I also have a timer that shuts the power off after a certain time that I know the resin will be cooked.
Odysis...great idea on pre-heating the molds. I must try that.
Old Nov 22, 2012, 07:06 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
Don't you want the bulbs on the bottom since heat rises?
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Build Log Molded tails with expanding foam core tzyoung Hand Launch 45 Nov 16, 2012 07:32 PM
Wanted Composite/foam or hollow molded Fin/Rudder Ne-Aero Aircraft - Sailplanes (FS/W) 2 Mar 01, 2011 02:38 PM
For Sale 3 x custom TabooGT models (std, disser + molded tails, narrow wing + foam tails) olgol Aircraft - Sailplanes (FS/W) 6 Mar 05, 2010 07:04 PM
Composite Molding Examples (Full-Scale) Phat2Wheel Composites Fabrication 8 Sep 09, 2004 09:15 AM
hollow mold vs. foam core on scale plane combatflier Composites Fabrication 10 May 11, 2004 03:42 PM
