Old Nov 11, 2012, 10:04 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
amazing is this your first time making molds ? if so you are a quick learner ,nice work ,heres a tip in case you need one ,when i do shapes that are not flat ,like your cowl and fuses i cut the glass on a 45 degree angle and it sure makes doing the lay ups a lot easier,also if you use a darker tool coat or dye the white to a darker color it makes doing the lay up a little better cause you can see air bubbles and voids a lot easier. nice work ...keep at it
AIR SALLY is offline Find More Posts by AIR SALLY
Old Nov 11, 2012, 11:07 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Definatley not a beginner, for sure!
A10FLYR is offline Find More Posts by A10FLYR
Old Nov 12, 2012, 06:49 AM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Thanks for the tip Roger keep them coming. Yes, I know about the angle layups to allow the cloth to flow around curves much better. I have made molds in the past but was thirty years ago and only made a couple of planes plus model boats. One was a large BA Hawk and the other a large Saab Viggen then a 5ft PT17 Jap Torpedo boat. These came out pretty good by pure luck.... laugh. Now it is so much easier to get info due to the internet.
This is my first large detailed scale mold set using all the modern resins etc. I wanted to tint my tool coat but it is the first time using this brand and type so did not want to risk anything on this layup.
I do have a lot of experience making molds with silicone/RTV rubbers etc. When I was restoring my Spider I had to make all of my own badging due to availability. I will be casting a lot of the scale parts for this model also.
Regards Stranded mat. It is working great for a stiffen layer. I pull it apart to loosen the strands then lay it as patches that overlap so they bind together. I use it only on the final and last layer.
acesimmer is offline Find More Posts by acesimmer
Old Nov 12, 2012, 10:49 AM
ruzam is offline
Find More Posts by ruzam
Go small or go home
ruzam's Avatar
Canada, SK, Regina
Joined Mar 2008
subbed
ruzam is offline Find More Posts by ruzam
Old Nov 12, 2012, 01:19 PM
Joe Kollmann is offline
Find More Posts by Joe Kollmann
United States, OR, Portland
What a great How-To!
Just out of curiosity, was the Spider an Alfa, Ferrari or some other two-seater?
I remember casting dash knobs for my 750 series Sprint twenty years ago.
Are you thinking you'll do composite skinned wings as well? It would be so nice to maintain this level of detail in the wing and control surface skins.
-Joe
Joe Kollmann is offline Find More Posts by Joe Kollmann
Old Nov 12, 2012, 01:38 PM
Robert Hansen is online now
Find More Posts by Robert Hansen
United States, HI, Kamuela
Joined Dec 2008
I would hope you would paint the beauty in 1965 - 1966 VIET NAM color's! I was there, Saw aerial support with the T-28. Thanks Bob Hansen
Robert Hansen is online now Find More Posts by Robert Hansen
Old Nov 12, 2012, 06:01 PM
acesimmer's Avatar
Joined Oct 2011
-Joe
81 Fiat.... Used to have a Ferrari Dino years ago and hated it. Slip the clutch a couple of times and its replacement time....Crunch a gear and you know what... Yuck
Yes, I'm doing a full top and bottom scale detailed wing. Going to try a couple of methods. Standard foam hot wire with the skin. And the other is 2K urethane expandable foam under compression whilst the skins are in the mold with a spar added. Done a few experiments and it looks very promising.
I just laid up a cowl to test the new release agents before continuing. One half with the old method and the other with the new stuff. Will see if any difference in part release. I would hate to finish the molds and find it does not part out... I did remove the rear parting plane and it just popped off super easy so maybe hope yet. I had read this morning that some peeps had issue with the new stuff then some loved it. So will see.... Also finished the rear parting plane and ready to mold that section tomorrow.
Old Nov 12, 2012, 06:03 PM
acesimmer's Avatar
Joined Oct 2011
I'll be doing several builds with a range of schemes. I must look that one up.
Old Nov 12, 2012, 08:18 PM
Willsonman is online now
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
That sounds like a BRILLIANT idea.
Willsonman is online now Find More Posts by Willsonman
Old Nov 13, 2012, 07:57 PM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
You're moving right along Ace.
J
J Morgan is offline Find More Posts by J Morgan
Old Nov 13, 2012, 09:37 PM
Joined Dec 2008
Squadron Signal has Era books on the aircraft in Viet Nam, in color, and various group Logos. Thanks Bob Hansen
Old Nov 13, 2012, 10:55 PM
aqkhana2002 is offline
Find More Posts by aqkhana2002
Australia, NSW, Plumpton
good to see this but need your help im material ...
if i want to make moulding what should i use material and can you list them with purpose ???
thanks in advace for helping...
aqkhana2002 is offline Find More Posts by aqkhana2002
Old Nov 13, 2012, 11:24 PM
acesimmer's Avatar
Joined Oct 2011
I'll Try.......
I used a foam plug and covered it in 2oz cloth using a laminating epoxy resin. Then covered in a 2K quality hi build automotive primer
Wet sand down 240, 300,400, wet/dry paper
Used a two part putty scratch filler then repeated until close to perfect. Then wet sanded to a hi sheen with 800, 1200 then 1600 paper.
Add rivets if wanted using hi quality carpenters glue with around 50% water. Google for lots of ideas!
For the mold
Used 100% pure Canuba wax buffing on several coats. Then spray with PVA mold release
Check my picks or Google for parting planes.
Used an epoxy tooling coat with two thin layers
Then clear epoxy laminating resin over 1oz cloth and build up sharp edges/corners until rounded off.
Then same resin with 2oz cloth several layers over those corners/edges.
Then cover entire plug with 2oz cloth and resin
Then several coats of 6oz cloth and resin
Final coat is the heavier stranded mat or 10oz cloth.
Allow to cure for 24 hrs above 70 deg F
Best to google and check out the real experts. Lots of vids on YouTube.
Old Nov 14, 2012, 07:32 PM
acesimmer's Avatar
Joined Oct 2011
The outside temps got much better today so with minimal heat in the shop I was able to layup the rear tail section. So she is half complete. I had a heck of a time with some of the sharp outside and inside corners. Especially around the hinge blocks and the elevator stub. Even using 3/4oz I was having issues due to the outer hinge block being very small and sharp. So I mixed up some tool coat and added cotton flock to make a paste. I inserted the flock paste into a large syringe and used it like a mini calk gun. Works like a champ and I was able to get at all the sharp bits and soften them up. I still think that I may have a few bubbles but will fix those in the mold face if required.
Tomorrow will remove parting planes and clean edges ready for the final layup on Friday. I sure hope these new materials work and the plug releases easy without being destroyed. One good thing about doing the mold in quarters instead of two halves is if one piece came out bad I could just remold that section assuming the plug survives....GULP!!
Build Log Molded tails with expanding foam core tzyoung Hand Launch 45 Nov 16, 2012 07:32 PM
Wanted Composite/foam or hollow molded Fin/Rudder Ne-Aero Aircraft - Sailplanes (FS/W) 2 Mar 01, 2011 02:38 PM
For Sale 3 x custom TabooGT models (std, disser + molded tails, narrow wing + foam tails) olgol Aircraft - Sailplanes (FS/W) 6 Mar 05, 2010 07:04 PM
Composite Molding Examples (Full-Scale) Phat2Wheel Composites Fabrication 8 Sep 09, 2004 09:15 AM
hollow mold vs. foam core on scale plane combatflier Composites Fabrication 10 May 11, 2004 03:42 PM
