Old Nov 09, 2012, 02:42 PM
NCRealEstateGuy is online now
Find More Posts by NCRealEstateGuy
I Used To Have More Free Time!
Charlotte, NC
Joined Feb 2011
subbed. I am waiting on the EF2000!
NCRealEstateGuy is online now Find More Posts by NCRealEstateGuy
Old Nov 09, 2012, 08:18 PM
acesimmer is online now
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Today is bloody cold and some snow. So with icicles on my nose I slugged across my lot to my shop. Crank the propane heater and began more work. I added the masking tape to the plug using dabs of hot glue attaching the parting planes to the plug on top of the tape. This works really good and makes a solid attachment. I then blew everything off and waxed up the planes with three coats of parting wax. I then inserted clay between the planes and the plug gaps so that I get a sharp clean edge on the mold. This also stop resin dripping on to the back side of the plug.
Once the clay is in I then re-waxed several more coats buffing to a high luster. One thing I will do next time is not to attaché the alignment dots until after the claying has they get in the way. So will mask small areas of the Pplanes off prior to waxing and claying.
I use card stock to make most of the template to cut out the parting planes then tape together. Once everything was waxed and clayed I then attached a couple of the air valves in the deeper regions to allow better removal of the mold using compressed air. I got these from the local tire shop when they cut them off customer rims.
A note here:
On this fuse plug I'm using all new resins and such. So not sure how they will release but I'm assured that they are some of the best. Its funny I could have purchased five or more foam kits and ARF's for the cost of materials for this one mold. However, I will be able to knock off quite a few models whenever I need them and can spread the materials cost over another mold or two.
acesimmer is online now Find More Posts by acesimmer
Old Nov 09, 2012, 08:28 PM
acesimmer's Avatar
Joined Oct 2011
I have also began a side job that is to build an 6ft super scale composite E2000 Euro Fighter. I have began work on the plug templates already so when I'm further into it I will do a build thread on that also. I'm going to be looking for advice on the Typhoon due to less experience than most with the bigger twin EDF's, retracts etc. This will be the DA4 two seater so that I can have a super scaled cockpit with animated Gi Joe pilots. So any input and or suggestions please just PM me.
Old Nov 09, 2012, 09:07 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Subbed ... Fantastic
Wilfor is offline Find More Posts by Wilfor
Old Nov 09, 2012, 09:51 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
keep the 2 seat cockpit, everyone and their mums have made a single seat euro.
v8truckin is offline Find More Posts by v8truckin
Old Nov 09, 2012, 10:33 PM
acesimmer's Avatar
Joined Oct 2011
Yep... Two seater it is. I like the way it looks and just imagine two pilots with backlit instruments and all that detail. A larger canopy to look in to. To me it just as more presence.
Old Nov 10, 2012, 02:49 AM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Very nice indeed I'm in
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Nov 11, 2012, 12:26 AM
Elec 1800 is offline
Find More Posts by Elec 1800
Flying 2 Fight Cancer
Elec 1800's Avatar
corona, ca
Joined Feb 2011
Wow very nice work
Elec 1800 is offline Find More Posts by Elec 1800
Old Nov 11, 2012, 09:06 AM
acesimmer's Avatar
Joined Oct 2011
I'm up at 5am turning the heat on in the shop. It is bloody cold at 18 deg. So will let the shop warm up for two hours. Time to layup the first part of the mold. I'm working from front to back then will do the reverse side in the same order.
Will take a day off and let it really cure. Then will remove the rear end parting plane and add the full rear parting planes on Monday. Will then wax and PVA the plug and layup the rear section Tuesday as it is getting a bit warmer.
How I do it.......
Several coats of mold release wax
two coats of PVA release agent shot with an air brush to keep it thin
Allow PVA to dry an hour or so when temps are not very high.
I start my layups with a couple of thin tool coats then 3/4oz cloth in all the corners and sharp edges. I then place several more 2oz bits in the same areas. I then cover the entire plug with 2oz in a couple of layers to hide any possible weave bleed through. Then several layers of 6oz. Finally I use a bunch of stranded mat to build up the final strength of the mold. I wait until slightly tack between the tool coats. Once this is applied its off to the races and just keep laying up.
It takes a long time to lay up a mold. I began the actual layup at 8:30 am with the tool coat. 11am for the second tool coat. 1pm with the first layers of 3/4oz 2oz, 6oz then mat and finally completed by 7:30 pm. Once I start with the cloth it is continuous except for the odd pee break and a coffee. Having the shop at 80 deg I am able to work around the plug laying up each layer. By the time you have one layer done the other end is tacky and ready for the next. If you stop and the epoxy hardens then you would have to re-sand the entire work before starting again.
If you are wondering what those blue stickup things are it is the tire air valve stems that I previously mentioned. I can shoot compressed air deep into the inner cavities that will help break the seal and loosen the mold from the plug. This really helps in releasing the final part layup from the molds without having to bang and tweak to get the parts out.
Old Nov 11, 2012, 09:55 AM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Awesome ace!
I know what you mean. By the time I get done laying up a mold my feet are killing me. Numerous smoke and coffee breaks or I wouldn't last through the process.
Really enjoying it, keep the info coming.
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: AJ-2 Savage
Old Nov 11, 2012, 10:12 AM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
What strand mat did you use that works well with epoxy?
wyowindworks is offline Find More Posts by wyowindworks
Old Nov 11, 2012, 01:42 PM
acesimmer's Avatar
Joined Oct 2011
No idea. It was given to me. It may be around 40 oz weight or so. It is the stranded stuff used to build boats and kit cars with. I only use it on the outer mold surface after the cloth for beefing up. It is so thick I have to pull it apart to loosen the weave.
Old Nov 11, 2012, 01:48 PM
A10FLYR is offline
Find More Posts by A10FLYR
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
I'm up at 5am turning the heat on in the shop. It is bloody cold at 18 deg. So will let the shop warm up for two hours. .
18 inches of snow and 18º......and where is this?
A10FLYR is offline Find More Posts by A10FLYR
Old Nov 11, 2012, 02:39 PM
Willsonman is offline
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
So when can these be purchased? J/K seriously nice work. I always stand in awe of those who attempt this work. lots of work and patience go into this sort of thing but what an outcome!
Willsonman is offline Find More Posts by Willsonman
Old Nov 11, 2012, 02:50 PM
Just fly it!
Cody, WY
Joined Nov 2007
Interesting. Most strand mats work very poorly with epoxy because the resin doesn't break down the binder. The styrene in a polyester or vinyl ester will break down the binder very easily.
Build Log Molded tails with expanding foam core tzyoung Hand Launch 45 Nov 16, 2012 07:32 PM
Wanted Composite/foam or hollow molded Fin/Rudder Ne-Aero Aircraft - Sailplanes (FS/W) 2 Mar 01, 2011 02:38 PM
For Sale 3 x custom TabooGT models (std, disser + molded tails, narrow wing + foam tails) olgol Aircraft - Sailplanes (FS/W) 6 Mar 05, 2010 07:04 PM
Composite Molding Examples (Full-Scale) Phat2Wheel Composites Fabrication 8 Sep 09, 2004 09:15 AM
hollow mold vs. foam core on scale plane combatflier Composites Fabrication 10 May 11, 2004 03:42 PM
