Old Jan 14, 2013, 11:30 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Will be nice to see your results on the Dinogy packs.
Mark sent me a 3S 2250mAh a few months ago and so far it's the real deal. After 3-1/2 months and 23 discharges all cells are still at 4mOhm as measured by my 306B. Hoping it'll still be doing well after it is more than a year old and over 100 discharges.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 15, 2013, 01:31 PM
MCSGUY is offline
Find More Posts by MCSGUY
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Good Feedback, it's nice to have high quality packs available at reasonable prices.
MCSGUY is offline Find More Posts by MCSGUY
Old Jan 15, 2013, 01:45 PM
rcalldaylong is offline
Find More Posts by rcalldaylong
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
Mark
Mark,
what kind of amps are you pulling from these packs?
rcalldaylong is offline Find More Posts by rcalldaylong
Old Jan 19, 2013, 05:46 PM
MarkF is online now
Find More Posts by MarkF
Battery Puffer
United States, NV, Las Vegas
Joined Nov 2001
Im glad to see the packs made it to you Joe. I look forward to your testing. I wanted to answer a question from an earlier post about sending special packs. I am just a distributor of these packs and have no testing equipment other that my TP 820. I want the results giving hear to be exactley what you would get from the packs you buy from me and test for yourself. I believe it does no good to stack the deck if you want your customers to stay your customers.
Mark
MarkF is online now Find More Posts by MarkF
Old Jan 19, 2013, 05:51 PM
So. Cal.
Originally Posted by rcalldaylong View Post
Mark,
Sorry that I missed your query earlier.
I don't have an in-flight logger but I run them wide open for ~4 minutes in my PZ Gunfighter and this takes me to about 80% DOD. So, doing quick math, I'm running them at ~12C continuous, or about 27 amps.
Mark
Old Jan 19, 2013, 08:30 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Mark
Yep, you sent me off the shelf brand new packs with a couple three light duty break in cycles on them. John at Revolectrix recently posted a good case that the newest packs don't need the break in process. I guess better safe then sorry.
Old Jan 20, 2013, 06:00 PM
djmoose is online now
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Awesome stuff MCSGUY. Is there any chance you recorded your findings at the lower amp runs? I know you said that they all performed about the same, but I like seeing numbers. If you don't, it's all good. I was curious on the different temps across these packs at 75-100A.
Thanks so much for this!
djmoose is online now Find More Posts by djmoose
Old Jan 20, 2013, 06:34 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Thanks for the interest, here's the whole series:
Old Jan 20, 2013, 07:57 PM
MarkF is online now
Battery Puffer
Joined Nov 2001
This is the best testing I've ever seen. Good job MCSGUY. This to me trully shows a packs performance. It looks like revo packs are the winner to me next to TP.
Mark
Old Jan 20, 2013, 10:14 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Thanks Mark, I can't wait to get started on the Dynamic load testing, that should be more revealing since I will also be recording the maximum static thrust put on the jet plus a running tally of the amps and voltage for 60 second at WOT.
Old Jan 28, 2013, 10:24 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
wow this is great info!!!!
jcdfrd is offline Find More Posts by jcdfrd
Old Jan 28, 2013, 10:40 PM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Alot of work but it's worth it to know the real scoop. I also believe the dynamic testing will be very revealing.
Old Jan 29, 2013, 10:23 AM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
Nice work, great testing methodology!
I have 2 comments, first, having Thunder Power packs with 250+ cycles and still going strong, you should try and do the same testing after extended usage as value only comes into play after you use them (if some fail on use # 20, is there still value?) and second, you should re-calculate the number with the TP interconnect changed to 6mm, Thunder Power only puts that there for shipping purposes and if not there, the numbers would be better (though you can blame them for the 4mm bullets melting in the first place for sure!). Nice job...
Jack
jfetter is offline Find More Posts by jfetter
Old Jan 29, 2013, 11:02 AM
MCSGUY is offline
aka JetMan Joe
MCSGUY's Avatar
Joined Feb 2010
Thanks Jack, you're absolutely correct. Repeat testing down the road is essential.
Your right about the 6mm also. I did not discover the flaw until the 180A test so it's the only one taken with the 6mm connector and I noticed a ~5% increase in output after I changed the connector.
Old Jan 29, 2013, 12:48 PM
jfetter is offline
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
I am going to e-mail Bob Burns @ TP and mention the interconnect was an issue and see what he says. I know why they do it and it can come in handy when shipping but upping their hardware to 6mm can't hurt either. I'll be watching this testing with interest!
Jack
