Old Jan 23, 2013, 12:40 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
In a 12, the next step up is a 12x8, but at 900kv on 4S you're going to over amp it. I'd
try an 11x7. ecalc says 3.2Kg of static thrust and 78mph pitch speed.
ian
Daemon is online now Find More Posts by Daemon
Old Jan 23, 2013, 12:52 PM
octane81 is offline
Find More Posts by octane81
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Nobody using the 830kv Tmotor from fpvmodels?
since they sell it with the model , i would think that was a good motor?
octane81 is offline Find More Posts by octane81
Old Jan 23, 2013, 01:12 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
the 800kv motor is more then enough power for mine
rclab1 is offline Find More Posts by rclab1
Old Jan 23, 2013, 01:40 PM
octane81 is offline
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Originally Posted by metalbender4by View Post
What is every body getting for weight? Mine is 4 lb's 3 oz's with no batteries and 5lb's 9oz's ready to fly. That's with one 5000 4 cell and a 600 3 cell.
Just put mine on the scale , and it weights 2.4kg (no idea what thats in lbs and ozes) with 10.000mAh 4S.
I still need to add OSD, vTX and a small video battery.
Guess I end up at around 2.6kg when ready to fly.
Old Jan 23, 2013, 01:45 PM
octane81 is offline
RTFM
octane81's Avatar
Antarctica
Joined Oct 2010
Are you using the 830kv Tmotor? what size prop?
Old Jan 23, 2013, 05:44 PM
rclab1 is offline
USA
Joined May 2010
octane81,
I use these two motors with 12x8 APCe, 4s-5700mah Lipo (80amp ESC).
http://epbuddy.com/index.php?main_pa...roducts_id=187
and
http://www.hobbypartz.com/96m603-big...826-870kv.html
both are unlimited vertical and can go on forever!!!!!
Old Jan 23, 2013, 07:32 PM
metalbender4by is offline
Find More Posts by metalbender4by
hey whats burning?
metalbender4by's Avatar
United States, FL, Vero Beach
Joined Oct 2007
That's about 5lb's 3oz and 5lb's 7oz.
metalbender4by is offline Find More Posts by metalbender4by
Old Jan 23, 2013, 09:30 PM
Issus is offline
Find More Posts by Issus
Issus's Avatar
Joined May 2012
I have two 5800mAh 4S batteries with different C ratings and different labels (one zippy compact, one zippy flightmax). Can I use these in parallel together safely for powering my skyhunter?
Issus is offline Find More Posts by Issus
Old Jan 23, 2013, 09:37 PM
CambriaHobby is offline
Find More Posts by CambriaHobby
United States, CA, Ventura
Joined Dec 2012
ian
Thanks Ian
Ill try the 11x7 pusher
CambriaHobby is offline Find More Posts by CambriaHobby
Old Jan 23, 2013, 09:43 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
With electrics pusher/puller designation is irrelevant.
Old Jan 23, 2013, 10:00 PM
Joined Dec 2012
Old Jan 23, 2013, 10:11 PM
jayb1rdz is offline
Find More Posts by jayb1rdz
Never fly an A model anything!
jayb1rdz's Avatar
Antarctica
Joined Apr 2008
Originally Posted by CambriaHobby View Post
Thanks Ian
E-Calc will say that a lot of the set-ups you see with FPV are over amping the motor as it makes the determination on the assumption that the motor will be operating at or near WOT. You will also see the flight times (and mixed flight times) are also of much shorter durations than usual FPV missions.
Most of us cruise at a fraction of the maximum operating capabilities of the motor so something what is marginal on E-calc might actually be in the sweet spot for efficiency
jayb1rdz is offline Find More Posts by jayb1rdz
Old Jan 23, 2013, 10:29 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
While it is true that most don't run at full throttle all the time, I've seen several ESCs
literally in flames due to being over amped after only moderate length runs at full
throttle. That and a few cooked motors.
The numbers for 4S 900Kv on a 12x8 prop are really over the top.
ian
Old Jan 23, 2013, 10:46 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
As long as you're not getting close to the C rating limit of either battery, they don't need to be perfectly matched. Use what you have I say.
subsonic is online now Find More Posts by subsonic
Old Jan 23, 2013, 10:55 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
. Actually, in series I would say its essential , in parallel, not as important.
OzparkPilot is offline Find More Posts by OzparkPilot
Discussion Discrimination against individuals professing strong belief in the supernatural? H2SO4 Life, The Universe, and Politics 66 Jan 04, 2016 11:20 PM
New Product New FPV PLANE: Bormatec FPV rclab1 FPV Aircraft 108 Mar 16, 2014 09:29 AM
Cool Skyhunter - New 1.8m twintail FPV/UAV EPO platform vigor FPV Talk 58 Nov 26, 2012 06:54 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd Aircraft - Electric - Airplanes (FS/W) 3 Mar 09, 2012 10:22 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd FPV Equipment (FS/W) 5 Mar 06, 2012 08:01 PM
