Old Jan 03, 2013, 04:13 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Originally Posted by jayb1rdz View Post
It's just a beer cooler with wings !
That's what I call any foam airplane these days. Beer cooler with a motor! I'm sure the SH will hold one of those Fosters Mini Kegs!
typicalaimster is offline Find More Posts by typicalaimster
Old Jan 03, 2013, 08:51 PM
Joined Jan 2005
Here's another video from the SH. Today I was testing out the new 5.8ghz TX I picked up about the same time the SH showed up. After adding the TX to the SH I ended up scooting my battery back about a 1/4". I could probably stand to take it back some more. At this rate the battery is moving pretty close to the CG of the SH.
Skyhunter 3 views... (0 min 58 sec)
I have more OSD video I can post, but it's pretty dull..
Old Jan 03, 2013, 10:33 PM
CambriaHobby is offline
Find More Posts by CambriaHobby
United States, CA, Ventura
Joined Dec 2012
[QUOTE=typicalaimster;23704604]Here's another video from the SH. Today I was testing out the new 5.8ghz TX I picked up about the same time the SH showed up. After adding the TX to the SH I ended up scooting my battery back about a 1/4". I could probably stand to take it back some more. At this rate the battery is moving pretty close to the CG of the SH.
Is you CG at 95mm? where the servo wires lay in the wing?
CambriaHobby is offline Find More Posts by CambriaHobby
Old Jan 03, 2013, 11:10 PM
Joined Jan 2005
It's about a finger tip away from that line. I'll probably move it back to that point the next go around. Usually I feel for that spot then move forward off the ledge.
Old Jan 03, 2013, 11:44 PM
dk31 is online now
Find More Posts by dk31
dk31's Avatar
Athens
Joined Oct 2009
Originally Posted by typicalaimster View Post
I guess we'll find out this summer when Skyhunters start falling out of the sky.
lol.
The question was not a joke. I'm just wondering if there's any point in painting/covering these black EPO planes. Temperatures here average 30C in summer. I know ESC and bec will be burried under the foam so they ll be insulated, but what about the gps? Also woried that the plane itself might become more flexible.
dk31 is online now Find More Posts by dk31
Old Jan 03, 2013, 11:53 PM
Cathay Stray is offline
Find More Posts by Cathay Stray
Flying Zayin
Cathay Stray's Avatar
China, Guangdong, Guangzhou
Joined May 2012
Originally Posted by dk31 View Post
lol.
I wasn't joking either. Temperature in the place where SH is designed and produced (and test-flown) in summer is often well over 30, plus 90+% humidity. Temperature in the place where I live is generally over 30 May-October, last summer was quite some hell with 35+ for a few weeks in a row, 90ish humidity. Pilots sweat, planes fly. Haven't heard of any crash due to overheating.
Cathay Stray is offline Find More Posts by Cathay Stray
Old Jan 04, 2013, 12:32 AM
dk31 is online now
dk31's Avatar
Athens
Joined Oct 2009
Glad to know. Painting black foam would be time consuming
Old Jan 04, 2013, 12:59 AM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
http://www.youtube.com/watch?v=ZQ4EgHJcTH0
Two things.
1. You've got a ghosting artifact. If using Sony Vegas, right click on all clips, and select
Switches - Disable Resample. Otherwise make sure project and render
frame rate, matches source clip frame rate exactly.
2. The view is shaky as though there's constant vibration, but I don't see the usual
jello artifact. Rendering glitch?
For whatever it's worth, CG at 93-95mm doesn't feel "on the edge" to me at all.
I am a bit puzzled as to why you're having to move your battery back so far to get there.
Mine is still a good distance forward of the CG and I've got flight camera + pan&tilt
and gopro on pan, all ahead of the CG, and my tail group is further forward than yours.
You carrying some other brick in the nose?
ian
Daemon is offline Find More Posts by Daemon
Old Jan 04, 2013, 10:08 AM
Joined Jan 2005
Originally Posted by Daemon View Post
Two things.
Good to know on the Vegas stuff since I just switched over to it. By what I ment with 'on the edge' is on the edge where the servo wire cut is at. I'm on the edge of cutout. Should have been more specific and just measured it. The brick I'm carring is the cased GoPro. Having a 6oz brick vs a 3oz camera in the front doesn't help. All in good fun!
Old Jan 04, 2013, 05:22 PM
BldrFlyr is offline
Find More Posts by BldrFlyr
BldrFlyr's Avatar
United States, CO, Boulder
Joined Nov 2012
No. Epoxy does not bond to EPO very well, and it makes a brittle joint.
If you want more time to align, use the stock contact adhesive.
This fuse locks together really well (lots of little alignment tabs and dimples), so
I didn't have any issues getting it aligned in time with thick CA. The kicker is applied to
one side and left to evap for a few minutes, then thick CA on the other side, and
press together.
ian
What glue are you guys using to join the wood motor mount to the fuselage? thx
BldrFlyr is offline Find More Posts by BldrFlyr
Old Jan 05, 2013, 11:03 AM
wingnutt is offline
Find More Posts by wingnutt
Will work for foam
wingnutt's Avatar
United States, WI, Muskego
Joined Apr 2005
How well does it transport? I have a twin boom (not removable) and it gets cumbersome.
wingnutt is offline Find More Posts by wingnutt
Old Jan 05, 2013, 01:01 PM
Joined Dec 2012
Wingnutt
Here is how I transport it.
The holder turns into a stand when I flip it over
Mark
Old Jan 05, 2013, 01:45 PM
rcmonster99 is online now
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
Wingnutt
Mark
blimey !! that's one hell of a stand !!
rcmonster99 is online now Find More Posts by rcmonster99
Old Jan 05, 2013, 02:57 PM
Joined Dec 2012
It works great. I use the same Velcro strap for storage over the nose and also when I have it on the stand for assembly and preflight testing. Stand/holder is only 19" tall and it protects the plane. Especially the tail section.
Old Jan 05, 2013, 05:48 PM
BldrFlyr is offline
BldrFlyr's Avatar
Joined Nov 2012
Great holder Mark. Can you give us specs on it so we could build one?
Discussion Discrimination against individuals professing strong belief in the supernatural? H2SO4 Life, The Universe, and Politics 66 Jan 04, 2016 10:20 PM
New Product New FPV PLANE: Bormatec FPV rclab1 FPV Aircraft 108 Mar 16, 2014 08:29 AM
Cool Skyhunter - New 1.8m twintail FPV/UAV EPO platform vigor FPV Talk 58 Nov 26, 2012 05:54 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd Aircraft - Electric - Airplanes (FS/W) 3 Mar 09, 2012 09:22 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd FPV Equipment (FS/W) 5 Mar 06, 2012 07:01 PM
