Old Mar 25, 2014, 09:27 PM
ls1elite is offline
Find More Posts by ls1elite
ls1elite's Avatar
United States, FL, Miami
Joined Oct 2012
[QUOTE=Daemon;27895869]I mean, the optimal CG is back around the servo wires, and when you put two
4S 5000 packs in it, they will have to be slid back almost completely out of sight
under the gear tray to maintain that optimal CG. If the batteries are forward
of that , it will likely be nose heavy, and inefficient thus burn more power.
Having an optimal CG is more important than the prop choice.[/QUOTE
ok understood now thanks for the help
ls1elite is offline Find More Posts by ls1elite
Old Mar 25, 2014, 11:03 PM
melsailsnorth is offline
Find More Posts by melsailsnorth
Fight for the Right to FPV!!!
melsailsnorth's Avatar
United States, CA, Chico
Joined Dec 2010
Originally Posted by ls1elite View Post
yes 4s. and what do you mean prop keeping it from running nose heavy
If you try the manufacturer's recommended CG you will probably find it horribly nose heavy and inefficient. With CG around the servo wire it flies great and and darn good efficiency. Unfortunately, as Daemen points-out, the batteries are WAY back under the tray and a real PITA to get out to charge (using 10-13AH 4S) . I started-out with a lipo strap but quickly changed to just using a long patch of velcro lining the bottom of the fuselage (under the tray). Was concerned about possible shifting of the lipos during flight but hasn't been a problem yet and a heck of a lot easier then having to remove the wings every time I wanted to swap or charge lipos.
melsailsnorth is offline Find More Posts by melsailsnorth
Old Mar 26, 2014, 12:06 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya, I've always just used a strip of velcro on the bottom of the fuse, and no strap.
I don't spend a lot of time trying to pull negative Gs while loaded up with 10Ah of batteries.
Never had em move in anything short of a full on crash, which is when
you want em to let loose anyway.
Daemon is online now Find More Posts by Daemon
Old Mar 26, 2014, 06:29 AM
skyhunter_1 is offline
Find More Posts by skyhunter_1
FPV Engineer
skyhunter_1's Avatar
China, Fujian, Xiamen
Joined Nov 2012
Hello everybody!! We are thinking of closing this thread and moving to a new thread located here,
http://www.rcgroups.com/forums/showt...4#post27896134
Opinions???
skyhunter_1 is offline Find More Posts by skyhunter_1
Old Mar 26, 2014, 07:20 AM
farmertom is offline
Find More Posts by farmertom
My planes plow into the field
farmertom's Avatar
United States, TN, Taft
Joined Oct 2012
Opinions???
For what reason? I vote no. There is a lot of good advice new user may miss if the thread is moved.
farmertom is offline Find More Posts by farmertom
Old Mar 26, 2014, 09:07 AM
DaaBears is offline
Find More Posts by DaaBears
Santi
DaaBears's Avatar
United States, MO, Clayton
Joined Nov 2003
Opinions???
Seems pointless in my opinion. Keep this thread going.
DaaBears is offline Find More Posts by DaaBears
Old Mar 26, 2014, 09:46 AM
bparini is offline
Find More Posts by bparini
bparini's Avatar
Paraguay, Central, Lambare
Joined Mar 2013
Opinions???
Keep this thread!. If you have any update or new version of the SH, update your first post or title.
Regards,
Bruno
bparini is offline Find More Posts by bparini
Old Mar 26, 2014, 10:00 AM
bparini is offline
bparini's Avatar
Joined Mar 2013
Can work this battery http://www.rangevideo.com/en/4s/315-...tery-pack.html with the SH?
GEB8043125. Ultra high energy density 260Wh/kg. 1C standard discharge, 2C maximum discharge, 3C for 3 second bursts. Charge at 0.5C
Dimensions: 120 x 45 x 140mm
Weight: 1360g
SH setup:
T-Motor AT2820 KV830
ESC: 60A
Prop: 12x8 APC
Servo: emax es08md digital metal micro servo 12g
Regards,
Bruno
Old Mar 26, 2014, 12:27 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Opinions???
As others have said, just update the first post of this thread with your new info.
You can even change the thread title from Advanced editing mode, although
it's best not to confuse people too much with meaningless title changes for
marketing purposes only. This thread's title is simple and to the point.
Definitely do not close this thread. If you do, we'll start a new one
that you do not control and move discussion there.
BTW, I see nothing in your new thread to indicate what makes the 2014 version
any different than the one before it. I, as a consumer would want to know
that (pics and description) before anything else.
Old Mar 26, 2014, 12:49 PM
Noircogi is online now
Find More Posts by Noircogi
United States, CA, Pleasanton
Joined Feb 2013
I agree, no reason for a new thread. This one has all of the user info. What we really want to know is what's new?
Did you improve the plastic brackets so the plane can look symmetrical?
Did you put holes in the flat surfaces of them for better glue purchase?
Did you strengthen the tail or the "pods" on the wind where the tail booms connect?
Is there a provision for rudders?
How about including pre-made servo extensions?
Those are just a few "improvements" which (aside from the rudders at least) would be welcome by all.
Noircogi is online now Find More Posts by Noircogi
Old Mar 26, 2014, 04:56 PM
ls1elite is offline
ls1elite's Avatar
Joined Oct 2012
no reason to move the thread !! :-)
Old Mar 26, 2014, 08:54 PM
FPV Engineer
Joined Nov 2012
Your points are understood. I was thinking this thread is very long and maybe confusing for people to look through but I did want to ask before doing so. Seems as if we'll leave it open. The plane is continuing the same design for now. If we make changes in the future, maybe that will be the time to start a new discussion.
Old Mar 26, 2014, 09:29 PM
ls1elite is offline
ls1elite's Avatar
Joined Oct 2012
quick question since ive been wondering about this .im using a 5v bec and on the output i have it connected to my dragonlink receiver and i also taped into the the bec output and connected it to my storm osd. is this ok to do ? or do you guys recommend i run a separate bec ? i want to make sure when my skyhunter arrives i install and run everything the best possible way, i have not had any problem running it this way in my skywalker, phantom fx wing or mini talon . but i want to outdo myself with the build on my skyhunter and have everything perfect. thanks again guys.
Old Mar 26, 2014, 10:42 PM
mccallum is offline
Find More Posts by mccallum
Joined Aug 2012
Sent email to skyhunter-rc.com about what was different with the new version. This is what they replied.
"There have been some rumors about the plane. At this moment there is no difference. It's just a continuation of the plane that many users already love. We do want to update the plane but are currently going over possibilities, this will take sometime and is not expected in the near future. "
So there you go. Same SH
mccallum is offline Find More Posts by mccallum
Old Mar 27, 2014, 02:54 PM
farmertom's Avatar
Joined Oct 2012
DIY SkyHunter Clone
Hi,
First let me say this maybe not is the correct thread for this but this thread inspired me to do it. Some how I got a wild hair to stick build a Skyhunter clone, designing it to be cut with my CNC machine. The plan is to build a sturdier SH with landing gear option, roomer/ easier to get at the batteries, RX, Autopilots, cameras, etc. I plan to cover the entire plane with fiberglass/Kevlar. But I get ahead of myself.
What I want to share is my progress so far. Hopefully the photos will explain it all.
This is still an Alfa version, just see how things go together and help me visualize it for further designs. So far I have the wings built, need to add mounting hardware and servos. Fuselage is close but I need to design some changes. Enjoy the photos.
Comments and suggestions are always welcome.
farmertom
New Product New FPV PLANE: Bormatec FPV rclab1 FPV Aircraft 109 Jul 12, 2016 02:36 AM
Discussion Discrimination against individuals professing strong belief in the supernatural? H2SO4 Life, The Universe, and Politics 66 Jan 04, 2016 10:20 PM
Cool Skyhunter - New 1.8m twintail FPV/UAV EPO platform vigor FPV Talk 58 Nov 26, 2012 05:54 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd Aircraft - Electric - Airplanes (FS/W) 3 Mar 09, 2012 09:22 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd FPV Equipment (FS/W) 5 Mar 06, 2012 07:01 PM
