Old Sep 18, 2013, 01:44 PM
geives1 is offline
Find More Posts by geives1
United States, IL, Hinckley
Joined Jan 2011
I to run the SII 3026 890Kv scorpion on a 75amp Castle esc. However, I use a single 4S 5000mah turnigy pack spinning a 12 x 6 graupner folding prop. I have no issues what so ever and it returns 20min flight times no problem.
Originally Posted by gazdxb View Post
Hi All
firstly thanks for posting so much info on the thread has really helped but I am facing a couple of issues.
setup is
scorpion sii 3026 890 kv motor 75 amp tunigy dlux esc 4s 2 p 6000 mah turnigy dmh211 servos bevrc vtx rfd900 modem and sherer uhf still to be fitted
flying at sea level
complete apm 2.6 with airspeed
have run a 12x 8 prop but it seriously over amped the esc so now running 10x6 or 10x7 but considering a 11x4
I believe the 3s set up would work with a 12x6 and be slightly lighter
any views plane flys well on 4 s but seems very heavy also do you think the bigger prop gives better low end cruising power I am trying to get long range
any thoughts welcome
typicalaimster have you got autoland working and if so what flare angle and time are you using the plane likes to glide for a long time
what would you say the stall speed is I am around 8 m/s
geives1 is offline Find More Posts by geives1
Old Sep 18, 2013, 02:29 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Can anybody post a picture on how they mounted their dragonlink receiver and antenna into their Skyhunter?
I bought this to use:
http://www.readymaderc.com/store/ind...oducts_id=1615
blueprint is offline Find More Posts by blueprint
Old Sep 18, 2013, 02:42 PM
Bigshow4u is offline
Find More Posts by Bigshow4u
Broke RC Pilot
United States, IN, Swayzee
Joined Aug 2011
Sorry I don't have a pic but I purchased the longest antenna and mounted the Rx on the wood tray then ran the antenna down the wing.
Bigshow4u is offline Find More Posts by Bigshow4u
Old Sep 18, 2013, 07:07 PM
ecworks is offline
Find More Posts by ecworks
Marshall Islands, Enewetak Atoll
Joined Sep 2011
I installed Rangelink rx buried into the lower surface of the right wing in line with the boom, with the antenna further out on the wing. This involved a lot of servo wires going back into the fuselage but it kept the rx as far away from all the electronics, video, camera as possible.
ecworks is offline Find More Posts by ecworks
Old Sep 18, 2013, 08:51 PM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
You using Kevlar veil/tissue to stiffen your inboard wing section?
BravoGolf is offline Find More Posts by BravoGolf
Old Sep 19, 2013, 12:19 AM
ecworks is offline
Joined Sep 2011
Kevlar there and at the tail joint
Old Sep 19, 2013, 12:38 AM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Thanks!!
Old Sep 19, 2013, 07:04 AM
Casey101 is offline
Find More Posts by Casey101
OpenTx University *****
Casey101's Avatar
United States, NJ, Clinton
Joined Aug 2013
ecworks,
What is the advantage of what you did to mount the Rx verses running an antenna line out to the wing and placing the antenna out there and leaving the Rx in the fuselage?
Casey101 is offline Find More Posts by Casey101
Old Sep 19, 2013, 08:48 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Can you run PPMSum or something similar back to the Fuse? You can cut the wires down to three. A positive, negative and signal wire. Inside if your AP takes PPM in you can hook up to that. If not there is PPM to Servo converters out there. I've done both a PPM wire and extended antenna mount out on the wing. It seems like the PPM is the cleanest way of doing things vs having to run a long antenna wire from the Fuse to the wing.
typicalaimster is offline Find More Posts by typicalaimster
Old Sep 19, 2013, 10:34 AM
ecworks is offline
Joined Sep 2011
Originally Posted by Casey101 View Post
ecworks,
Advantages: No antenna extensions, away from all other electronics.
Disadvantages: a lot of servo wires going back to fuselage.
I've had the Rangelink rx inside a number of planes including this one and had problems. With this layout everything is working great.
Old Sep 19, 2013, 10:35 AM
ecworks is offline
Joined Sep 2011
Don't know anything about PPMsum, etc. Sounds like a good idea though.
Old Sep 19, 2013, 10:53 AM
Dan777 is offline
Find More Posts by Dan777
Shakopee, MN
Joined Aug 2004
I am using a 15" antenna mounted like this with the Dragonlink receiver right at the end of the plywood platform. Probably not the best for really long range but it works well for my flying. I have had it out 5+ miles with good Rssi left.
Dan777 is offline Find More Posts by Dan777
Old Sep 20, 2013, 02:12 AM
Crolaser is offline
Find More Posts by Crolaser
Crolaser's Avatar
Croatia, City of Zagreb, Zagreb
Joined May 2013
I am using ppmsum whit my rangelink lrs .it is very simple to connect and on my rangeling rx which is on the end of wings going just 2 wires .
I have same solution on x8 and on skyhunter and all works perfect .
http://www.foxtechfpv.com/rmilec-ppm...ter-p-403.html
Crolaser is offline Find More Posts by Crolaser
Old Sep 20, 2013, 10:23 AM
fliteevolution is offline
Find More Posts by fliteevolution
fliteevolution's Avatar
United States, CO, Boulder
Joined Apr 2013
We mount the DL rx on the back of wood tray then route the Dipole wire through the back of the fuse, out a hole, and attach the antenna vertically to the back per the picture.
fliteevolution is offline Find More Posts by fliteevolution
Old Sep 20, 2013, 11:36 AM
Jengaleng is offline
Find More Posts by Jengaleng
United States, PA, Norristown
Joined May 2012
Are there any sellers of replacement sky hunter parts?
I know foam can be repaired but we had a bad hand launch(stalled) and ripped the horiz stab to shreds
Jengaleng is offline Find More Posts by Jengaleng
Discussion Discrimination against individuals professing strong belief in the supernatural? H2SO4 Life, The Universe, and Politics 66 Jan 04, 2016 10:20 PM
New Product New FPV PLANE: Bormatec FPV rclab1 FPV Aircraft 108 Mar 16, 2014 08:29 AM
Cool Skyhunter - New 1.8m twintail FPV/UAV EPO platform vigor FPV Talk 58 Nov 26, 2012 05:54 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd Aircraft - Electric - Airplanes (FS/W) 3 Mar 09, 2012 09:22 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd FPV Equipment (FS/W) 5 Mar 06, 2012 07:01 PM
