Old May 24, 2013, 03:16 PM
tupelo is offline
Find More Posts by tupelo
tupelo's Avatar
Finland, Uusimaa, HKI
Joined Feb 2008
Originally Posted by Daemon View Post
Dunno how you pulled that off. Mine will fly with a single 3S 4000 battery
and it's still several inches back from the nose. A single 3S 5000 is
more than halfway under the wing, and 2x4Ah or 2x5Ah are pretty much
entirely under the wing. The only weight up front is GoPro (not in its case)
on a pan servo.
So it sounds like a heavy servo in the tail makes sense. Especially if one files with 3s 5Ah x 2 and a Gopro3 - in its case. I am afraid to fly my brand new 3 Black edition without itīs protective case you see.
tupelo is offline Find More Posts by tupelo
Old May 24, 2013, 09:12 PM
KeithLuneau is offline
Find More Posts by KeithLuneau
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
Originally Posted by timtimtim View Post
How many mm is that? 80mm?
75-80, which may still be a bit nose heavy but it flies so good I just left it alone after the maiden flight.
KeithLuneau is offline Find More Posts by KeithLuneau
Old May 24, 2013, 10:32 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
That is pretty nose heavy. It flies a lot more efficiently with it moved back
with less tendency to nose up at higher speeds, and it does not get pitchy at high
speeds with the CG back, like the Skywalker does.
Daemon is online now Find More Posts by Daemon
Old May 24, 2013, 11:18 PM
Joined Jan 2002
That's the thing though, mine flies great with the CG on the spar. Pitch trim remains the same from 25mph to 60, and it only needs a touch of "down" to fly inverted. It will already match my Skywalker 1900 in terms of efficiency, if not beat it.
All that said, maybe it's just that the RVOSD masks any nose-heavy characteristics... lol I do tend to fly in FBW more often than not.
Old May 24, 2013, 11:23 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes, FBW will mask all ills.
I started with the CG at stock recommended 75mm and going slow it wanted to fall
on its face, and going fast it wanted to pull up hard. That's classic nose heavy
symptoms. Moved it back over a few flights and it got more and more
neutral and efficient, but will still cruise pretty much hands off.
Old May 25, 2013, 03:39 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
I can sort of figure most of it out, but it would sure be nice if there were instructions on how to assemble the FPV Models pod kit and GoPro gimbal. Anyone have anything?
eroeder is offline Find More Posts by eroeder
Old May 25, 2013, 03:50 AM
timtimtim is offline
Find More Posts by timtimtim
Joined Apr 2012
But i cant get why my SH is so heavy in the back? is it becuase i dont have a gopro on the front or why? but i will maiden her with battery in front and cg about 95mm, im still a little worried about launch and that prop.. hopefyllt i will have all my fingers left when i throw 1.9kg in the air
timtimtim is offline Find More Posts by timtimtim
Old May 25, 2013, 08:21 AM
gtlavin56 is offline
Find More Posts by gtlavin56
Joined Oct 2011
Thanks Fransbr
Yes 2 1000mW each @ 1.3 GHz, I just installed a video splitter, yes I use Gopro2 for OSD and recording, shielded with cooper foild, 3 blade prop 12x6, 50 Amps peak, 60 A ESC, 32 770 turnigy motor easy match, eagletree OSD, Dragon Link, 16000 mah battery 14.6 volts, BEC 6 volts with 1500 mah battery, 11.1 v, ominidierctional anntena and skew planar.
Ground station is eagleeyes,telemetry and diversity, yagi 13 dBi, skew plannar antenna, 2 receivers with saw filter.
One transmitter @ 1280, anotherone @ 1360. All system ground tested, unfortunately there is too much wind today, so I quit to test it! I hope there will be better weather conditions tomorrow, let you know if there is not any kind of interference in the air
Should be fine with this set up, right? I hope!!!!
gtlavin56 is offline Find More Posts by gtlavin56
Old May 25, 2013, 09:51 AM
Nereth is offline
Find More Posts by Nereth
Joined Jun 2012
I know this has been asked before, but where are all your tails located on the tail booms? They're not at max length are they?
Nereth is offline Find More Posts by Nereth
Old May 25, 2013, 10:42 AM
xxkiloxx is offline
Find More Posts by xxkiloxx
United States, Mt, Helena
Joined Mar 2005
Originally Posted by webdr View Post
Tim, if you take the prop off and still have the vibes as you described, balance the motor can with a piece of tape.
If you take the prop off and run it up, and the vibes stop on the Z axis, you will need to keep working on that prop. Check your tip as well as hub balance, and make sure the prop tracks straight and your motor shaft is 100% straight. Spin the prop while looking at its path against a white wall, if the blades have a slightly different arc, you'll get vibes that will always be there regardless of balance. Take a sanding block and run the base of the hub where it touches the motor over the sanding block. That will take out any flashing lips or high/low spots on the mounting surface. I do this to all my props and always can see the high spot after sanding it. Blade tracking is as important as balance.
you just solved an issue i couldn't track down. Thanks!
xxkiloxx is offline Find More Posts by xxkiloxx
Old May 25, 2013, 12:30 PM
CambriaHobby is offline
Find More Posts by CambriaHobby
United States, CA, Ventura
Joined Dec 2012
Try this out.
It should help.
http://www.cambriahobby.com/misc/Sky...20assembly.pdf
Mark
CambriaHobby is offline Find More Posts by CambriaHobby
Old May 25, 2013, 01:31 PM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
Originally Posted by CambriaHobby View Post
Thanks!
I also appreciate www.cambriahobby.com creating the document!
Old May 26, 2013, 10:49 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Depends on who you ask. I'm flush with the boom holder. Daemon has scooted his tail in a bit so the boom protects the end of the tail.
typicalaimster is offline Find More Posts by typicalaimster
Old May 26, 2013, 11:27 AM
Nereth is offline
Joined Jun 2012
My plane doesn't yet have all its electronics in it yet because of shipping delays (it's been months!) but it's really tail heavy unless I slide the tail well forward. Kind of concerning.
Old May 26, 2013, 12:18 PM
Bauf is offline
Find More Posts by Bauf
Norway
Joined Aug 2011
Mine is so noseheavy.. and the batteries are jammed so far back as it gets. thats with 1 4s 5Ah and 1 3s 2.2Ah. Thinking of putting some lead on the tail, would be nice to not have the batteries so far back..
Bauf is offline Find More Posts by Bauf
Discussion Discrimination against individuals professing strong belief in the supernatural? H2SO4 Life, The Universe, and Politics 66 Jan 04, 2016 10:20 PM
New Product New FPV PLANE: Bormatec FPV rclab1 FPV Aircraft 108 Mar 16, 2014 08:29 AM
Cool Skyhunter - New 1.8m twintail FPV/UAV EPO platform vigor FPV Talk 58 Nov 26, 2012 05:54 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd Aircraft - Electric - Airplanes (FS/W) 3 Mar 09, 2012 09:22 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd FPV Equipment (FS/W) 5 Mar 06, 2012 07:01 PM
