Old Mar 28, 2013, 04:18 AM
Nereth is offline
Find More Posts by Nereth
Joined Jun 2012
I need your opinions guys, how much drag do you think 130mm tall tricycle LG will add to the plane? I am doing the maths right now for 17x12 E vs 16x12E and I have 17x12E edging out on cruise efficiency by a very (very!) slight margin, under the complete ass-pull assumption that the LG will add 10% drag.
What do you guys think? Is 10% too low? Too high? What should I set it to?
Nereth is offline Find More Posts by Nereth
Old Mar 28, 2013, 05:03 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
10% drag with fixed gear is fairly high - Looking at some examples of clean air frames, look at the Glasair FG vs RG.. Just 4 Mph difference with a cruise near 200 Mph. so this works out at just 2% drag. Look at the Cessna 210 vs 182 turbo.. same engine but there is 30 Mph different for a 170 Mph cruise. So around 10% but this is an OLD production aircraft and you should be aiming for 5%. You need to ask yourself, Why am I adding fixed gear ? I think you mentioned because you were intending to build a load carrying long endurance SH... But should you then not be looking at wheel pants.. gear fairings etc ? This will get you near your 5%
OzparkPilot is offline Find More Posts by OzparkPilot
Old Mar 28, 2013, 05:47 AM
Nereth is offline
Joined Jun 2012
I'm adding fixed gear because I find landing and takeoff rolls fun, and it's pretty chunky gear because I don't have much of a smooth surface by the way
4mph difference in speed at 200 works out to ~4% difference in drag by the way, since drag is by square of speed:
204^2*(drag)=200^2*(increaseindrag*drag)
sub the value of 1 into drag and you get increaseindrag=1.0404 i.e. 4.04% (obviously approximate due to other factors we haven't taken into account)
I think it's going to be interesting. What I'm getting here is just a few % increase in efficiency from 17x12 over 16x12, depending on what I am doing at the time (acceleration/cruise/climb). I wander if it will be measurable with the accuracy of my gear. Probably not, so after a few flights it might come down to whether the 17x12 looks dangerously close to booms/overheats the motor/sounds really awesome (which it might do). It has significantly more low speed thrust but I don't really care about that lol, 16x12 has more than enough.
Old Mar 28, 2013, 03:03 PM
fpvnaija is offline
Find More Posts by fpvnaija
fpvnaija
Joined Aug 2012
That eagle squawk at the end is epic.
fpvnaija is offline Find More Posts by fpvnaija
Old Mar 28, 2013, 09:04 PM
Jeffem62 is offline
Find More Posts by Jeffem62
Jeffem62's Avatar
United States, TX, El Paso
Joined Apr 2012
Skyhunter Update on Build
Easy part is pretty much done. Fuselage together, Electronics tray sanded and it fits snug. Built the FPV shelf but Im not going to use the gimbal portion. Only installing pan and tilt for the Camera.
I did put additional carbon fiber bracing on the rear stabilizer elevator area along with the vertical fins. It just seemed to flimsy. Both wings done and booms measured and taped so they fit in the same way each time.
As you can see I used a little bit bigger servo than maybe is needed. Went with HS-85mg's all around. On the tail it sticks out just a little. No big deal in making the holes a bit bigger.
Now using only CA, seems to work much better than epoxy, and its easier. Just need to work fast with it.
I originally laid down Velcro on the bottom of the fuselage. Just took that out. Epoxy gave it up pretty easy. Who ever said the epoxy will crack was correct. Batteries were not sitting correctly. Will make a battery tray that sits on Velcro so I can slide the tray where it needs to be and the battery or batteries will remain secure in the tray. All kinds of room in this build so might as well take advantage of it.
Now its a waiting game. I have one item on backorder with readymaderc and its holding up everything.
Jeffem62 is offline Find More Posts by Jeffem62
Old Mar 28, 2013, 10:38 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
For whatever it's worth, the way I stick velcro down to EPO is by putting
a thin layer of medium or thick CA on the foam (sanded to white foam for these dark
planes), then I spray a little kicker on the back of the velcro and then press it
into the CA. The accelerator makes it cure fast and hot, which activates the
glue on the Velcro backing and it all melts together with the CA and makes
a nice permanent bond. Will not peel off in extremely cold temps like straight
Velcro adhesive will.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 29, 2013, 12:15 AM
Jeffem62 is offline
Jeffem62's Avatar
Joined Apr 2012
Thanks for the ca Velcro tip. Ill do that this weekend.
Old Mar 29, 2013, 10:33 AM
carguy1994ca is online now
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
+1 ! The velcro in my SW kept peeling off after some use. I glued it with a bit of GG on the sides but after some use, want to come off again. Will try the CA.
carguy1994ca is online now Find More Posts by carguy1994ca
Old Mar 29, 2013, 11:22 AM
Matt Gunn is online now
Find More Posts by Matt Gunn
RCGroups Editor
Matt Gunn's Avatar
United States, OH, Parma
Joined Jul 2009
for all you guys with your elevator and servo horns on the bottom of the elevator, try flipping the elevator horn to the top and cutting a slot for the servo horn so the linkage is now above the elevator. That way, you don't snag it on landing if you touch the tail, and it will prevent the servo from stripping the gears.
Matt Gunn is online now Find More Posts by Matt Gunn
Administrator
Old Mar 29, 2013, 12:15 PM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Hmm good point. I bent the excess control rod up toward the tail so it pushes whatever is coming at it down. I'm also using MG servos in my tail. I will admit that I picked up some tall grass on this past landing on the control horn. I'd flip my horn around but I decided to glue it. The screws weren't giving me the warm fuzzies.
typicalaimster is offline Find More Posts by typicalaimster
Old Mar 29, 2013, 12:26 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Ya, this mod has been mentioned a few times before in this thread. I snapped a servo
arm off on a normal landing on a hard surface, because the tail group bumped the ground.
Moved the linkage to the top.
Old Mar 29, 2013, 06:36 PM
Watts up ?
Joined Nov 2006
Got the Video link bugs worked out I think - Here is a video I did last night showing just how fast this SH is and its aerobatic capabilities aswell... No music yet
Skyhunter - FPV flight with aerobatics (12 min 23 sec)
Old Mar 29, 2013, 09:05 PM
tree topper is offline
Find More Posts by tree topper
Joined Feb 2013
tail skids
I glued tail skids on bottom of white plastic tube holder . Made from small dia. music wire solves problem of dragging tail . Works good Bob
tree topper is offline Find More Posts by tree topper
Old Mar 30, 2013, 01:12 AM
farmertom is online now
Find More Posts by farmertom
My planes plow into the field
farmertom's Avatar
United States, TN, Taft
Joined Oct 2012
picture please!
farmertom is online now Find More Posts by farmertom
Old Mar 30, 2013, 03:21 PM
Joined Feb 2013
tail skid
Description:
Description:
Description:
Originally Posted by farmertom View Post
picture please!
Sorry about pic quality not used to camera yet Bob
Discussion Discrimination against individuals professing strong belief in the supernatural? H2SO4 Life, The Universe, and Politics 66 Jan 04, 2016 11:20 PM
New Product New FPV PLANE: Bormatec FPV rclab1 FPV Aircraft 108 Mar 16, 2014 09:29 AM
Cool Skyhunter - New 1.8m twintail FPV/UAV EPO platform vigor FPV Talk 58 Nov 26, 2012 06:54 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd Aircraft - Electric - Airplanes (FS/W) 3 Mar 09, 2012 10:22 PM
Sold Complete FPV Plane, Ground Station, Autopilot, Dual Camera 27x zoom + more NEW crd FPV Equipment (FS/W) 5 Mar 06, 2012 08:01 PM
