Old Dec 22, 2012, 05:04 PM
Harpye is offline
Find More Posts by Harpye
Build it again, Sam!
Harpye's Avatar
Germany
Tried to render this as a little proposal ... Just for fun .. perhaps one day I will make molds but not at the moment!
Harpye is offline Find More Posts by Harpye
Old Dec 22, 2012, 05:53 PM
HELModels is offline
Find More Posts by HELModels
HELModels's Avatar
Joined Aug 2003
OK, you have a good rendering, is there more under the surface?. Are you able to go in and say get a wing section at any point, or a fuselage cross section? Would you be able hypothetically to make plans that could be laser cut or cut from foam, or is that a completely different approach?
HELModels is offline Find More Posts by HELModels
Old Dec 23, 2012, 12:49 AM
DeadTom is offline
Find More Posts by DeadTom
Team of ONE....or...Team Me
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
Originally Posted by HELModels View Post
I've seen some very technical things done with blender like gears and an enitre ball bearing assembly based on actual dimensions, so I know it can be very precise.
Here is the very first Blender tutorial I did of a 608 bearing, it was written for an older version Blender and was a little difficult to follow but I made it through.
The author was himself an engineer so I thought that would help me and it did to an extent. The bearing is drawn to scale/shop drawings.
Here is the link to the tutorial and a quick pic of my bearing.
http://www.rab3d.com/tut_blender.php
DeadTom is offline Find More Posts by DeadTom
Old Dec 23, 2012, 04:29 AM
Harpye is offline
Harpye's Avatar
Germany
@ Helmodels :
Of course it is possible to derieve any data needed from the skin model - to detail it and to setup laser or routing code with other CAM applications or - if you are good in SW programming you could do this in the embedded VBA clone engine.
So I'll show you a quick and dirty workflow. ( I'm not sure in which technique to build her ( Stryene monocoque with about 10 to 12 gram AUW or bigger Styrene wood or composite is also not clear, so please understand that I do not put too much effort in this ... just to show up the principle )
FIrst step place section planes inthe areas to get 2D data from
Second step intesect planes with model ( get yellow 2D shapes)
Third step arrange and create NC Code
Fourth step ( post detail and cut the parts)
Self Scripted Rhino Cam Module (2 min 56 sec)
Old Dec 23, 2012, 11:13 AM
DeadTom is offline
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
I utilize a very similar work flow; export an .stl file from Blender, import the .stl file into either a a 2D CAM program (Cut2D) or into 3D CAM program (MeshCAM), make up the toolpaths with the cutter of choice and output it to the machine for cutting.
As far as using Blender to extract sectional or cross-sectional information it should be possible but I am still learning how to utilize Blender efficiently.
Nice work Harpye
Old Dec 23, 2012, 11:25 AM
Harpye is offline
Harpye's Avatar
Germany
The disadvantage of STL is that it is a one way ticket! Comming from NURBS ( mathematical defined mesh) to STL ( discrete triangular mesh)
this is always an irreversible conversion ( downgrading)! ... Another thing is that triangular mesh can be critical when it comes to fittings ... dependent on the chosen bit and the " radius correction" ( if there would be a radius) this might cause issues in some cases... ( for modelling ( wood) I don't think that it will be critical ( wood is that elastic). And choosing the "triangle length of edge parameter" smaller than the physical step width of the machine would also exceed the PCs memory sometimes But GOOD LUCK! It is fun , it is free and that should be the main targets of this hobby!!
Old Dec 23, 2012, 05:20 PM
DeadTom is offline
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
Agreed that .stl files are not a professional choice but since this is a home hobby I have not run into any issues yet.
If I do no need tighter precision I can use one of my CAD programs (Microstation, TurboCAD) to draw up want I need and then bring that into the CAM environment for toolpaths, which is what I have done with many other projects where I did need better control of curve paths.
I am still waiting for my MakiBox 3D printer where the .stl file will be alright as the resolution of the parts can only be printed to a certain resolution anyways, again this is a hobby grade machine.
Old Dec 24, 2012, 04:13 AM
Harpye is offline
Harpye's Avatar
Germany
I know! and things like the MAKI BOX are the original reason why STL was invented!!
I'm going to do my own prototyper as soon as the current lathe is finished....
But since I dont like the structured appearance and the costs of the parts comming out of the makerbot it will be another working principle than FDM...
Lot cheaper on running costs, but not bound to the necessity to use support material to create bridges and overhangs!
Question Anybody use this wattmeter? Multi-function Wattmeter FD-WM Bill Smudge Power Systems 13 Sep 19, 2012 08:52 PM
Question Anybody use this wattmeter? Multi-function Wattmeter FD-WM Bill Smudge Electric Plane Talk 19 May 22, 2012 07:22 AM
Mini-HowTo adding textures to Clearview using blender othmanskn Simulators 0 Jan 05, 2007 09:41 AM
Discussion Modelling Planes using Blender for FMS and Clearview othmanskn Simulators 5 Dec 03, 2006 03:02 AM
Mini-HowTo Adding Moveable surfaces to Clearview using Blender othmanskn Simulators 4 Dec 01, 2006 01:36 AM
