Old Nov 08, 2012, 11:46 PM
Smokeshow is offline
Find More Posts by Smokeshow
Joined Oct 2012
altimeter blues
So i just got a new V4 OSD pro with altitude meter.
my problem is that if i fly away from any metal objects it works great!
But I took it on the construction site for work, there are lots of metal plates and etc around. I took off about 2m in the air and the altitude meter jumped to 12m!! it did this a couple of times.
as soon as I got about 30m in the air it worked again! ??? hmm
Is there any way to avoid this?? i.e putting in a film canister or something??
thanks in advance
Jason
Smokeshow is offline Find More Posts by Smokeshow
Old Nov 09, 2012, 08:24 AM
dhares is offline
Find More Posts by dhares
Saline, MI
Joined Jul 2006
Are you using the GPS Altitude or the Barometric Altitude sensor?
dhares is offline Find More Posts by dhares
Old Nov 11, 2012, 09:51 PM
Joined Oct 2012
i am using the Barometric Altitude
Old Nov 12, 2012, 08:22 AM
dhares is offline
Saline, MI
Joined Jul 2006
When I get strangeness like that, It's usually because of a kink in one of the hoses from the probe to the electronices. The hoses should be cut to length and not bent at an extreme angle. I mount the electronics package as near the pitot tube as possible and use extension cables if necessary to connect them to the V4
Discussion Hobbyking altimeter Vegas_flyer Sailplane Talk 122 Oct 26, 2015 08:55 AM
Discussion How to connect the altimeter to electric sailplane setup? liukku Electric Sailplanes 2 Apr 09, 2012 06:43 PM
Discussion Altimeter Accuracy samc99us Hand Launch 33 Apr 07, 2012 08:34 PM
Discussion Altimeter V3 - DOA cuprum Eagle Tree Systems 2 Mar 31, 2012 01:59 AM
Wanted Zlog Altimeter or How High Altimeter Bohh33 Aircraft - General - Miscellaneous (FS/W) 1 Feb 11, 2007 10:52 AM
