Old Nov 08, 2012, 09:31 PM
DrlSgt is offline
Find More Posts by DrlSgt
R.C. Designs - I fab. things
DrlSgt's Avatar
United States, MI, Sterling Heights
Joined Oct 2009
Help!
Airtronics Grand Esprit Dimensions
I'm looking at the Plan sheet and the tail boom dimensions in the top view are different from the side view. I'm getting a quote for a custom carbon boom and I need to give the supplier a size.
The top view shows the boom as:
33.500 x 1.200 x .350
The side view shows the boom as:
33.500 x 1.200 x .700
the plans inply that the boom has flatened sides starting near the center and running to the tail end.
Can someone give me the exact dimensions as supplied with the kits?
Also, there are several holes in the tail end for mounting the tail planes and as such are really bad for a carbon boom. Should I be using a FG boom instead reinforced with some carbon?
DrlSgt is offline Find More Posts by DrlSgt
Old Nov 08, 2012, 11:13 PM
prodjx is online now
Find More Posts by prodjx
prodjx's Avatar
United States, AZ, Tucson
Joined Jan 2007
I would repost this over on the thermal forum. I'm sure someone over there would know the answer. Larry Jolly is over there a bit and used to work for Airtronic's during that era.
prodjx is online now Find More Posts by prodjx
Old Nov 08, 2012, 11:46 PM
John Cole is offline
Find More Posts by John Cole
John Cole's Avatar
United States, CA, Santa Rosa
Joined Jun 2001
My GE boom is a 33.75" tube, 1.2" tapering to .75". The boom is a tapered flat-wrap made of fiberglass and epoxy resin. The boom ends at the stab TE, and there is a balsa extension several inches long stuck on the end. This balsa extension also has a ply skid bonded to it. You could use carbon, no problem and much lighter-stronger, etc. The boom has no holes drilled for the 'v' tail, it is mounted above the boom on a balsa-ply bed.
There are two holes drilled about 1.5" from the tail end for the pushrods to exit. Hope this helps!
John
John Cole is offline Find More Posts by John Cole
Old Nov 09, 2012, 06:08 AM
jolly01 is offline
Find More Posts by jolly01
United States, FL, Shalimar
Joined Jan 2009
You will have no problem with the removable tail or control rod holes at the end of the boom, there's plenty of ply and balsa on the tail mount to make up for any weakness in the carbon if any.
jolly01 is offline Find More Posts by jolly01
Old Nov 09, 2012, 07:28 AM
John Cole's Avatar
Joined Jun 2001
Edit: In looking at the stab mount, holes are drilled for the stab screws as well.
John
Old Nov 09, 2012, 06:22 PM
DrlSgt is offline
DrlSgt's Avatar
Joined Oct 2009
Thank you very much for the replies. The info is very helpful.
Old Nov 10, 2012, 02:45 PM
John Cole's Avatar
Joined Jun 2001
You are welcome, let me know if you need any more information. I have resources available for this model (2 completed from old kits, and an old Airtronics kit)
John
Old Nov 11, 2012, 02:02 AM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
Look at cross section D-D just above the TE on the side view, it should give you the answers to your dimension questions.
The glass booms on my Super and Grand Esprits have survived several crashes that have required the front of the fuselage to be replaced but the V-tail mounts are from the orginal builds.
Carbon should hold up better than the glass.
Joe
Thermaler is offline Find More Posts by Thermaler
Help! Airtronics Grand Esprit Dimensions DrlSgt Thermal 0 Nov 07, 2012 10:46 PM
Help! Airtronics Grand Esprit DrlSgt Sailplane Talk 1 Oct 29, 2012 07:35 PM
Help! Airtronics Grand Esprit assembly instructions DrlSgt Thermal 1 Oct 29, 2012 07:33 PM
For Sale Airtronics Grand Esprit (scratch built not from kit) spud nut Aircraft - Sailplanes (FS/W) 10 Oct 22, 2012 07:51 PM
Sold Airtronics Grand Esprit Aeronut41 Aircraft - Sailplanes (FS/W) 10 Mar 29, 2012 10:09 PM
