Old Nov 08, 2012, 08:46 PM
war64 is offline
Find More Posts by war64
Joined Oct 2012
Hi Start / Bungee Hook
What the correct / best way to mount a hook for a bungee launch? I have a Speedo 1.2M Pro II that I want to mount the hook to. Building threads didn't show hook mounting. I have the hook, 2 nuts, washers and small wood spacer. Thanks.
war64 is offline Find More Posts by war64
Old Nov 08, 2012, 11:09 PM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
United States, AZ, Tucson
Joined Jan 2007
For a model like that I would put it somewhere between the spar and the leading edge. I'm guessing you don't want to launch like a thermal type glider. When you launch a model like the Speedo you don't want to use any control input's if possible. Not knowing your model very well I'm assuming it has no rudder.
prodjx is offline Find More Posts by prodjx
Question Zogling tow hook location for hi-start nikram58 Scale Sailplanes 6 May 21, 2010 10:02 PM
Discussion Problems un-hooking from hi-start and questions on placement... GreenAce92 Sailplane Talk 22 Jul 31, 2009 09:19 AM
Help! Installing Hi-start hook? Position? Securing? Evan Byrne Slope 10 Jan 12, 2008 08:56 PM
HI-Start hook placement? IBbob31 Hand Launch 0 Feb 05, 2003 03:18 PM
