Old Nov 16, 2012, 09:46 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I crashed a Giant Big Stik w/30CC recently due to signal failure with a Spektrum DX7 and AR7000rx. But due to the rx being thrown out of the plane and the battery and servos all being disconnected I will never know what caused it. It went from flying fine in a shallow bank to a steady uncontrolled decent to mother earth.
That is my 2nd plane in just over a year that did that. ( All crashes between have been pilot error). I fly every day so the problem is probably nothing that can ever be defined. Maybe some other 2.4 system like a wireless phone or wireless router hitting it?? Don't, know. But back when, I had failure with 72mhz systems too. The nature of technology I think.
Fokker DII is offline Find More Posts by Fokker DII
Old Nov 16, 2012, 10:47 PM
Evan03 is offline
Find More Posts by Evan03
Mtn Home, Idaho
Joined Feb 2010
Need some logging info. So you could see what was going before the crash
Evan03 is offline Find More Posts by Evan03
Old Nov 18, 2012, 07:52 AM
davidmc36 is online now
Find More Posts by davidmc36
No bounce, No play.
davidmc36's Avatar
Canada, ON, Ottawa
Joined Oct 2010
Originally Posted by high as a kite View Post
....Is Sprectrum 2.4 that bad????....
In a word.....NO
Have used DX7 (DSM2) last three seasons and DX18 this past season. With all sats installed and antennae oriented properly running 4.8V large capacity batts capable of providing enough power without voltage dropping have never even had a hint of issue. Flight logs always show low numbers. I even have one plane that I never used any Sats on and it is fine too. It has a huge Lipo and I never run it even close to LVC.
Make sure all controls have no friction or binding. An over-worked servo will draw excess current and drop your voltage.
I always have NiMh batt packs fresh off the charger right before I leave.
I never fly Lipo powered Tx that is more than 25% drained.
My planes that have no separate Rx battery use quality speed controllers that provide plenty of power to the built in BEC.
Space your Sat Rx's as far apart as possible and as far from any other electronic equip in the plane as you can get them. Line up your antennae on as many axes as you can. If you have all the "90 degree" ones covered, put additional ones at 45 deg.
Never run your power system close to the edge of its capability. Set it up so you are only drawing around 60-70% of what the specs say it will handle.
Have all Rx's LED's visible so you can confirm each time you fire up that they are all connected.
Don't leave your radio equipment in situations where they can build up condensation. Keep them in a moderate temperature environment, never swinging wildly from hot to cold and back again, and be careful of storing in areas of excess humidity no matter what the temperature.
You can't just toss radio equipment into the airplane randomly, run cheap BEC or batt pack, push the batteries right to the end of their capacity, or have control systems that bind and drag and then, be surprised/blame it on "That crappy Spektrum stuff", when you lose control.
davidmc36 is online now Find More Posts by davidmc36
Old Nov 18, 2012, 12:41 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Well said sir! +1
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Sold JR- 921 2.4 Spectrum DSM2 Receiver ptxman Aircraft - General - Radio Equipment (FS/W) 3 Apr 21, 2012 12:41 PM
For Sale Jr/Spectrum Rx's and Modules for sale (2.4 Module, AR6110e, AR6115e, AR7000, R900s) Twyl Aircraft - General - Radio Equipment (FS/W) 9 Apr 03, 2012 12:23 PM
Sold JR- 921X 2.4 Spectrum DSMX Receiver 2048 ptxman Aircraft - General - Radio Equipment (FS/W) 2 Apr 01, 2012 11:06 PM
Sold Spectrum DM8 2.4 module for Futaba 9c 2.4ghz Aircraft - General - Radio Equipment (FS/W) 2 Feb 23, 2012 03:44 PM
Discussion will my 2.4 video down link interfere with my spectrum 2.4 rx & tx ? djdaveq Radios 6 Sep 13, 2007 05:40 PM
