Old Nov 08, 2012, 09:05 PM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
Originally Posted by typicalaimster View Post
Hmm looks like they are out of stock. You guys bought up all the planes didn't you! I'd probably convert this over to a A tail vs the H tail they have going on. I'll keep an eye out for this plane and hopefully it'll come back in stock.
Sadly I'm a sucker for TBP's
their site says this
First batches will be available from 15.11.2012
Nice looking kit.
I have thought of turning my Zephyr2 into a 'Boomer type' like this - but without a fuselage.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Nov 09, 2012, 06:38 AM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
BCsaltChuck
in terms of aeroflight dynamics, what is the point of dual boom design, as opposed to regular airplane single boom with Hori/Verti tail. Is this more efficient?
I see that countries around the world prefer this twin boom pusher setup for 'drones'....
What about for us Hobbiest that prefer efficient FPV plane for long fligh times and glide factor.
LexusFPV is offline Find More Posts by LexusFPV
Old Nov 09, 2012, 07:35 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
The twin boom design breaks down into a smaller package vs your standard plane. It's a matter of portability. To me it's about looks.
typicalaimster is offline Find More Posts by typicalaimster
Old Nov 09, 2012, 07:41 AM
hefest is offline
Find More Posts by hefest
KISS
hefest's Avatar
Joined Oct 2009
Than there is line of thrust issue with easy star like configurations compared to twin boom.
hefest is offline Find More Posts by hefest
Old Nov 09, 2012, 08:58 AM
LexusFPV is offline
Joined Feb 2011
hefest,
what do you mean 'easy star' like configuration? pusher type?
So, the Twin Boom is just for transport/breaking down easily?
Also,
how hard will this be to convert to "A" tail (opposite of a 'V' tail).?
Old Nov 09, 2012, 10:41 AM
hefest is offline
KISS
hefest's Avatar
Joined Oct 2009
Originally Posted by LexusFPV View Post
hefest,
Also,
Yes, I mean pusher configuration like easy star.
In such configuration thrust line is usually tilted to compensate for the off-center position of motor. With this configuration that's not the case and I see it as advantage. Also you can fit quite large prop on this one.
Old Nov 09, 2012, 02:12 PM
Joined Jan 2005
Also,
Converting to an A tail is rather easy. I'd suggest just using some balsa and whacking some tails out yourself. The material is light weight and durable. The nice part about the booms is it allows for a larger prop. I'd love to run a 11x7 on my Skywalker but the tail boom restricts the size of prop. With a TBP you're limited to the space between the boom.
The magic number for a A-Tail from what I remember is 110-120 degrees. I'll attach the spread sheet I was using when I was designing TBP's back in the day. I'd love to start designing some TBP's again.. Just don't have anyone that I know that can make cheap molds.
Old Nov 10, 2012, 05:54 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Twin boom allows for large prop / low kv motor, which always was the key of an efficient propulsion.
I would provide a foldable prop, though.
renatoa is offline Find More Posts by renatoa
Old Nov 10, 2012, 04:18 PM
lee8sec is offline
Find More Posts by lee8sec
Australia, QLD, Hervey Bay
Joined Apr 2008
Damm, another to add to the list.
lee8sec is offline Find More Posts by lee8sec
Old Nov 10, 2012, 04:20 PM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
What are the specs on it?
What are the recommended motor/servo combo?
eroeder is offline Find More Posts by eroeder
Old Nov 12, 2012, 01:43 AM
eroeder is offline
eroeder's Avatar
Joined Jan 2004
I see there are two threads on this...
http://www.rcgroups.com/forums/showthread.php?t=1767087
Old Nov 12, 2012, 06:35 AM
LexusFPV is offline
Joined Feb 2011
eroeder, you asked whats a recommended motor/prop etc....
Someone mentioned that with pusher prop configuration,
its more efficient with "Low Kv motor, and big ass prop"
for very low cruising amps..... so it flight times will be longer:-)
Old Nov 12, 2012, 09:39 AM
fpvmania is offline
Find More Posts by fpvmania
Joined Nov 2012
Skyhunter recommended setup
T-Motor AS2820(3542) KV920 motor
11x7 or 12x6 APC propeller
T-Motor 60A ESC
8-15g metal digital servo x3
4S 14.8V 5000-25000mah li-po battery
Skyhunter - New 1.8m twintail FPV/UAV EPO platform Ground footage (1 min 33 sec)
Skyhunter - New 1.8m twintail FPV/UAV EPO platform Flight video (0 min 0 sec)
fpvmania is offline Find More Posts by fpvmania
Old Nov 12, 2012, 11:25 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
The specs say it comes with a 12mmx 10mm spar. That might be ok, depends on how the wing loads I suppose. Definitely looks like a good plane at first glance. Like I said in the other thread, it needs landing gear. Otherwise the tail might get damaged on landing. Secondly, the FPV camera needs to sit higher up, so the deck is clear for a HD camera.
ashdec87 is offline Find More Posts by ashdec87
Old Nov 12, 2012, 11:40 AM
LexusFPV is offline
Joined Feb 2011
FPVmania
Can You post vids' of this plane landing?....so it clears up that the twin booms
are strong as advertised.... also, it will show how the twin 'FOAM' vert/ horizontal stabilizers
in the rear of the plane will hold up.....
I ask because, the grass around here is too long for ROG take off, and ROG landings'....
(I don't need landing gears)....a modified 'skid' will be cool though.
Something SIMPLE!!!!
Mini-Review FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider McMoron Electric Sailplanes 428 Dec 03, 2015 01:43 AM
Discussion EPO Global Hawk, possible fpv platform? Black Baron FPV Talk 4 Apr 04, 2012 10:19 AM
Discussion Eagle Wing EPO FPV platform - 150cm fidzi2002 FPV Talk 16 Nov 16, 2011 10:15 AM
