Old Nov 08, 2012, 02:56 AM
iskess is online now
Find More Posts by iskess
FPV in Hawaii
iskess's Avatar
United States, HI, Kailua
Joined Feb 2012
Help!
Adding a directional antenna to a Walkie-Talkie for tracking UHF beacons
Can someone help me figure out how to solder an SMA connector to this Motorola walkie talkie PCB?Name: ImageUploadedByTapatalk1352364717.676241.jpg
Description:
Description: Name: ImageUploadedByTapatalk1352364775.944986.jpg
Description:
I want to add an SMA connector so I can add a Yagi antenna to help track a UHF beacon.
The problem I see it that there is only one wire for the stock antenna, and I need to know where to attach the ground. The ground should be on the RF Module, not just the battery ground. Can anyone identify it for me?
Thank you for your help.
iskess is online now Find More Posts by iskess
Old Nov 12, 2012, 07:45 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
If noone has a better idea, I would use the ground one can see in the last image, with the many vias in it.
Julez is offline Find More Posts by Julez
Old Nov 12, 2012, 05:31 PM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Thank you do much for your reply. No one else has chimed in yet. Can you try to describe the location you are talking about in the photo?
Old Feb 03, 2013, 12:51 AM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Bump.
Maybe this will catch someone else's eye who can help me.
Old Feb 03, 2013, 10:02 PM
jakestew is offline
Find More Posts by jakestew
United States, ID
Joined Sep 2011
The RF ground is where the antenna wire departs away from the groundplane. Scrape off some solder mask right next to the RX out and solder there.
You can't take any ground other than a couple mm from the RX out or it becomes part of the antenna.
jakestew is offline Find More Posts by jakestew
Old Feb 04, 2013, 03:18 AM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Thank you so much for the reply. So just to clarify, you are saying to just pick any point right next to the existing antenna solder blob and scrape off the green?
Old Feb 04, 2013, 01:19 PM
jakestew is offline
United States, ID
Joined Sep 2011
Yes. It's hard to see on what's going on with your board, so make sure you tap into the ground.
The antenna starts wherever the TX path departs from the ground. Right on one side or the other will be your best point to attach the connector.
If you want to put on a connector you need to ground the outside of it, otherwise the connector will be part of the antenna. Same if you use some sort of coax cable to connect to the antenna. If you just want to try a straight wire as an antenna then you don't have to worry as you'll just solder directly on the TX output.
Old Feb 04, 2013, 03:33 PM
FPV in Hawaii
iskess's Avatar
Joined Feb 2012
Ground the outside of the SMA connector? Isn't that what I am doing when I scratck off the green and solder the conector there? Or do you mean ground it again to the battery ground?
Old Feb 05, 2013, 10:44 AM
jakestew is offline
United States, ID
Joined Sep 2011
Yep, that's right. The SMA connector is grounded right next to the old antenna. Don't ground it anywhere else or you could cause some ground loop problems.
Sold Walkie Talkies (pair) $20.00 + shipping mtdoramike Aircraft - General - Miscellaneous (FS/W) 0 Mar 01, 2012 01:12 PM
Discussion PMR Walkie Talkie or cheap UHF module for long range control? cloudy FPV Talk 3 Dec 09, 2010 12:09 PM
Discussion 2 way radio (walkie talkie) for controls? Bobbyallan Power Systems 2 Feb 19, 2010 03:30 PM
tx antenna, walkie talkie style? snowcrash75 Beginner Training Area (Aircraft-Electric) 8 Oct 10, 2005 05:01 PM
Directional Antenna for Cobra Walkie-Talkie uscra112 DIY Electronics 11 May 25, 2005 05:13 PM
