If this is for real....
Nail 2 nails on a flat surface a set distance apart (1 foot, 1 meter etc). Make some appropriate markings between the nails (inches, centimeters etc). Mark off 6" of string for the end you will tie to one nail and tie it on starting at that mark (whatever hangs off is already counted) Wind the string around the nails counting the number of complete wraps. Each wrap equals twice your set distance (2 feet, 2 meters etc + your tie amount). When you get to the end measure it against the markings you made between the nails previously (i.e halfway would be 6" or 50cm etc). Add it all up for a total that is going to be within 1% of your actual total (loose a tiny amount of distance going around the nails). Tie amount + (wraps X2) + end remnants = string length If you need more precision than this....why are you using string?
Stuart. |
| Thread Tools | |
| Discussion Curving relative wind, how much slip is ideal in turns, yaw strings videos | aeronaut999 | Modeling Science | 7 | Jun 19, 2012 10:58 PM |
| Question How should a yaw string behave in a proper thermal turn? | Miami Mike | Sailplane Talk | 12 | Mar 22, 2012 08:00 AM |
| Discussion How long is a piece of string? | epilot | Indoor and Micro Models | 52 | Nov 14, 2009 05:02 AM |
| Discussion How long did you keep your model airplane in one piece? | ShayRC | Fuel Plane Talk | 17 | Apr 17, 2006 07:01 AM |
| How Can I Cut Colored Tape In Long Pieces? | hoppy | Power Systems | 6 | Jun 01, 2001 10:08 AM |
