Old Jan 26, 2013, 02:30 PM
Francesco is offline
Find More Posts by Francesco
Francesco's Avatar
United States, CA, Mountain View
Joined Apr 2001
Originally Posted by cityevader View Post
you CAN glide at different speeds with the same trim if it's balanced. It should go exactly where it is pointed.
Actually, the only way you can glide at different airspeeds with the same trim is by changing what I think you call balance, i.e. the CG position.
Francesco is offline Find More Posts by Francesco
Old Jan 26, 2013, 02:34 PM
Phil.Taylor is offline
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
the entire goal of a balanced plane is so that it WON'T require different trims for different speeds; that is an indication of an unbalanced plane, and it is NOT desirable to have it fly different all the time just because speeds are different (an unbalanced plane).
After 16 pages of stuff which is mostly about CofG & "decalage"
how about some clarity on "trim" - which is one of the questions you started with?
Trim IS about flying the plane at different speeds.
Start by flying your plane nice & level - then hands off the controls - it flies at a certain speed - for that state-of-trim
add a few clicks of down elevator "trim" - again hands off - it will fly faster.
likewise if you add a few clicks of up trim - again hands off - it will fly slower.
If you ever get to learn in a full-size sailplane, you will be taught to adjust the trim lever so it flies hands-off at the speed you want - say 50 knots. Want to fly faster between thermals? - adjust the trim "down" so it now flies at, say, 70 knots.
Hope that makes sense?
NOTE - all of the above is for one particular CofG position.
and of course CofG position & elevator "trim" are inter-related - move the CofG forward, and you will need to add up trim to fly hands-off at the same speed as before - move the CofG back, and you will need to add down trim.
now, if you move the CofG forward and DONT retrim the elevator - what happens? - the plane flies faster hands-off - which for small changes is pretty much the same thing as adding a bit of down trim, except you cant change the CofG in the air.
Now - I'm interested to hear what other folks mean when they are talking about "trim" ?
Phil.
Phil.Taylor is offline Find More Posts by Phil.Taylor
Old Jan 26, 2013, 02:51 PM
medroller is offline
Find More Posts by medroller
Australia, QLD, Townsville
Joined Jul 2011
Thanks for the feedback gents.
Like I said, it does fly OK on the glide ,but I reckon with some more experimentation, i can get better performence.
Cityevader,i'll try what you said about gordy's suggestion.
One thing the dynamic does is drop it's nose sharply sharply when I power down. So maybe with playing around with setups ,I can eleveate this.
I bought a graupner maxisport off a fellow gliderman ( Fisherman- gliderman ?). Now that's a whole new ball game flying that bird.
medroller is offline Find More Posts by medroller
Old Jan 26, 2013, 02:57 PM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Glider Guider
Here in Canada the CBC insists on calling them "Fishers" so as to not be gender biased. That would mean those who fly gliders are also gliders ,
Or perhaps gliderers?
pmackenzie is online now Find More Posts by pmackenzie
Old Jan 26, 2013, 03:01 PM
williamson is offline
Find More Posts by williamson
Joined Feb 2006
Originally Posted by HerkS View Post
What you describe is both normal and desirable. The why is somewhat complex, but it's mainly because of the interaction between the weight/CG which is pretty much constant and the aerodynamic forces which are proportional to speed squared. The slight down elevator at your ideal soaring trim and CG doesn't cause any problem and doesn't need fixed. It's normal too for higher speed flight to require more down trim in a well balanced sailplane.
To endorse what Herk said, every plane that has been trimmed out for near-level flight will have the CG ahead of the neutral point. It can then be said that the combination of the stab and elevator must be providing some downward force to offset the fact that the CG is ahead of the neutral point. In a simplified view, this is like a balance-beam problem. You may have an elevator that is slanted downward relative to the stab, but the combination of stab and elevator will be providing a net downward force.
When a plane speeds up (e.g. steep or vertical dive), the aerodynamic forces (net effect of wing, stab and elevator) increase. The CG ahead of the neutral point does not provide enough pitch-down force to offset the increased aerodynamic forces that are pushing the nose up. Thus the nose pitches up.
williamson is offline Find More Posts by williamson
Old Jan 27, 2013, 12:24 AM
MrE is offline
MrE
Find More Posts by MrE
MrE
United States, WA, Gig Harbor
Joined Aug 2007
You guys are forgetting the several posts by top pilots who fly their models with a combination of CG/trim such that they tuck when in a dive and others that dont tuck or pull out in a dive.
Also Dr Drellas notes on the Bubble dancer clearly show a CG position that results in zero force on the stab. With zero force on the stab the model can easily be trimmed to pull out in a dive OR tuck OR do nothing.
I have played with my new BD and with the CG at his suggested point, the model can indeed be trimmed to do all three - and will still fly hands off level at all three settings. Of course, this results in 3 different "trimmed" speeds.
Well, actually there are any number of speeds depending on the trim setting, but you get my point.
MrE is offline Find More Posts by MrE
Old Jan 27, 2013, 03:30 AM
cityevader is online now
Find More Posts by cityevader
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
Francesco and Phil, I think my personal definition of trim is much more broad than it should be, and you are correct. I wasn't referring to a properly balanced plane that was trimmed one way or another, rather, an unbalanced (nose heavy) plane requiring "trim"; My definition of trim also includes the stick corrections that are constantly required (during the slope flying I do) as the models speeds and slows, speeds and slows...the stick itself becomes the trim because you obviously can't take your thumb off the stick in order to hit the trim during a dive/high speed pass/rolling pullout into a near-hover at the top, dead-into-the-wind. This is what I was referring to as being undesirable, rather than desirable, flight characteristic.
And a side note fwiw, there's also a lot of TD guys chiming in here with an assumption that my topic was "single speed" trim and relation to cg etc. when in fact I had been seeking a "neutral" plane at all speeds.
cityevader is online now Find More Posts by cityevader
Old Jan 27, 2013, 07:13 AM
Phil.T-tailer
Devon, UK
Joined Jun 2003
LOL - I call that "flying"
You & the slope guys move the CofG back for control responsiveness/neutrality
The TD guys move the CofG back for performance & lift signalling
On my local slope, I do both! - great thermals way out over the valley in front of the slope - I need those different "trim" speeds to get out there & hang there.
Good that we got you sorted - happy flying !
Phil.
Old Jan 27, 2013, 07:44 AM
atmosteve is offline
Find More Posts by atmosteve
Joined Nov 2007
Phil T has summed it up nicely. Just go fly.. Don't over hype the little details, it will do you no good, proven here on RCG countless times with umpteen types of gliders. You don't need the internet to become a proficient rc flyer.
atmosteve is offline Find More Posts by atmosteve
Reply With Quote  (Disabled)
Old Jan 27, 2013, 04:29 PM
Joined Feb 2006
With the CG at the neutral point, there will indeed be no force on a flying stab. Top pilots typically set the CG very close to the neutral point in order for the plane to be highly responsive. However, it takes a lot of skill to fly at this CG. If the plane goes into a dive, it continues in that dive (or tucks). This is hard to sense when the plane is high in the air. For this reason, a lot of pilots place the CG ahead of the neutral point so that the plane has more pitch stability. If the CG is placed far ahead of the neutral point, the plane is sluggish and tends to easily get into large pitch oscillations.
Old Jan 27, 2013, 08:32 PM
MrE is offline
MrE
MrE
Joined Aug 2007
Actually, you dont need the CG ahead of the neutral point - just a tad of up trim will do exactly what you want - pull out of a dive.
We just spent several pages proving this point - Its the trim setting (decolage) that determines if the model pulls out of the dive - NOT the cg position.
You can have your cake (a plane that indicates lift as well as it possibly can) and eat it too (have pitch stability)
Old Jan 28, 2013, 11:41 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
Tom and Mike and several others have commented that as the Cg is moved closer to or at the neutral point, the performance improves?
1. Can you define what is performance?
2. How can I determine I have reached the maximum performance of a plane?
3. If Cg AND elevator trim setting determines if I pull out of a dive, What should be done to determine if maximum 'performance' is reached?
How do I know I am flying a plane too slowly and should not move the Cg further back?
Isn't it possible that I chose the wrong speed to start with?
Are we trying for min. sink or best L/d speed when we are trimming?
Frank
Fly2High is offline Find More Posts by Fly2High
Old Jan 28, 2013, 02:30 PM
got-one is online now
Find More Posts by got-one
Cowl Flaps Open - check
got-one's Avatar
USA, MI, Rochester
Joined Nov 2008
Frank
Frank,
You have some good questions there that I too would like to see answered. In addition to your questions can some one comment on:
  • Where is the neutral point on a RP?
  • If you move the CG further and further back, will you have to add down trim to keep it from stalling?
  • How do you know if you have the CG too far back?
Dave F
got-one is online now Find More Posts by got-one
Old Jan 28, 2013, 02:58 PM
Joined Feb 2006
Frank
1. Performance is hard to define. This discussion leads toward one definition, namely that the pitch response of the plane indicates lift well. A plane that has the CG slightly ahead of the neutral point will have pitch oscillations (phugoid oscillations) that are so slow that they are hardly noticeable in most instances. A long tail boom does a good job of dampening these oscillations.
2. The maximum performance of a plane is very dependent on your flying style. As the CG is moved back, the response to both wind gusts and transmitter commands is greater. This means that the plane is reliant on more active control by the pilot. As said earlier, controlling a plane at long distance and/or high elevation is difficult unless that plane has a modest amount of pitch stability. A case in point is cross-country planes that fly high. For these planes, the CG is farther ahead of the neutral point than would be the case for thermal duration competition.
3. Once the CG is established, elevator trim comes in. By changing elevator trim, the plane can be moved over the full range set by the L/D curves for that plane. One trim can place the plane at minimum sink. Another trim can place the plane at the maximum L/D. Other trims can place the plane at the maximum distance covered in a head wind, etc. A great presentation of this subject is at:
http://www.5c1.net/Glider%20Performance%20Airspeeds.htm
Old Jan 28, 2013, 03:00 PM
Joined Feb 2006
Originally Posted by got-one View Post
Frank,
Dave F
You can find the neutral point on a sailplane by moving the CG back until the plane becomes uncontrollable in pitch.
As the CG is moved back, more down trim is needed to keep the glide slope constant.
Question Trim, cg, and incidence biskit High Performance 10 Dec 16, 2012 07:32 AM
decalage CG relations Beginner!? Modeling Science 4 Apr 26, 2005 07:04 AM
Debugging glider - which to tackle first: CG, incidence, decalage, elevator flex? dimple Hand Launch 6 Oct 28, 2004 11:09 AM
Tiny trim & CG questions JamesD Parkflyers 0 Oct 20, 2002 04:33 PM
