Old Dec 17, 2012, 05:48 AM
Kiesling is online now
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Originally Posted by Phil.Taylor View Post
Sorry, but you can do the dive test from any state of trim you like - so long as you return to that state of trim after changing the CofG. Re-read Daryls posts & think about it. What you are actually testing for, is dynamic stability/neutrality - at that particular state of trim.
Phil.
Okay, fair enough. The model at least needs to fly at a constant speed hands off for extended periods. If it is neutrally balanced, it should be able to do this for a variety of trim speeds. I suppose the benefit of setting trim for a slow glide is you know within a reasonably short period that the model is trimmed for constant speed flight. With a fast or even moderate cruise, a pilot may think that the model is maintaining constant speed, when in fact it may be gradually accelerating. So in Daryl's case where it tucked, either his model was not stable or it was not trimmed for constant speed - correct? (I actually want an answer to this to confirm my understanding). Also, it seems to me the dive test is really testing for static stability and not dynamic stability (the initial response to the down input and not the long term damped behavior of the aircraft).
Tom
Kiesling is online now Find More Posts by Kiesling
Old Dec 17, 2012, 06:31 AM
Daryl Perkins is offline
Find More Posts by Daryl Perkins
Daryl Perkins's Avatar
United States, VA, Falls Church
Joined Mar 2007
Tom,
It was trimmed for constant speed. My example was simply that Joe was on one side of "slow speed cruise" and I was on the other side. Always within one or 2 clicks of trim. Slow speed cruise is somewhat subjective. I wasn't consciously trying to trim for a slightly faster cruise, that's just what felt right to me at the time. And it felt.. OH MY GOD slow....
I think I've gone that far the other direction now, and am probably trimmed too slow for the dive test to mean anything.
Daryl Perkins is offline Find More Posts by Daryl Perkins
Old Dec 17, 2012, 08:45 AM
Phil.Taylor is online now
Find More Posts by Phil.Taylor
Phil.T-tailer
Phil.Taylor's Avatar
Devon, UK
Joined Jun 2003
Tom
If your model is accelerating on its own, when it should be cruising - you've got problems !
Phil.
Phil.Taylor is online now Find More Posts by Phil.Taylor
Old Dec 17, 2012, 09:00 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
Phil.
... unless it's got a tiny fan or turbine on board ?
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Dec 17, 2012, 11:17 AM
GliderJim is offline
Find More Posts by GliderJim
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
So to clarify, you're saying you have the CG where you want it, but because you're trimmed for slow flight, doing a dive test would probably result in the plane pulling out rather quickly?
Also, when you say "push" the plane around the sky, I assume you mean having to give it a little bit of down now and then to keep it moving. With a rearward CG setting is there a tendency for the plane to get into a "mushing along" state if you don't give it a little down once in awhile to keep it moving?
Jim
GliderJim is offline Find More Posts by GliderJim
Old Dec 17, 2012, 01:48 PM
cityevader is online now
Find More Posts by cityevader
IT'S NOSE HEAVY!!!!!!!
cityevader's Avatar
United States, CA, San Jose
Joined Mar 2012
Seems like he's pushing it because there's a bit of up trim, not necessarily because of the cg, per se, right?
cityevader is online now Find More Posts by cityevader
Old Dec 17, 2012, 03:09 PM
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
Right - at least that's what I'm understanding him to say.
My 2nd question should have been separated.
When I've messed around with moving the CG back it sometimes seems like the plane is just mushing along. With a more forward CG it seems like that doesn't happen. It'll settle into a groove, or if I slow it up too much it'll drop the nose and speed itself up. Just wondering if others have experienced this or if I'm just imagining things.
Jim
Old Dec 17, 2012, 10:27 PM
MrE is offline
MrE
Find More Posts by MrE
MrE
United States, WA, Gig Harbor
Joined Aug 2007
Seems to me that if its mushing after you moved the cg back, then you didnt re-trim it to fly at the same speed as before you moved the CG. Sounds like you need another click or two of down.
MrE is offline Find More Posts by MrE
Old Dec 18, 2012, 12:55 AM
cityevader's Avatar
Joined Mar 2012
I'm laying in bed, mind whirling...
I'm picturing a mobile hanging from the ceiling. You know, different shapes and weights and moment arms...yet all in perfect balance.
Obviously a heavy/short arm balances a light/long arm and any air movement causes it to rock and sway. Now give each end a "perfectly" flat and level horizontal surface...then provide a "perfectly" horizontal and level wind. In a "perfect" world it would remain motionless regardless of wind speed. If say, the shorter arm had it's flat surface moved back to be right at the ("mounting") string, and then re-weighted to remain perfectly balanced, it should still stay motionless with a "perfectly flat" wind...regardless of speed.
If it were then allowed to "dive" at an angle, it would have a vertical vector force (gravity) and a horizontal vector force (wind).
Could it be surmised that in a "perfect" setting, it would balloon into the wind (due to horizontal vector forces on the lighter/longer "tail") and conversely tuck with a tail wind? (Perfect world and no other forces involved)
I'm not sure where I'm going with this, but I've lost enough thoughts at bedtime because I didn't write them down.
Old Dec 18, 2012, 01:02 AM
cityevader's Avatar
Joined Mar 2012
Jim
Just thinking out loud...if it "settles into a groove", isn't that an indicator all by itself that it's nose-heavy? ...If it "wants to" fly at a particular speed, that is?
Then, your second description is what I call porpoising...which is (to me anyways) an adverse flight characteristic...whether thermaling, sloping, or power planes...or maybe it's just me.
Old Dec 18, 2012, 01:08 AM
Francesco is offline
Find More Posts by Francesco
Francesco's Avatar
United States, CA, Mountain View
Joined Apr 2001
If that were true, wouldn't that mean that the glider flying in the air has a way to sense the airmass movement even it takes place at constant speed? Or am I mis-interpreting what you mean by tailwind/headwind?
Francesco is offline Find More Posts by Francesco
Old Dec 18, 2012, 01:14 AM
cityevader's Avatar
Joined Mar 2012
I was thinking that in one direction, the "wind" would hit the top of the "tail" and in the other direction the bottom of it.
On second thought, for actual flight, that would require a super steep dive in order that the horizontal "flight speed" would be less than the "tail-wind speed" in order for the wind to affect the underside of the tail whist going downwind...nevermind.
That's what I get for "bedtime physics"!
Old Dec 18, 2012, 01:35 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Upwind and downwind have no impact once the model is free of the ground, so any analysis of supposed differences between the two conditions is moot.
pmackenzie is offline Find More Posts by pmackenzie
Old Dec 18, 2012, 01:38 AM
cityevader's Avatar
Joined Mar 2012
not if the mobile is diving steep enough! but of course, it really isn't "flying" at that point.
Yup...bedtime physics indeed. I too tired to post, not tired enough to sleep.
Edited to add: I turned the computer back on to add that my above response was in an emotional fashion, to prove "I'm right" (even if I'm wrong) as prolly most of us have done thus far (and I don't know who's right or wrong)...
If said perfectly balanced mobile was traveling straight down, a 90 wind would affect the "tail" and push it to some degree, would it not? Thereby angling it more into the wind. Tail feathers of an arrow effect. re-edited: arrow is a bad example because of connotation of speeds which I wasn't intending....and you're still talking about a PLANE. I was talking about a ceiling MOBLIE.
We can both be right! We can both be wrong!
Old Dec 18, 2012, 01:55 AM
MrE is offline
MrE
MrE
Joined Aug 2007
I think its interesting to note that we have gone from:
The dive test is the way to check/set cg
to
The dive test is stupid (when your talking about cg) - it only tells you the trim setting
to
No its not stupid - it DOES tell you CG because its physics
to
It may or may not be stupid but it doesnt tell you squat about CG
Question Trim, cg, and incidence biskit High Performance 10 Dec 16, 2012 07:32 AM
decalage CG relations Beginner!? Modeling Science 4 Apr 26, 2005 07:04 AM
Debugging glider - which to tackle first: CG, incidence, decalage, elevator flex? dimple Hand Launch 6 Oct 28, 2004 11:09 AM
Tiny trim & CG questions JamesD Parkflyers 0 Oct 20, 2002 04:33 PM
