Would you mind expanding on what you mean? Do you mean balancing a model in the horizontal axis i.e. pitch?
What specific issues are you having? You could read "CG Position" and "Decalage" here: http://tailwindgliders.com/Tips.html Thanks Curtis |
Had the same basic discussion several times in the hand launch thread and I am sure in this thread.
this is the one I started: http://www.rcgroups.com/forums/showthread.php?t=1762343 I went through the RC Soaring Digest also (I listed the articles from each I was interested in. Some may help you with this question). Lots of guys with many letters after their name discussing the validity of the dive test, etc. http://www.rcsoaringdigest.com/pdfs/...SD-1991-08.pdf designing a sailplane pt 3 Understanding thermal Soaring Sailplanes pt4 - Ballance, Trim and Vortex Drag Launching http://www.rcsoaringdigest.com/pdfs/...SD-1992-02.pdf Flying in wind and weather CG, Elevator, Trim and decalage - theory http://www.rcsoaringdigest.com/pdfs/...SD-1992-03.pdf Flying in wind and weather CG, Elevator, Trim and decalage - practice The joy of competitive soaring http://www.rcsoaringdigest.com/pdfs/...SD-1992-04.pdf Flying in wind and weather CG, Elevator, Trim and decalage - The Utility Vacuum Feed through fitting http://www.rcsoaringdigest.com/pdfs/...SD-1992-09.pdf Flying in wind and weather CG, Elevator, Trim and decalage - Trimming techniques Programming the X347 On flying upside down http://www.rcsoaringdigest.com/pdfs/...SD-1993-01.pdf Addenda to Programming the X347 Decalage Again? Understanding Sailplanes Jer's Mold Making Part 1 And it goes on after that a few times as well. What I got was this: 1. CG sets stability. Back is less stable but more readily indicates lift. Unfortunately, you will need to be on the sticks more to correct for the turbulence. Forward dampens turbulence in pitch but also can mask thermals. It takes practice, not settings to differentiate lift from turbulence. 2. Decalage sets trim speed. How fast do you want to fly? you can adjust the decalage for faster or slower flight. Flatter is faster. In the end, it is a preference thing. Set all three the way you like the plane to fly. All three can change for some based on weather (wind and turbulence) conditions. Unless you are way off, no setting will make a plane horrible or suoper fantastic. It is still the pilot behind the sticks that wins contests. Enjoy the reading. I have. Frank |
United States, MA, Waltham
Joined Dec 2001
Stalls get sharper and nastier as the c.g. goes back. A tail heavy glider may diverge without a correction. For instance, it may go faster and faster and faster, pitching down all the while. Or it may pitch up a little and get really slow, without correcting itself, and stall hard. |
Latest blog entry: pics from Winthrop, MA indoor flying...
Joined Apr 2011
It's not really so confusing. Assume the plane is flying straight and level. It is staying level because it is balanced. By balanced, I mean that either it's weight is perfectly balanced and the horizontal stabilizer/elevator is not exerting any up or down force OR the weight is not perfectly balanced but the stab is exerting the perfect amount of up or down force to keep the plane level. Assume that the second case is true. When you put the plane in a dive, the nose weight does not change, regardless of the airspeed. However, the force exerted by the stab increases as the airspeed increases, so the balance achieved during level flight no longer exists. The out of balance plane will now either nose over even further, or recover from the dive, depending on whether the stab was exerting an upward force or a downward force during level flight. If the plane is nose heavy, then during level flight the stab had to exert a downward force to keep the plane balanced. When you dive the plane, this downward force increases but the nose weight stays the same, and the tail is forced down, which then forces the nose up, and the plane pulls up. If the plane is nose light (tail heavy) then during level flight the stab is lifting, and during a dive the tail lift increases, forcing the plane into an even steeper dive.
hmm...you're all saying what I thought was true, but previously adding nose/tailweight didn't yield satisfactory results.
hmm...perhaps I am a bit hung up regarding having the control surfaces neutralized for a neutralized flight, and need to ignore the "up-trim" for now. Therefore, as I mentioned before, I need to start from scratch. However! I need to do this more specifically than just "add/subtract weight". I need to mark the current CG and make incremental adjustments and re-measure and re-mark CG...then fly. Previously, I made adjustments on the slope (which means no way to actually check CG due to non-static/windy conditions) and then fly. I get too...what's the word?...pppffff and just "do something" rather than take an analytical and incremental approach. It's good to know that, at the very least, the way I saw the plane was on the right track...but what I did with that info was not. More importantly!!! I can't just go with three or more planes on one trip and try to remember exactly what each one is doing differently! |
| Thread Tools | |
| Question Trim, cg, and incidence | biskit | High Performance | 10 | Dec 16, 2012 07:32 AM |
| decalage CG relations | Beginner!? | Modeling Science | 4 | Apr 26, 2005 07:04 AM |
| Debugging glider - which to tackle first: CG, incidence, decalage, elevator flex? | dimple | Hand Launch | 6 | Oct 28, 2004 11:09 AM |
| Tiny trim & CG questions | JamesD | Parkflyers | 0 | Oct 20, 2002 04:33 PM |
